Technical Library
  • Technical Library
Technical Library
Documents NXP: LPC1830 Based LPC1830-Xplorer Board from NGX (OM13028)
  • Author Author: Oliver
  • Date Created: 8 Aug 2012 7:32 AM Date Created
  • Last Updated Last Updated: 4 Jan 2013 11:10 AM
  • Views 2140 views
Buy NowBuy NowDevelopment ToolsTechnical DocumentsVideoFeaturesKit Contents
Kit Overview
LPC1830-Xplorer (OM13028OM13028) is a breakout board for LPC1830LPC1830 Cortex-M3 based microcontroller. The LPC1830LPC1830 microcontroller has flash and flashless parts. For flashless microcontroller has 200KB SRAM, two 32KB SRAM blocks with separate bus. 64KB ROM containing boot code and on-chip software drivers. 32-bit OTP. For flash microcontroller 1MB dual bank flash, 136KB SRAM, Ethernet MAC, one USB 2.0  Device/Host/OTG interface with DMA support, one USB2.0 Host/Device interaface with DMA, on-chip full-speed PHY and ULPI interface to external high-speed PHY, 4 UARTS with DMA support, 2 C_CAN 2.0B, 2 SSPs, 2 I2C, 2 I2S, LCD controller, 8 GPDMA, up to 164 GPIO, 1 10-bit DAC, 2 10-bit ADCs, and RTC.
LPC1830-Xplorer has been developed in partnership with NGX Technologies. It is a compact and versatile evaluation platform for the NXP's Cortex-M3 based MCUs. NGX's evaluation platforms are generally not tied up to any particular debugger or compiler/IDE. However it is not practical to test and ensure that the solution would work out of box with all the available debuggers and compilers/IDE. As long as the compiler supports the particular MCU and the debugger supports the standard debug interfaces like the SWD/JTAG you can use this platform with any tool. The board is supported by extensive sample examples allowing you to focus on the application development.
Key Applications: Industrial, RFID readers, Consumer, e-Metering, White goods,etc.
imageOther NXP Development KitsimageNXP Overview
Development Tools
Software Development Tools:
Tool TypeSupplierMPNSupported   FamilyDescription
IDEARMKeil MDK-ARMARM CortexTm-M  / Cortex-R4 / ARM7Tm / ARM9TmThe MDK-ARM is a complete software development environment for CortexTm-M, Cortex-R4, ARM7Tm and ARM9Tm processor-based devices. MDK-ARM is specifically designed for microcontroller applications, it is easy to learn and use, yet powerful enough for the most demanding embedded applications. Learn More
Hardware Development Tools:
Emulator / Debugger / ProgrammerARMULINK2ULINK2ARM CortexTm-M  / ARM7Tm / ARM9TmULINK2 Debug Adapter
Emulator / Debugger / ProgrammerARMULINKProULINKProARM CortexTm-M  / ARM7Tm / ARM9TmULINKpro Debug and Trace Unit
EmulatorSeggerJ-LinkJ-LinkARM CortexTm-M  / Cortex-R4 / ARM7Tm / ARM9TmJTAG/SWD Emulator with USB interface
ProgrammerSeggerFlasher ARMFlasher ARMARM CortexTm-M  / Cortex-R4 / ARM7Tm / ARM9TmFlash Programmer for ARM and Cortex cores
Back to top
Technical Documents
Learning Center
TypeDescription
User GuideNXP: LPC1830-Xplorer Quick Start Guide
User ManualNXP: LPC18xx ARM Cortex-M3 microcontroller
User ManualNXP: LPC1830-Xplorer User Manual for KEIL MDK ARM with ULINK2/ME
User ManualNXP: LPC1830-Xplorer User Manual for LPC-Xpresso with NXP LPC-Link
Product BriefNXP: Cortex-M microcontroller brochure
DatasheetNXP: LPC18xx Datasheet
Revision NoteNXP: Errata sheet 1 - LPC1850, LPC1830, LPC1820, LPC1810
Revision NoteNXP: Errata sheet 2 - LPC1850, LPC1830, LPC1820, LPC1810
Design Elements
TypeDescription
SchematicsNXP: LPC1830-Xplorer Schematics
Reference DesignNXP: Using the SCT in LPCXpresso, Keil, and IAR
Back to top
Video
This video is unavailable.
Back to top
Kit Features
  • Controller: LPC1830LPC1830, 100 pin BGA
  • PCB: 4-layer (86mm x 40mm, RoHS Compliant)
  • Two LEDs
  • One user switch and one reset switch
  • Boot select switch
  • 32Mb Quad flash
  • On board crystals for controller, RTC and audio codec
  • On board Ethernet PHY, 50 MHz Oscillator and RJ45 connector with magnetics
  • On board audio codec and audio jacks
  • On board USB host power switch
  • On board Micro SD card slot
  • Two USB ports, one HS (High speed) port and one FS (Full Speed) port
  • 10-pin cortex debug header
  • Unused I/Os brought to a header
Back to top
Kit Contents
The NXP OM13028OM13028 is supplied with below contents:
  • LPC1830-Xplorer Evaluation Board
  • 1 meter USB AM to Micro B
  • 0.2 meter USB AF to Micro B
Back to top
  • lpc1830
  • lpc1830-xplorer
  • om13028
