BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Forum Can a BBB run Debian 11.7 GUI?
Join BeagleBoard to participate - click to join for free!
  • Subscribers 107 subscribers
  • Views 1637 views
landolfi
landolfi over 2 years ago
I inherited an Element14 Beaglebone Black from my grandson and tried to install the latest Debian 11.7 GUI software image on it from https://www.beagleboard.org/distros/am335x-11-7-2023-09-02-4gb-emmc-xfce-flasher.
The GUI loads the first time I boot after flashing, but subsequent boots go to a command prompt, and when I try to install anything it says "no space left on device", leading me to think the only way to run a GUI is off SD even though I got the image directly from the BBB software images. Any other ideas?
I don't have a specific application for this, just wanted to use the UI to play around with it. I've also noticed from previous times I had a UI running, my 802.11n Edimax USB wifi module and browser are incredibly resource intensive and slow even with the router only 20 feet away. Would an older, non-GUI OS solve the slow wifi performance?
Bob
    shabaz over 2 years ago +2
    Hi Bob, You're correct, the BBB needs a micro SD card for any reasonable image with GUI, i.e. desktop. The build-in storage (eMMC) is quite small. The BBB is a very underpowered platform nowadays, so…
  • cstanton
    cstanton over 2 years ago in reply to shabaz +2
    shabaz said: (those will require a micro SD card) Or USB, or even with the Pi 5 an nvme with the appropriate hat! And perhaps even network boot. I cannot remember if the BBB supported pxe booting.
  • bidrohini
    bidrohini over 2 years ago +1
    Flash the Debian 11.7 XFCE image to an SD card instead of using the eMMC, or switch to a lighter distribution. Consider a non-GUI OS to free up resources and improve Wi-Fi performance.
    0 shabaz over 2 years ago
    Hi Bob,
    You're correct, the BBB needs a micro SD card for any reasonable image with GUI, i.e. desktop. The build-in storage (eMMC) is quite small. The BBB is a very underpowered platform nowadays, so desktop performance won't be very good. It may be better to use it without launching a desktop, and just SSH'ing into a text-based shell prompt.
    Something like Pi 4 or Pi 5 would have much better desktop experience (those will require a micro SD card).
  • bidrohini
    0 bidrohini over 2 years ago
  • landolfi
    0 landolfi over 2 years ago in reply to bidrohini
    Thanks to all! This all began because the factory eMMC image wouldn't drive the wireless module. I had previously tried LXQT 9.1 on SD with no significant performance improvement. I'll try going back to the oldest GUI on SD and if that doesn't work I'll settle for a non-GUI.
  • cstanton
    0 cstanton over 2 years ago in reply to shabaz
  • mp2100
    0 mp2100 over 2 years ago in reply to landolfi
    Yes. I love the bbb, but Even 5 years ago the bbb was slow with xwindows gui. You could try and flash really old angstrom images onto it but that would be not very secure by today’s standards.
