BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Forum Beaglebone Hang on Reboot
Join BeagleBoard to participate - click to join for free!
  • Subscribers 109 subscribers
  • Views 2105 views
  • beagleboneblackindustrial
  • hang
I joined a company recently that is using the Beaglebone black in a device that is outdoors. I recommended that we switch to the Industrial Element 14 version for improved temperature specs.
One serious issue that came up with the original BBB is that it would sometimes hang when reset and it prompted us to design in an external watchdog. A test that we performed was to reboot Linux (sudo shutdown -r now)
every few minutes using several boards and we found that a hang would occur about 5% of the time. There is this blurb but it is inconclusive and suggests abrupt power loss as a culprit and it doesn't seem that they performed the simple reboot experiment.
Has anyone had this experience? Has anyone studied the PMIC (measured voltage and timings examined the errata etc)?
Kenny
  • volly
    volly over 10 years ago
    kennykoller, I had similar intermittent incidences like you are experiencing. It has got to do with an occasional phantom UART character causing the problem.
    This is what I did....
    Check out the following link and do this. http://andicelabs.com/2014/07/beaglebone-black-boot-issues/
    If you do not get this, please let me know and I will get you goings, okay?
    YV.
    e14 Contributor over 10 years ago in reply to volly
    Yunus,
    This is excellent. The Google link you referenced also reported 1/20 failures. This seems like a very solid theory and we'll retest with your solution.
    Thank you for taking the time to write things up and making them available to the community.
    Kenny
  • volly
    kennykoller, glad you could find some headway with this info.
    Please keep us all posted with the respective outcomes.
    Also, please take some time to also mark these replies as helpful and or liked, this is
    what keep this community inspired and active.
    Best Regards
    YV.
  • jy824212
    jy824212 over 8 years ago in reply to volly
    When I follow the instruction from the link you recommended, when I perform the last thing inside of the Robert Nelson’s instructions , when I reach
    make ARCH=arm CROSS_COMPILE=${CC}
    My beaglebone says the gcc  version is older than 6.0 mine is 4.8
    Wonder if you ever encountered this issue and if there is a way to get over with it.
