BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Blog How Do You Get C onto a BeagleBone AI?
Join BeagleBoard to participate - click to join for free!
  • Author Author: dubbie
  • Date Created: 13 Nov 2019 9:05 AM Date Created
  • Views 4335 views
  • Comments 17 comments
  • c on the beaglebone ai
dubbie
dubbie
13 Nov 2019
Could anyone give me a quick pointer as to where to look for information on how to transfer a C programme to the BeagleBone AI and then compile it and run it?
I have a C programme compiled in Microsoft that I wish to transfer to a BeagleBone AI. I have had a quick look online and Element14 and so far I have not found any information about this. I am not a Linux user so this may be easy and obvious but when you don't know something it always seems hard. The C programme implements an Artificial Neural Network and I want to use it with my LDR Camera as part of the Vision Thing Project14. Time is running out.
Dubbie
  • Sean_Miller
    Sean_Miller over 7 years ago +4
    BeagleBone uses a development system called Cloud9. You access it after the BBAI boots up by typing http://youripaddress in a Browser on your network. The address could be a different depending how you…
  • skywalker1211
    skywalker1211 over 7 years ago +3
    copy source file and header to the and run gcc to compile it. example: main.c and main.h gcc main.c -o main run by ./main
    Jan Cumps over 7 years ago +3
    If you want to develop and compile on your PC and then run/debug on the BB(AI): BeagleBone: Build and Debug a Linux C++ Program with Code Composer Studio
  • skywalker1211
    skywalker1211 over 7 years ago in reply to dubbie
    i usually use winscp to copy file from windows to linux
    https://winscp.net/eng/download.php
    dubbie over 7 years ago in reply to Sean_Miller
    Sean,
    I understood most of this and a little lightbulb of understanding flickered on, thanks. It seems to be eminently viable for me. I think I will give this a go.
    Dubbie
    dubbie over 7 years ago in reply to Jan Cumps
    I think this approach would have to be a last resort for me, as it looks fairly complicated.
    Dubbie
    dubbie over 7 years ago in reply to skywalker1211
    This looks helpful, although I'm still not sure how to get the C programme into the BBAI Linux environment. I assume the gcc is already installed on the BBAI. Will I be able to copy in the Windows environment and then paste into an empty file in the BBAI environment?
    Dubbie
  • Sean_Miller
    BeagleBone uses a development system called Cloud9.  You access it after the BBAI boots up by typing http://youripaddress in a Browser on your network.  The address could be a different depending how you connected to your BBAI.  If you connected using the BBAI adhoc connection, it is 192.168.8.1.
    Cloud9 seems a little clunky at first, but you soon see the benefits when you start doing things like familiar shortcuts and compiling.
    To add a C program in the Cloud9 environment, here's my approach:
    1. Right Click on the BeagleBone/AI directory
    2. Choose New File.
    3. Rename that file to whatever you like:  forexample,   helloworld.c
    4. Double click on the file name.
    5. You will have a very nice text editor open up in the main pane.  Paste your code here and hit CTRL s to save.
    6. Click the green Run button on top.  It will fail due to the "runner needing set".
    7. In the bottom pane, set your runner to C or C++ (Beagle Makefile).
    If you need GPIO, PWM, or I2C, there will be more to set up.  This blog will get you there:
    BeagleBone AI Survival Guide V3.18: PWM, I2C, Analog/Digital Read/Write, Vision AI, Video Text Overlays, Audio, & Hardware
    See ya',
    Sean
