WaRP7
  • Single-Board Computers
  • WaRP7
WaRP7
Blog Warp7 Yocto : Part1 : setup, configure and generate Warp7 binaries
Join WaRP7 to participate - click to join for free!
  • Author Author: tusharp
  • Date Created: 16 Sep 2016 7:30 AM Date Created
  • Views 9915 views
  • Comments 89 comments
  • tusharp
  • imx7
  • yocto
  • image
  • bitbake
  • warp7
  • embedded
  • yocto-bsp
  • linux
tusharp
tusharp
16 Sep 2016
Contents
1. Warp7 Yocto Part1 <-- You are here
2. Warp7 Yocto Part2
3. Warp7 Sensors demo - mpl3115a2
4. Warp7 Sensors demo - fxos8700cq
5. Warp7 IoT demo
The Warp7 is a next generation Wearable and IoT development platform.
plz refer  NXP and element14 website for more platform related information.
Warp7 Board
CPU Board
IO Board
In this blog we will
1. Download warp7 yocto sources.
2. Setup required environment.
3. add/customise warp7 machine configs.
4. Compile and generate binaries.
A bit on yocto before we start :
If you are new to yocto , plz make sure to check the yocto project before proceeding.
Platform Setup:
I am using Ubuntu 14.04 x86_64 for the build process. you can use do this from a Virtual Machine (vmware, virtualbox) also.
We need to install some packages on which yocto depends for the build process.
sudo apt-get install gawk wget git-core diffstat unzip texinfo gcc-multilib build-essential chrpath socat libsdl1.2-dev \
xterm sed cvs subversion coreutils texi2html python-pysqlite2 help2man make gcc g++ desktop-file-utils libgl1-mesa-dev \
libglu1-mesa-dev mercurial autoconf automake groff curl lzop u-boot-tools
Download repo:
We need to have a repo tool to pull yocto sources.
mkdir ~/bin
curl http://commondatastorage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
chmod a+x ~/bin/repo
export PATH=~/bin:$PATH
Download Yocto:
following steps will help download yocto sources from NXP(Freescale) official repository:
mkdir warp7_yocto
cd warp7_yocto
repo init -u https://github.com/Freescale/fsl-community-bsp-platform -b krogoth
repo sync
Before building the yocto bsp we need to update the yocto build with warp7 config.
To configure we need to pass the proper MACHINE name as a macro.
Determine machine name:
echo; ls sources/*/conf/machine/*.conf | sed s/\.conf//g | sed -r 's/^.+\///' | xargs -I% echo -e "\t%" | grep imx
The Warp7 machine name is imx7s-warp .
Setting up the environment:
MACHINE=imx7s-warp source setup-environment build
Select "Y" to accept the EULA license and complete the machine config setup.
Now a build directory is created under ~/warp7_yocto directory.
It contains the build system settings for warp7 machine(i.e local.conf) and yocto bitbake layers path information (i.e bblayers.conf).
local.conf
bblayers.conf
Customise warp7 machine config:
Now edit the kernel source in warp7 machine configuration file.
in ~/warp7_yocto/sources/meta-fsl-arm-extra/conf/machine/imx7s-warp.conf file, edit as below.
Replace
PREFERRED_PROVIDER_virtual/kernel ?= "linux-fslc-imx"
with
PREFERRED_PROVIDER_virtual/kernel ?= "linux-warp"
Now the kernel source will be pulled from the linux-warp%%  bitbake recipe.
Create a directory named "linux-warp7-4.1" and recipe named "linux-warp7_4.1.bb" in below path.
~/warp7_yocto/sources/meta-fsl-arm-extra/recipes-kernel/linux/
mkdir ~/warp7_yocto/sources/meta-fsl-arm-extra/recipes-kernel/linux/linux-warp7-4.1
touch ~/warp7_yocto/sources/meta-fsl-arm-extra/recipes-kernel/linux/linux-warp7_4.1.bb
Populating warp7 recipe:
populate the recipe "linux-warp7_4.1.bb" with below contents.
# Released under the MIT license (see COPYING.MIT for the terms)
include recipes-kernel/linux/linux-imx.inc
include recipes-kernel/linux/linux-dtb.inc
DEPENDS += "lzop-native bc-native"
SRCBRANCH = "4.1-1.0.x-imx"
SRCREV = "fa571312b4271e368ca99ffcdf7992247d534e55"
SRC_URI = "git://github.com/WaRP7/linux-fslc.git;branch=${SRCBRANCH} \
           file://defconfig"
COMPATIBLE_MACHINE = "(imx7s-warp)"
In above recipe we setup 4.1-1.0.x-imx as source branch for our kernel and file defconfig will be the default kernel config file.
Next copy the defconfig file (in attachment) into the linux-warp7-4.1 directory.
Downloading yocto packages:
If you want to build images offline, its a good idea to download the packages first.
bitbake core-image-minimal -c fetchall
Build:
Now build, it will take several hours to complete depending on your PC configuration.
While kernel build is in process you might encounter an error wrt imx7s-warp.dtb.
This will happen is there is no imx7s-warp.dts file in below directory.
~/warp7_yocto/build/tmp/work/imx7s_warp-poky-linux-gnueabi/linux-warp7/4.1-r0/git/arch/arm/boot/dts
below is a snapshot from the log file that captured the above  error.
In that case copy the imx7s-warp.dts from the attachments to the below directory:
Now hit build again.
After build completed, the images build are found in ~/warp7_yocto/build/tmp/deploy/images/imx7s-warp
Let us know any challenges faced during build procedure through comments.
Next time we will flash the generated images.
Happy Warping.
warp7_attachments.zip
  • bwelsby
    bwelsby over 9 years ago in reply to Jan Cumps +1
    Jan Cumps wrote: bitbake -fetch finished successful (14 hours on the raspberry pi to complete all 189 jobs. it used 4 job threads to allocate tasks on this board), now up to the next step: build That's…
  • bheemarao
    bheemarao over 9 years ago +1
    I tried building the same as shown steps below bheema@Bheema:~/warp7_yocto$ MACHINE=imx7s-warp source setup-environment build-warp7 then by default the kernel will fetch from "include recipes-kernel/linux…
    Jan Cumps over 9 years ago in reply to Jan Cumps +1
    Installing the dependencies. Once I'm at the bitbake line, I'll switch to bheemarao 's steps...
  • marcocavallini
    marcocavallini over 8 years ago
    Running this from a Virtual Machine (vmware, virtualbox) the Device Firmware Upgrade Mode (DFU mode) to burn the uboot to warp7 emmc fails.
    The dfu-util command does not detect anything.
    Are you experienced using DFU in Virtual Box, do you have proof that it works?
  • marcocavallini
    marcocavallini over 8 years ago in reply to griff0417
    Yocto Project 2.2.1 'morty' working perfectly.
         Booting Linux on physical CPU 0x0
         Linux version 4.1.36-4.1-1.0.x-imx-warp7+ga543d1b (koan@quad) (gcc version 6.2.0 (GCC) ) #1 SMP PREEMPT Tue May 23 14:04:53 CEST 2017
         CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
         CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
         Machine model: Warp i.MX7S Board
         Poky (Yocto Project Reference Distro) 2.2.1 imx7s-warp /dev/ttymxc0
         imx7s-warp login: root
    Marco Cavallini - KOAN sas - Italia - Yocto Project Advocate
  • gius_8
    gius_8 over 8 years ago in reply to griff0417
    Hello,
    Thank you for the reply.
    I tried to use bitbakes clean option, but I have the same problems.
    Now I'm trying with debian, if I still have problems I will try with ubuntu 14.04.
    This is the local.conf:
    MACHINE ??= 'imx7s-warp'
    DISTRO ?= 'poky'
    PACKAGE_CLASSES ?= "package_rpm"
    EXTRA_IMAGE_FEATURES = " \
      debug-tweaks \
    USER_CLASSES ?= "buildstats image-mklibs"
    PATCHRESOLVE = "noop"
    BB_DISKMON_DIRS = "\
        STOPTASKS,${TMPDIR},1G,100K \
        STOPTASKS,${DL_DIR},1G,100K \
        STOPTASKS,${SSTATE_DIR},1G,100K \
        STOPTASKS,/tmp,100M,100K \
        ABORT,${TMPDIR},100M,1K \
        ABORT,${DL_DIR},100M,1K \
        ABORT,${SSTATE_DIR},100M,1K \
        ABORT,/tmp,10M,1K"
    PACKAGECONFIG_append_pn-qemu-native = " sdl"
    PACKAGECONFIG_append_pn-nativesdk-qemu = " sdl"
    CONF_VERSION = "1"
    DL_DIR ?= "${BSPDIR}/downloads/"
    ACCEPT_FSL_EULA = "1"
    I'll keep you up-to-date.
    EDIT:
    NO ERRORS with ubuntu 14.04.5 LTS. So you have to just avoid ubuntu 16.10.
    Thanks image
  • griff0417
    griff0417 over 8 years ago in reply to gius_8
    Can you please share your local.conf in <build dir>/conf. Also have you tried using bitbakes clean option? bitbake -c clean core-image-minimal and then bitbake core-image-minimal. I know someone who tried to use Ubuntu 16.04 to build for the WaRP7 and they had issues which ended in them going to 14.04 so maybe your issue lies somewhere in that.
  • gius_8
    Hello,
    I tried to compile the image following this guide, but I can not fix these errors. Can someone help me?
    I use Ubuntu 16.10 with VMWARE.
    Thanks image
    gius@ubuntu:~/warp7_yocto/build$ bitbake core-image-minimal
    WARNING: Host distribution "Ubuntu-16.10" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
    Loading cache: 100% |##################################################################################################################| ETA:  00:00:00
    Loaded 2199 entries from dependency cache.
    NOTE: Resolving any missing task queue dependencies
    Build Configuration:
    BB_VERSION        = "1.30.0"
    BUILD_SYS         = "x86_64-linux"
    NATIVELSBSTRING   = "universal"
    TARGET_SYS        = "arm-poky-linux-gnueabi"
    MACHINE           = "imx7s-warp"
    DISTRO            = "poky"
    DISTRO_VERSION    = "2.1.2"
    TUNE_FEATURES     = "arm armv7ve vfp thumb neon       callconvention-hard       cortexa7"
    TARGET_FPU        = "hard"
    meta
    meta-poky         = "HEAD:b4df9df4624a300923a5dfc5a8f7157bef145a2a"
    meta-oe
    meta-multimedia   = "HEAD:55c8a76da5dc099a7bc3838495c672140cedb78e"
    meta-fsl-arm      = "HEAD:e2254e7b2ded0c2b66b1226f879b3a6d52037b2d"
    meta-fsl-arm-extra = "HEAD:2c28e636ec15c2cfd49bc9cebe0bbbcfde95bc7b"
    meta-fsl-demos    = "HEAD:a165068f8a0d1cf29aabe4b4053f28be1c2aa492"
    NOTE: Preparing RunQueue
    NOTE: Executing SetScene Tasks
    NOTE: Executing RunQueue Tasks
    No currently running tasks (245 of 2066)
    No real function for mknod: /home/gius/warp7_yocto/build/tmp/sysroots/x86_64-linux/usr/bin/../lib/pseudo/lib64/libpseudo.so: undefined symbol: mknod
    No real function for mknodat: /home/gius/warp7_yocto/build/tmp/sysroots/x86_64-linux/usr/bin/../lib/pseudo/lib64/libpseudo.so: undefined symbol: mknodat
    No real function for mknodat: /home/gius/warp7_yocto/build/tmp/sysroots/x86_64-linux/usr/bin/../lib/pseudo/lib64/libpseudo.so: undefined symbol: mknodaWARNING: core-image-minimal-1.0-r0 do_rootfs: No not found in the base feeds (imx7s_warp cortexa7t2hf-neon-mx7d cortexa7hf-neon-mx7d cortexa7t2hf-neon cortexa7t2hf-vfp cortexa7hf-neon cortexa7hf-vfp armv7vet2hf-neon armv7vehf-neon armv7vet2hf-vfp armv7vehf-vfp armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
    WARNING: core-image-minimal-1.0-r0 do_rootfs: real not found in the base feeds (imx7s_warp cortexa7t2hf-neon-mx7d cortexa7hf-neon-mx7d cortexa7t2hf-neon cortexa7t2hf-vfp cortexa7hf-neon cortexa7hf-vfp armv7vet2hf-neon armv7vehf-neon armv7vet2hf-vfp armv7vehf-vfp armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
    WARNING: core-image-minimal-1.0-r0 do_rootfs: function not found in the base feeds (imx7s_warp cortexa7t2hf-neon-mx7d cortexa7hf-neon-mx7d cortexa7t2hf-neon cortexa7t2hf-vfp cortexa7hf-neon cortexa7hf-vfp armv7vet2hf-neon armv7vehf-neon armv7vet2hf-vfp armv7vehf-vfp armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
    WARNING: core-image-minimal-1.0-r0 do_rootfs: for not found in the base feeds (imx7s_warp cortexa7t2hf-neon-mx7d cortexa7hf-neon-mx7d cortexa7t2hf-neon cortexa7t2hf-vfp cortexa7hf-neon cortexa7hf-vfp armv7vet2hf-neon armv7vehf-neon armv7vet2hf-vfp armv7vehf-vfp armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
    WARNING: core-image-minimal-1.0-r0 do_rootfs: mknod: not found in the base feeds (imx7s_warp cortexa7t2hf-neon-mx7d cortexa7hf-neon-mx7d cortexa7t2hf-neon cortexa7t2hf-vfp cortexa7hf-neon cortexa7hf-vfp armv7vet2hf-neon armv7vehf-neon armv7vet2hf-vfp armv7vehf-vfp armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
    WARNING: core-image-minimal-1.0-r0 do_rootfs: /home/gius/warp7_yocto/build/tmp/sysroots/x86_64-linux/usr/bin/../lib/pseudo/lib64/libpseudo.so: not found in the base feeds (imx7s_warp cortexa7t2hf-neon-mx7d cortexa7hf-neon-mx7d cortexa7t2hf-neon cortexa7t2hf-vfp cortexa7hf-neon cortexa7hf-vfp armv7vet2hf-neon armv7vehf-neon armv7vet2hf-vfp armv7vehf-vfp armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
    WARNING: core-image-minimal-1.0-r0 do_rootfs: undefined not found in the base feeds (imx7s_warp cortexa7t2hf-neon-mx7d cortexa7hf-neon-mx7d cortexa7t2hf-neon cortexa7t2hf-vfp cortexa7hf-neon cortexa7hf-vfp armv7vet2hf-neon armv7vehf-neon armv7vet2hf-vfp armv7vehf-vfp armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
    WARNING: core-image-minimal-1.0-r0 do_rootfs: symbol: not found in the base feeds (imx7s_warp cortexa7t2hf-neon-mx7d cortexa7hf-neon-mx7d cortexa7t2hf-neon cortexa7t2hf-vfp cortexa7hf-neon cortexa7hf-vfp armv7vet2hf-neon armv7vehf-neon armv7vet2hf-vfp armv7vehf-vfp armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
    WARNING: core-image-minimal-1.0-r0 do_rootfs: mknod not found in the base feeds (imx7s_warp cortexa7t2hf-neon-mx7d cortexa7hf-neon-mx7d cortexa7t2hf-neon cortexa7t2hf-vfp cortexa7hf-neon cortexa7hf-vfp armv7vet2hf-neon armv7vehf-neon armv7vet2hf-vfp armv7vehf-vfp armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
    WARNING: core-image-minimal-1.0-r0 do_rootfs: mknodat: not found in the base feeds (imx7s_warp cortexa7t2hf-neon-mx7d cortexa7hf-neon-mx7d cortexa7t2hf-neon cortexa7t2hf-vfp cortexa7hf-neon cortexa7hf-vfp armv7vet2hf-neon armv7vehf-neon armv7vet2hf-vfp armv7vehf-vfp armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
    WARNING: core-image-minimal-1.0-r0 do_rootfs: mknodat not found in the base feeds (imx7s_warp cortexa7t2hf-neon-mx7d cortexa7hf-neon-mx7d cortexa7t2hf-neon cortexa7t2hf-vfp cortexa7hf-neon cortexa7hf-vfp armv7vet2hf-neon armv7vehf-neon armv7vet2hf-vfp armv7vehf-vfp armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
    ERROR: core-image-minimal-1.0-r0 do_rootfs: Unable to install packages. Command '/home/gius/warp7_yocto/build/tmp/sysroots/x86_64-linux/usr/bin/smart --log-level=warning --data-dir=/home/gius/warp7_yocto/build/tmp/work/imx7s_warp-poky-linux-gnueabi/core-image-minimal/1.0-r0/rootfs/var/lib/smart install --attempt -y ' returned 1:
    error: no package(s) given
    ERROR: core-image-minimal-1.0-r0 do_rootfs: Function failed: do_rootfs
    ERROR: Logfile of failure stored in: /home/gius/warp7_yocto/build/tmp/work/imx7s_warp-poky-linux-gnueabi/core-image-minimal/1.0-r0/temp/log.do_rootfs.47995
    ERROR: Task 9 (/home/gius/warp7_yocto/sources/poky/meta/recipes-core/images/core-image-minimal.bb, do_rootfs) failed with exit code '1'
    NOTE: Tasks Summary: Attempted 1766 tasks of which 391 didn't need to be rerun and 1 failed.
    Waiting for 0 running tasks to finish:
    Summary: 1 task failed:
    Summary: There were 37 WARNING messages shown.
    Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
