GIZMO 2
  • Single-Board Computers
  • GIZMO 2
GIZMO 2
Blog Gizmo2: Adding external PWR and RST buttons
Join GIZMO 2 to participate - click to join for free!
  • Author Author: fvan
  • Date Created: 28 Jan 2015 9:56 AM Date Created
  • Views 2579 views
  • Comments 8 comments
  • buttons
  • reset
  • jtag
  • external
  • gizmo2
  • gizmosphere
  • power
fvan
fvan
28 Jan 2015
  • Introduction
  • Buttons
  • Demo
In my previous post, I designed and 3D printed an enclosure for the Gizmo2. Unfortunately, this blocks access to the onboard power and reset buttons. So I searched for a way to have some external buttons which I could eventually mount to the enclosure.
Buttons
The process to find where I could connect my buttons to was rather simple actually. Using my multimeter, I searched for connections between the buttons and the JTAG debug port. I quickly found following mapping:
Using jumper wires, I made the connections with buttons on a breadboard and tested the setup. Both buttons work as expected image
image UPDATE: the two colored pins on the top row are actually connected, so they could be replaced by a single, common connection.
Demo
Here's a short video demonstrating the buttons functioning as expected:
  • fvan
    fvan over 11 years ago in reply to e14 Contributor +1
    I used my multimeter to find pins on the debug header directly attached to the buttons The schematics are also available, so I'm assuming the info should be in there as well.
    e14 Contributor over 11 years ago in reply to fvan +1
    Oh righty, thank you very much!
    Frederick,
    nice post and good video demo. At this point arise two questions: The first is why the debug port while there is a couple of specific pins on the PCIe connector of the Gizmo2 for the reset button and the power button ?
    Then, I read somewhere else a note about your post always on Gizmo2 about an external power. Is there a way to find it somewhere? I have searched inside the Element14 posts by author but I found nothing.
    Enrico
    DAB over 11 years ago
    Nice idea, especially if you cannot solder buttons in parallel with the on board power and reset.
  • dls3491
    dls3491 over 11 years ago
    where can I get the cable for debug port
  • xever
    xever over 11 years ago in reply to fvan
    Yes, the pin out is also in the schematic on Sheet 8.  http://www.gizmosphere.org/wp-content/uploads/2014/12/amd_gizmo2_sch_12_13_2014.pdf
