BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Forum BBB can not boot , and flash
Join BeagleBoard to participate - click to join for free!
  • Subscribers 107 subscribers
  • Views 649 views
  • not booting
  • beagle bone black
  • bbb
lunaret
lunaret over 8 years ago
I got the problem after updated PyBBIO reboot via cloud 9 IDE, then my BBB had permanently turned on all of LEDs , and i tried to flash OS, the LEDs are blinked  sequentially 1-2 times and USR2  is on all time.
So, How to fix this thing?
  • littleben1
    littleben1 over 8 years ago
    Have you tried to redo the boot from sd card sequence and start over? When I first got mine it had some problems with the os that was in the emmc so I followed the steps of installing a new os from an sd card (hold down the boot button as you power on, etc.) and after I finally got it to boot from the card and installed the new os to the emmc it was able to get rid of whatever corruption was in the original install of the os. anyways it fixed my problems so I would suggest trying it, would be better than a fried board, hope it helps
  • littleben1
    Was looking back at this and wondering if the redownload helped you with the boot problems? Hoping things worked out for you, I know with mine it took messing around with it for a while, but then I finally got the right sequence and it started right up.
