Single-Board Computers
  • Single-Board Computers
Forum WIFI dongle on beaglebone black
  • Subscribers 58 subscribers
  • Views 1803 views
  • wpa
  • wi-fi
  • BeagleBone
  • wireless
  • wi-fi_connectivity
Hi
I am working on beaglebone black trying to integrate TP link TL-WN721N Wifi dongle which uses atheros driver.
I am using linux 3.2 kernel with ti-sitara rootfs
The problem is when is type the command
                              wpa_supplicant -Dwext -i wlan0 -c /etc/wpa_supplicant.conf
it shows                  Successfully initialised wpa_supplicant
but it gets stuck there and i have to give ctrl+c to exit from that ,after that i gave
                              ifup wlan0
the response was
                             Sending discover...
                              Sending discover...
                              Sending discover...
                              No lease, failing
after this I repeated the step for wpa_supplicant this time also it gets stuck and when I gave ifup wlan0
this time it got the correct IP and was able to ping..........
This cycles was seemed to repeat when I tried connecting any-other wifi networks (ie: wpa_supplicant gets stuck two times and on the second attempt of ifup wlan0 only i will be able to get IP)
here is my /etc/wpa_supplicat.conf file
network={
        ssid="UTStarcom"
        #psk="123force"
        psk=44d83e5c96bd39f47b54625d80b80c79d5b14430d424fdf6636365901b01ab14
and my /etc/network/interfaces
# The loopback interface
     auto lo
     iface lo inet loopback
# Wired or wireless interfaces
     auto eth0
iface eth0 inet static
     address 192.168.2.30
     netmask 255.255.255.0
     gateway 192.168.2.1
allow-hotplug wlan0
     auto wlan0
     iface wlan0 inet dhcp
     wpa-driver wext
     wpa-conf /etc/wpa_supplicant.conf
Please help me out of this issue
Regards
Hariprasad
  • gsgill112
    gsgill112 over 12 years ago +1
    I recently got a Netgear N150 WNA1100 Wi-Fi Module with atheros chipset, Luckly both Angstrom and Debian images support this module as a plug and play device , even no need to install some separate package…
  • clem57
    clem57 over 10 years ago +1
    See https://www.youtube.com/watch?v=HJ9nUqYMjqs for how to. Clem
  • gsgill112
    0 gsgill112 over 12 years ago
    Luckly both Angstrom and Debian images support this module as a plug and play device , even no need to install some separate package or compile the drivers . image
  • clem57
    0 clem57 over 10 years ago
    Clem
  • clem57
    Is the eth0 on same network as the wlan0? If so, the failure makes sense.
    Clem
