RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Documents RIoTboard Quick Start Tutorials
Join RIoTboard to participate - click to join for free!
  • Date Created: 1 Apr 2015 8:35 AM Date Created
  • Last Updated Last Updated: 14 May 2015 9:18 AM
  • Views 5565 views
  • Comments 14 comments
The RIoTboard RIoTboard is an open source platform based on an i.MX 6Solo applications processor, using an ARMRegistered CortexRegistered-A9 architecture.
element14 has produced a six part video series for the RIoTboard to help you get started. The video series will cover basics such as connecting displays and sensors. The tutorials will use both; Linux (Ubuntu) and Android (ICS) operating systems with the RIoTboard.  Basic RIoTboard introductions are also available HERE.
Part 1:How to connect different Displays to the RIoTboard on both Android and Linux.
Part 2: Reprogramming the EMMC flash memory
Part 3: Creating a bootable SD card.
Part 4: Connecting cameras to the RIoT board.
Part 5: Adding wireless Connectivity
Part 6: Connecting the Sensor Module
  • tutorial
  • tutorials
  • riotboard_tutorial
  • tusharp
    tusharp over 11 years ago in reply to fvan +1
    can you give this a try, its SVN3000.
  • tusharp
    Previous build were not configured in terms of kernel GADGET support . This build will be the official & the most updated one. Will push this to download center shortly.
  • tusharp
    This new image also seems to be smaller in size: 1.41GB vs 3.97GB for the other Yocto image ? Added some needed but missing packages (webcam,rsync,ntp,apache,libpng....) & removed a lot of bloatware…
  • stmorgan
    stmorgan over 9 years ago in reply to jim-st
    Tushar Panda's blog is probably the best place for you to start looking for answers to your questions:
    [One Stop Place] RIoTboard Platform Glossary
    The Supported OS Images section has links to source for several Android and Linux builds.
    This blog also has a Yocto on RIoTboard section with information on how to use Yocto in conjunction with community Freescale BSPs available here:
    https://github.com/Freescale/fsl-community-bsp-platform
    The blog also has a RIoTboard Documentation section with a link to the user manual which has procedures for building from source, although they may be out-of-date in some respects.
    This thread will give a notion as to what particular kernel versions you can get with specific Yocto releases:
    Yocto Layer Change Relevant to RIoTboard
    Just be aware that Embest and RIoTboard devs have apparently moved on to other things, so there is not much in the way of support anymore.  The same probably is probably true for community participants who put together the sub-forum content 2-3 years ago.
  • jim-st
    jim-st over 9 years ago
    Are the sources to build a kernel available anywhere?
    when I worked on the imx5 the Freescale blobs were pushed which had the reverence platform driver bsp setup, and it was handy to have.
    Is this near any reference design, and is the support pushed anywhere, so it could be combined with the kernel image + freescale bits to make a kernel?
    thanks
    Jim
  • tusharp
    tusharp over 11 years ago in reply to e14 Contributor
    Linux Ubuntu throws errors when i do apt-get update
    try below in terminal:
    Step1: updating the sources,
    cat <<EOF >> /etc/apt/sources.list
    deb http://old-releases.ubuntu.com/ubuntu/ oneiric main restricted universe multiverse
    deb http://old-releases.ubuntu.com/ubuntu/ oneiric-updates main restricted universe multiverse
    deb http://old-releases.ubuntu.com/ubuntu/ oneiric-security main restricted universe multiverse
    EOF
    Step2: installing aptitude
    sudo apt-get install aptitude
    Step3: update all.
    sudo aptitude update
    I burned the BSP Linux Yocto image on to a 16GB SD card but it doesn't boot. All the boot settings are set to boot from SD card. Linux Ubuntu works fine but doesn't have a valid resolution apart from 640X480. Its sad to see that appropriate software for this hardware is not well maintained. Linux Ubuntu throws errors when i do apt-get update and it does not let me download OpenCV even though i can browse through all the websites on Mozilla. I would be happy if anyone here can help me out.
  • fvan
    fvan over 11 years ago in reply to tusharp
    Great, thanks a lot for your help!
  • tusharp
    Added some needed but missing packages (webcam,rsync,ntp,apache,libpng....) & removed a lot of bloatware to keep size minimal image.
  • tusharp
  • fvan
    That seems to work. Could you explain why it didn't work before (while it does in the videos) and it does with this new image?
  • tusharp
  • fvan
    fvan over 11 years ago in reply to fvan
    I would also add that using the Android Kit Kat 4.4 SD Card image (SDcard-image_SVN2705.zip), everything is fine and Wifi works properly.
