BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Forum Beaglebone Black Internet issue
Join BeagleBoard to participate - click to join for free!
  • Replies 9 replies
  • Answers 2 answers
  • Subscribers 111 subscribers
  • Views 4917 views
  • beagle bone black
  • internet connection
gunjanvora
gunjanvora over 9 years ago
I have a Beaglebone Black board having following configuration :- Linux beaglebone 3.8.13-bone47, Debian GNU/Linux 7 (wheezy). The internet connection in this board is not working. Neither through USB now through Ethernet. Kindly help me to resolve this issue.
  • ninjatrent
    ninjatrent over 8 years ago +1
    This video might be a better explanation. www.youtube.com/watch
  • jomoenginer
    jomoenginer over 8 years ago +1
    I think Gunjan is not getting the wired Ethernet or the USB IP to work on the Beaglebone Black so I believe it is not a Wi-Fi issue. @Gunjan - try running 'dmesg' on the Beagelbone to see if there are…
  • gsgill112
    gsgill112 over 8 years ago in reply to ninjatrent +1
    Do you have any help with enabling the DTO files for WLAN and BLE Module ? I have a Beagle Bone Black with WCC cape and I am having some issues with getting it working. //GS GILL
  • crjeder
    0 crjeder over 9 years ago
    Please post more details:
    How are you accessing your BBB? Attached keyboard and monitor?
    How is your network set up? DHCP Server in place?
    For USB: Drivers installed?
  • gunjanvora
    0 gunjanvora over 9 years ago in reply to crjeder
    I'm using USB cable to connect to BBB to my laptop. Drivers are installed properly for Windows
  • crjeder
    Could you please post the output of ifconfig?
  • gsgill112
    0 gsgill112 over 8 years ago
    some more details. please. try connecting the FTDI cable and get the boot sequence , if there is any issue during boot.
    GS GILL
  • ninjatrent
    0 ninjatrent over 8 years ago
    To enable connection of the Beaglebone to the desired network.
    # As root enter the following commands
    connmanctl
    tether wifi off
    enable wifi
    scan wifi
    services  #(this will call a list of available networks)
    agent on
    # For Dynamic IP Address DHCP
    connect wifi_xxxxxxx_xxxxxx_managed_psk
    ( enter desired network's managed PSK.)
    # For Static IP
    connmanctl config wifi_xxxxxx_xxxxxx_managed_psk --ipv4 manual 192.168.1.7 255.255.255.0 192.168.1.1 --nameservers 8.8.8.8  (change 192.168.1.7 to desired IP and change 192.168.1.1 to network gateway)
    quit
    Hope this will work for you.
    Trent
  • ninjatrent
  • jomoenginer
    0 jomoenginer over 8 years ago
    @Gunjan - try running 'dmesg' on the Beagelbone to see if there are any messages that are related to the Ethernet port being down or the driver having issues.
    Also, as we mentioned previously, check 'ifconfig -a' to see if the Ethernet port is up or not.
    Have you tried rebooting the BBB or restart the network interface?
    You should be able to restart the network interface with:
    # sudo /etc/init.d/network restart
    Derek Molloy has pretty good instructions on how to set up the Ethernet ports on the Beaglebone Black so you might want to have a look at the following links.
    http://derekmolloy.ie/set-ip-address-to-be-static-on-the-beaglebone-black/
    http://derekmolloy.ie/beaglebone/getting-started-usb-network-adapter-on-the-beaglebone/
  • gsgill112
    0 gsgill112 over 8 years ago in reply to ninjatrent
    //GS GILL
  • ninjatrent
    0 ninjatrent over 8 years ago in reply to gsgill112
    Unfortunately the information that I have provided is the limit of my knowledge with this TI Wi-Fi Module on the BBB Wireless.
    It has only been a few months since beginning to work with the Beaglebone. Primarily experienced with Raspberry Pi. The Beaglebone Black Wireless has won me over with its abilities and design.
    If the cape that you speak of uses the same Ti WiFi Chip, you might be able to find a solution in the documentation.
    Trent
