BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Forum Kernel configurations reset by make command
Join BeagleBoard to participate - click to join for free!
  • Subscribers 107 subscribers
  • Views 795 views
elem2018
elem2018 over 7 years ago
Hi There,
my environment:
BBB, ti-processor-sdk-linux-am335x-evm-05.01.00.11
After running
$(MAKE) -C $(LINUXKERNEL_INSTALL_DIR) ARCH=arm CROSS_COMPILE=$(CROSS_COMPILE)  tisdk_am335x-evm_defconfig
I get .config file in the linux kernel root path
Now I changed CONFIG_BRCMFMAC=m to CONFIG_BRCMFMAC=y  in this .config file to get inbuild driver.
After that I built the dtb file
$(MAKE) -j $(MAKE_JOBS) -C $(LINUXKERNEL_INSTALL_DIR) ARCH=arm CROSS_COMPILE=$(CROSS_COMPILE)  am335x-boneblack.dtb
Now strange thing happened:
CONFIG_BRCMFMAC=y in the .config file is set back to CONFIG_BRCMFMAC=m,   not what I wanted CONFIG_BRCMFMAC=y !
It seems that the make command reset the .config file.
Question:
How can I make sure that CONFIG_BRCMFMAC=y stays permanently, not reset by the make command?  I tried to do it in the tisdk_am335x-evm_defconfig file, but the same results.
Regards
Xi
  • elem2018
    excatly speaking it is not reset, but ovewritten.  Now I find out that the FMAC driver can't be set as built-in, running menuconfig I can only choose either FMAC as module or no FMAC. In the appropriate Kconfig file, I see the FMAC is defined as tristate,
    so it is strange why only two states are allowed.  The Linux kernel versoin 4.14.67.  Thanks in advance for any hint
    Regards
    Xi
