RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Forum 1280x720 on RIOTboard!!!
  • Subscribers 25 subscribers
  • Views 1149 views
So the Android package gives humongous black bars on my Sony Bravia LCD.  I try to flash to ubuntu...  Turns outIt gives 1280x720 and nothing else.  (And it has no black bars.)  That's because I have a scorching case of the 1280x720 blues, again!  My Raspberry Pi NEVER gave me this problem.  Ever.
    By Blues, I mean I've got massive overscan.  The exact opposite of what I got with Android.
  • element14jamie
    element14jamie over 12 years ago in reply to e14 Contributor
    Hello
    I will send this over to the RIoTboard area as it is a better fit to your question.
    Thank you for being a member of the element14 Community!
    Jamie
  • radiatortwo
    radiatortwo over 12 years ago
    The resolution is set in the boot variables of u-boot.
    Heres a thread with that: Screen Resolution with preinstalled Android
    e14 Contributor over 12 years ago in reply to radiatortwo
    I've also seen anecdotal tales that leaving the video= piece out altogether, or removing the resolution might allow it to use EDID, however it seems rather variable as there are some boards using i.MX6 where EDID doesn't work properly or hasn't been connected... So forcing the resolution on the commandline has become the norm.
    letting the system use EDID seems to be much more workable with 3.15 kernel, but that doesn't help for android...
  • tusharp
    tusharp over 12 years ago
    basically when the display resolution is different from the standard 16:9 ratio the painting happens improperly.
    so even though you set 1280*720 it may not be painting the horizontal and vertical pixels properly .
