Technical Library
  • Technical Library
Technical Library
Documents Freescale: TWR-S08MM128-KIT MC9S08MM Medical Development Module
  • Author Author: atomar
  • Date Created: 20 Jul 2012 11:49 AM Date Created
  • Last Updated Last Updated: 18 Jan 2013 4:50 AM
  • Views 1640 views
Buy NowBuy NowDevelopment ToolsTechnical DocumentsVideoFeaturesKit Contents
Kit Overview
The Freescale's TWR-S08MM128-KITTWR-S08MM128-KIT is a development module for the 9S08MM128 Flexis 8-bit microcontrollers that supports external communications interfaces and an open connector for an MED-EKGMED-EKG development board. It is designed to aid in the evaluation and prototyping of medical applications and includes an electrocardiograph sensor (MED-EKGMED-EKG) as part of the evaluation system.
The TWR-S08MM128TWR-S08MM128 operates as a standalone debug tool and can also be combined and used as part of the modular Tower System development platform, a modular development platform that enables rapid prototyping and tool re-use through reconfigurable hardware. Take your design to the next level and begin constructing your Tower System today.
The S08MM is the 8-bit series of the Flexis MM family. It provides ultra low-power operation, USB connectivity and integrated analogs (OPAMPs, TRIAMPs, DAC and ADC)—all in one cost-effective, 8-bit microcontroller. S08MM devices are ideal for portable medical applications or any other application requiring a significant amount of precision analog such as instrumentation and industrial control.
Ordering Infromation:
MPNDescription
TWR-S08MM128TWR-S08MM128Freescale S08MM128 MCU Tower Module Only
KIT - Freescale S08MM128 MCU Tower Module with Tower Serial Module ( TWR-SERTWR-SER ), Tower Elevator Module (TWR-ELEVTWR-ELEV ) and Electrocardiograph development kit (MED-EKGMED-EKG )
Key Applications: Portable Medical Applications
imageFreescale Development KitsimageFreescale Development Tools
Development Tools
Software Development Tools:
IDEFreescaleCodeWarriorAll Freescale MCU's
Freescale's software and development solutions take you beyond the silicon, helping to bring your embedded applications to life.  Learn More
RTOSFreescaleMQXColdFire / HC08 / HC12 / ARM / S08 / RS08 / PowerPC
The Freescale MQX Real-Time Operating System (RTOS) provides real-time performance within a small, configurable footprint. This RTOS is designed to allow you to configure and balance code size with performance requirements. Learn More
Hardware Development Tools:
Debuggers, Emulators & JTAG ToolsFreescaleU-MULTILINKU-MULTILINKHC08 / HCS08 / HCS12 / ColdFire / Qorivva MPC55xx/56xx / KinetisP&E USB Multilink Universal debug and programming interface for HCS08, HC(S)12(X), ColdFire, Qorivva MPC55xx/56xx, and Kinetis
Debuggers, Emulators & JTAG ToolsFreescaleUSBMULTILINKBDMEUSBMULTILINKBDMEHCS08 / RS08 / HCS12USB BDM Interface cable for the 68HC(S)12(X) and 68HCS08 and 68RS08 and ColdFire V1
Debuggers, Emulators & JTAG ToolsFreescaleUSBMULTILINK08EUSBMULTILINK08EHC08In-circuit emulation, debugging and programming for 68HC08 Flash MCUs
Debugger / ProgrammerFreescaleM68CYCLONEPROEM68CYCLONEPROEHC08 / HS08 / RS08 / HCS12Hardware Debug Interface and Stand-Alone Programmer for HC08, HCS08, RS08, ColdFire V1, and HC(S)12(X)
Back to top
Technical Documents
Learning Center
TypeDescription
User GuideFreescale: MED-EKGUG_-User Manual for evalboard MED-EKG_
User GuideFreescale: S08MM128QSG-Quick Start Guide for TWR-S08MM128-KIT
User ManualFreescale: TWR-MCF51MMUM-User Manual for TWR-MCF51MM
Product BriefFreescale: Freescale Tower System Fact Sheet(Rev 11)
Product BriefFreescale: MC9S08MM128FS-MC9S08MM128 Fact Sheet
Product BriefFreescale: Tower System TWR-K53N512 Fact Sheet
Product BriefFreescale: TWRFS-Freescale Tower System Fact Sheet
Application NoteFreescale: AN4116-Using the MM/JE Flexis Families for Infrared Communication
Application NoteFreescale: Application Note for Glucose Meter Fundamentals and Design
Application NoteFreescale: AN4223-Connecting Low-Cost External Electrodes to MED-EKG
Selection GuideFreescale Semiconductor: Selection Guide for FREESCALE Tower System Development Tools
TutorialsFreescale: S08MMMELAB1-LAB1 for TWR-S08MM128
TutorialsFreescale: S08MM128LAB2-LAB2 for TWR-S08MM128
TutorialsFreescale: S08MM128LAB3-LAB3 for TWR-S08MM128
TutorialsFreescale: S08MM128LAB4-LAB4 for TWR-S08MM128
TutorialsFreescale: S08MM128LAB5-LAB5 for TWR-S08MM128
Design Elements
TypeDescription
Application LibraryFreescale: Software Code for Glucose Meter Fundamentals and Design
Back to top
Video
Video 1Video 2Video 3
This video is unavailable.
Back to top
Kit Features
The TWR-S08MM128-KITTWR-S08MM128-KIT Features
  • Integrated open-source BDM debugging tool
  • Small form factor (59mm x 90mm)
  • Supports external communications interfaces
  • Includes power regulation circuitry with standardized bus
  • Two 80-pin connectors on the outside to support debugging or expansion to LCD module
  • RS232, RS485, CAN , USB
  • Open connector for MED-EKGMED-EKG development board
  • Low power
  • The TWR-S08MM128TWR-S08MM128 board contains a Flexis MC9S08MM128, an Energy-Efficient Product Solution by Freescale
Features of the MC9S08MM Tower MCU board:
  • Tower compatible processor board
  • Open Source BDM (OSBDM) circuit
  • Analog measurement circuitry
  • 4 LEDs
  • DIP Switches and push buttons for user input
  • Potentiometer
  • MMA7361LMMA7361L three‐axis accelerometer
  • RS232 transceiver and 2x5 pin header
Back to top
Kit Contents
The Freescale's TWR-S08MM128TWR-S08MM128 contains:
  • TWR-S08MM128 board with a 9S08MM128 8-bit MCU
  • Necessary cables
  • DVD with lab tutorials, software, training and collateral
  • Quick Start Guide document
The Freescale's TWR-S08MM128-KITTWR-S08MM128-KIT also contains:
  • TWR-SERTWR-SER - Tower System Serial Module
  • TWR-ELEVTWR-ELEV - Tower System Elevator Modules
  • MED-EKGMED-EKG - Electrocardiograph development kit for Tower System
Back to top
  • med-ekg
  • twr-s08mm128
  • mcf51mm
  • freescale
  • 9s08mm128
  • s08mm
  • mc9s08mm128
  • medical_development_module
  • twr-s08mm128-kit
