BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Blog How Do You Get C onto a BeagleBone AI?
Join BeagleBoard to participate - click to join for free!
  • Author Author: dubbie
  • Date Created: 13 Nov 2019 9:05 AM Date Created
  • Views 4334 views
  • Comments 17 comments
  • c on the beaglebone ai
dubbie
dubbie
13 Nov 2019
Could anyone give me a quick pointer as to where to look for information on how to transfer a C programme to the BeagleBone AI and then compile it and run it?
I have a C programme compiled in Microsoft that I wish to transfer to a BeagleBone AI. I have had a quick look online and Element14 and so far I have not found any information about this. I am not a Linux user so this may be easy and obvious but when you don't know something it always seems hard. The C programme implements an Artificial Neural Network and I want to use it with my LDR Camera as part of the Vision Thing Project14. Time is running out.
Dubbie
  • Sean_Miller
    Sean_Miller over 7 years ago +4
    BeagleBone uses a development system called Cloud9. You access it after the BBAI boots up by typing http://youripaddress in a Browser on your network. The address could be a different depending how you…
  • skywalker1211
    skywalker1211 over 7 years ago +3
    copy source file and header to the and run gcc to compile it. example: main.c and main.h gcc main.c -o main run by ./main
    Jan Cumps over 7 years ago +3
    If you want to develop and compile on your PC and then run/debug on the BB(AI): BeagleBone: Build and Debug a Linux C++ Program with Code Composer Studio
    dubbie over 7 years ago in reply to Sean_Miller
    I tried Java once when it first came out. I wanted an internet camera as well to see when the coffee was ready. It was supposed to be the answer to all my problems with controlling stuff. Java and I just didn't get on. All I wanted to do was turn a LED on and off. Even when I was given a working programme I still couldn't get it work. I'll stick with C unless Python is any good.
    Dubbie
  • Sean_Miller
    Sean_Miller over 7 years ago in reply to dubbie
    I remember learning C back around 95 with a Sams Teach Yourself in 21 days book.  It was such a major shift for me from BASIC.  I remember absolutely struggling to learn it.  Once JAVA came out and it handled strings and memory so much better, I thought - I'm glad I'll never need C again.
    25 years later, the microcontroller begins to roam the earth and now I program in C more than anything.  Funny how that can happen.
    -Sean
    dubbie over 7 years ago in reply to Jan Cumps
    Jan,
    Debug in real-time. Is that a real thing? I think the only time I tried debugging in real time was with an 8086 emulator with associated logic analyser and it was so long ago I think dinosaurs stilled roamed the earth. I have tended to rely on pure brain power and thinking when debugging which stems from when I was studying and it took 30 minutes or more to make a change to a programme. You just had to work out what the problem was before making an edit, rather than the try it and see what happens approach - when editing a programme and re-running it takes only a few seconds. Still having said that I spent hours yesterday trying to work out why a C programme wasn't compiling, deleting all comments, deleting all unnecessary code and eventually resorted to commenting out statement by statement until  I realised I had accidentally deleted the last close bracket ( } ) from the main loop. C error messages can be so unhelpful at times.
    Dubbie
  • Sean_Miller
    It intimidated me at first.  After a bit I quickly realized the efficiency of it, particularly for running the examples.  It also sustains your session between visits.  So, Cloud9 has become the only way I develop with the BBAI.
    See ya,
    Sean
    Jan Cumps over 7 years ago in reply to dubbie
    dubbie  wrote:
    I think this approach would have to be a last resort for me, as it looks fairly complicated.
    Dubbie
    .... but you can debug image real time
