RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Forum spdif audio programming
  • Subscribers 24 subscribers
  • Views 696 views
kylemills
kylemills over 12 years ago
i was able to setup the riotboard on Linux after some attempts.
i discovered there is a spdif interface, i want to do some sound programming.
i am new to embedded but have worked on linux, so any pointers will be good.
regards
kyle
  • tusharp
    tusharp over 12 years ago in reply to kylemills +1 verified
    there is freescale document AN3663 on sgtl5000. its a high performance low power codec and highly supported by freescale .
    While the i.MX6 is capable of SPDIF, unfortunately it's not been usefully wired up on the RIoTboard. Without sensible access to the hardware side of the SPDIF, there really isn't a lot you can do with it.
    The only obviously accessible SPDIF signals would be:
    SPDIF_IN on KEY_COL3, but that's already used by HDMI
    SPDIF_IN on EIM_D21
    SPDIF_OUT on EIM_D22
    both of which are used for USB OTG power and would probably require removal of U20.
  • kylemills
    0 kylemills over 12 years ago in reply to e14 Contributor
    If SPDIF doesn't work, any other interface i can use image.
  • tusharp
    0 tusharp over 12 years ago in reply to kylemills
