RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Documents RIoTboard Quick Start Tutorials
Join RIoTboard to participate - click to join for free!
  • Author Author: Former Member
  • Date Created: 1 Apr 2015 8:35 AM Date Created
  • Last Updated Last Updated: 14 May 2015 9:18 AM
  • Views 5130 views
  • Comments 14 comments
The RIoTboard RIoTboard is an open source platform based on an i.MX 6Solo applications processor, using an ARMRegistered CortexRegistered-A9 architecture.
element14 has produced a six part video series for the RIoTboard to help you get started. The video series will cover basics such as connecting displays and sensors. The tutorials will use both; Linux (Ubuntu) and Android (ICS) operating systems with the RIoTboard.  Basic RIoTboard introductions are also available HERE.
Part 1:How to connect different Displays to the RIoTboard on both Android and Linux.
Part 2: Reprogramming the EMMC flash memory
Part 3: Creating a bootable SD card.
Part 4: Connecting cameras to the RIoT board.
Part 5: Adding wireless Connectivity
Part 6: Connecting the Sensor Module
  • tutorial
  • tutorials
  • riotboard_tutorial
  • tusharp
    tusharp over 11 years ago in reply to fvan +1
    can you give this a try, its SVN3000.
  • tusharp
    Previous build were not configured in terms of kernel GADGET support . This build will be the official & the most updated one. Will push this to download center shortly.
  • tusharp
    This new image also seems to be smaller in size: 1.41GB vs 3.97GB for the other Yocto image ? Added some needed but missing packages (webcam,rsync,ntp,apache,libpng....) & removed a lot of bloatware…
  • fvan
    fvan over 11 years ago
    Having trouble getting the wifi to work with the Yocto Linux image.
  • tusharp
    which yocto release you are using ??
    Plz share the output of below command
    ifconfig -a
    WiFi Manual for Riotboard.
  • fvan
    fvan over 11 years ago in reply to tusharp
    Linux 3.10.17 [RIoTboard SDCard image] (SDcard-image_SVN2652.zip)
    In combination with the purple element14 wifi dongle wifi dongle
  • fvan
    fvan over 11 years ago in reply to fvan
    I would also add that using the Android Kit Kat 4.4 SD Card image (SDcard-image_SVN2705.zip), everything is fine and Wifi works properly.
  • tusharp
  • fvan
    That seems to work. Could you explain why it didn't work before (while it does in the videos) and it does with this new image?
  • tusharp
  • tusharp
  • fvan
    Great, thanks a lot for your help!
