Technical Library
  • Technical Library
Technical Library
Documents Freescale: MPC5668GKITJ Evaluation Kit for MPC5668G/E
  • Author Author: atomar
  • Date Created: 19 Jul 2012 9:07 AM Date Created
  • Last Updated Last Updated: 27 Oct 2013 5:37 AM
  • Views 1013 views
Buy NowDevelopment ToolsTechnical DocumentsVideoFeaturesKit Contents
Kit Overview
The Evaluation Kit MPC5668GKIT built on Dual core Power ArchitectureRegistered technology which uses 32-bit MPC5668G MCU, It connects at one single point all the possible communication protocols you can find in a car. The dual-core architecture provides the performance throughput you need to maintain real-time operation backed-up by a strong third-party ecosystem support.
The Qorivva MPC56xx family of 32-bit microcontrollers built on Power ArchitectureRegistered Technology, is designed for engine management applications, body control, gateway, safety, chassis and driver information applications. The Qorivva MPC56xx and MPC55xx families offer significant benefits to automotive designers:
  • Software and hardware compatibility from low to high end.
  • Scalability among different core versions and product features
  • Embedded flash experience implemented in a high-density, floating-gate technology
  • Unmatched efficiency-parallel processing in conjunction with sophisticated peripheral sets leverages Power Architecture tools and software ecosystem
  • Designed to assist meeting present and future emmission regulations
Key Applications: Automotive - Central Body Controllers, Automotive Gateways, Battery State of Health Monitoring, Battery Monitoring Central Gateway / In-Vehicle Networking  and Body Electronics .
imageFreescale Development KitsimageFreescale Development Tools
Development Tools
Software Development Tools:
Tool TypeSupplierMPNSupported   FamilyDescription
IDEFreescaleCodeWarriorAll Freescale MCU's
Freescale's software and development solutions take you beyond the silicon, helping to bring your embedded applications to life.  Learn More
RTOSFreescaleMQXColdFire / HC08 / HC12 / ARM / S08 / RS08 / Power Arch.
The Freescale MQX Real-Time Operating System (RTOS) provides real-time performance within a small, configurable footprint. This RTOS is designed to allow you to configure and   balance code size with performance requirements. Learn More
RTOSMicriumuC/OS   IIIColdFire / HC08 / HC12 / ARM / S08 / RS08 / Power Arch.
μC/OS-III is Micrium’s newest RTOS, designed for developers who need to save time on their current and next embedded sytem projects. Using a commercial real-time   kernel such as μC/OS-III provides a solid foundation and framework to the design engineer dealing with the growing complexity of embedded designs.  Learn   More
Hardware Development Tools:
Debuggers, Emulators & JTAG ToolsFreescaleUSBMLPPCBDMUSBMLPPCBDMPower ArchitectureUSB Power Architecture BDM Multilink
Back to top
Technical Documents
Learning Center
TypeDescription
User GuideFreescale: Quick Start Guide for MPC5668GKITJ Dev Kit
User ManualFreescale: User Manual for Guide for MPC5668GKITJ Dev Kit
DatasheetFreescale: Datasheet for MPC5668x Microcontroller
Application NoteFreescale: Application Note for MPC56xx C90FL Flash Recovery
Application NoteFreescale: Application Note for System Integration Unit Lite Pin Multiplexing
Application NoteFreescale: Application Note for Qorivva MPC56xx Flash Programming Through Nexus/JTAG
Application NoteFreescale: Application Note for MPC5668x Family Demonstration Lab Training
Design Elements
TypeDescription
SchematicFreescale: Schamatics File for Guide for MPC5668GKITJ Dev Kit
Application LibraryFreescale: Software Code for MPC5668x Family Demonstration Lab Training
Back to top
Video
Video1Video2
This video is unavailable.
Back to top
Kit Features
  • MCU Socket supporting the 208BGA production package and the 256BGA development package
  • Single 12-14V external power supply input with on-board regulators to provide all of the necessary EVB and MCU voltages
  • Flexible MCU clocking options
  • Standard 14-pin ONCE debug connector and 38-pin MICTOR Nexus connectors
  • Ethernet signals routed to a National Semiconductor physical interface and Pulsejack RJ45 connector with integrated magnetics
  • Supports all automotive communication protocols currently available
  • Optimized for communication data management:
    • 592 KB embedded RAM, split into two blocks to allow concurrent accesses by bus masters
    • Additional e200z0 core to pre-process incoming communication data from high-speed networks,such as FlexRayTM and Ethernet
Back to top
Kit Contents
The Freescale's MPC5668GKITJ is Supplied with below contents:
  • MPC5668GKITJ Evaluation Kit
  • Power supply 12VDC 5A, with US cord and adapters EUR, UK, AUST. PSE approved
  • Cable: DB9 M/F, RS-232RS-232 serial, 6 ft
  • Cable, 6ft. USB2.0 A-M to B-M
  • P&E PowerPC Nexus Multilink for Freescale MPC55XX microcontrollers, RoHS compliant
  • Freescale warranty card
  • MPC5668GKITJ Quick Start
  • MPC5668EVB hardware doc DV
Back to top
  • mpc5668evb
  • flexraytm
  • freescale
  • e200z0
  • mpc5668gkit
  • mpc5668gkitj
  • evaluation_kit
  • mpc55xx
  • mpc5668g
  • mpc56xx
  • mpc5668g/e
