Single-Board Computers
  • Single-Board Computers
Forum LPC4357-EVB LCD demo program problem
  • Subscribers 57 subscribers
  • Views 697 views
  • lcd
  • element14
  • lpc4357-evb
Hi all, I am using LPC4357-evb board.  While using LCD demo code, it works fine with a 4.3 TFT screen, but when I use the same demo file with a 7" TFT display, the image is not shown at all, what I am getting is just a few blurred lines, what should I do?
  • element14jamie
    0 element14jamie over 11 years ago
    Hello sakthiemb,
    Welcome to the element14 Community, we hope you enjoy it. I will move this over to the Single-Board Computers area as it is a better fit.
    Thank you,
    Jamie
    0 e14 Contributor over 11 years ago in reply to element14jamie
    Any solutions?
  • element14jamie
    0 element14jamie over 11 years ago in reply to e14 Contributor
    Hello sakthiemb,
    I do apologize for the confusion, I moved this to the appropriate area for members on the element14 Community to chime in and assist. I will see if anybody internally can chime is as well.
    Thank you,
    Jamie
  • cstanton
    0 cstanton over 11 years ago
    Hi sakthiemb,
    This is opening a huge can of worms, frankly.
    So to be able to make a better assessment of whether or not the LCD screen you're trying to use will work; you need to know the pinouts of the connector for the larger screen and compare that with the user manual: Embest: User Manual for LPC4357-EVB Evaluation Board , section 3.5.8, Figure 3-10, page 11.
    Also note that the board and manual mainly point out compatibility with a QVGA 4.3" screen, it's possible that the output signal is incompatible with the screen you're trying to use.
    Unfortunately I do not have access to one of these boards and the hardware you're using (which you also need to specifically state so that people can help you better, including make/model/revision of board).
    In other terms I suspect it simply won't work without some form of interim circuitry, but do report back with information or what the pinouts you've found on your LCD screen are and how they compare to the manual.
