Technical Library
  • Technical Library
Technical Library
Documents Embest: SBC8600B Single Board Computer based on TI AM3359 Sitara ARM Cortex-A8 MPU
  • Author Author: atomar
  • Date Created: 3 Oct 2013 4:34 AM Date Created
  • Last Updated Last Updated: 5 Mar 2014 10:42 AM
  • Views 2312 views
BUY NOWBUY NOWDevelopment ToolsTechnical DocumentsVideoFeaturesKit ContentsAdd-on Modules
Overview
The SBC8600BSBC8600B  is an excellent high-performance single board computer based on Texas Instruments’ 720MHz Sitara AM3359AM3359 ARM Cortex-A8 processor. It is driven by a tiny core board (Mini8600BMini8600B) which has integrated AM3359 processor, DDR3, NAND Flash and extends most of the features and signals of the AM3359 CPU through expansion pins. The core board is combined with a carrier board to extend and provide more features through headers and connectors.
The SBC8600BSBC8600B  board comes with a rich set of communication peripherals including six serial ports (2*RS232, 3*TTL, 1*RS485), two 10/100/1000 Mbps Ethernet ports, two USB Hosts, USB OTG and CAN interfaces, providing an ideal solution for applications requiring remote control and monitoring or mass connectivity. The board also has an LCD and a touch screen interface, Audio input and output ports, RTC, Buzzer and many other interfaces. Embest offers 4.3 inch and 7 inch LCD panels as optional extras which also contain a 4-wire resistive touch screen. The SBC8600B is a ready-to-run platform with support for Linux 3.2.0, Android 2.3 and WinCE 7 operating systems.
The SBC8600BSBC8600B  board is a ready-to-run solution which is provided with a Linux 3.2.0, Android 2.3 and WinCE 7 BSP. One DVD is delivered along with the goods which includes the software driver source code and relative documents to help customer better understand this board and start their initial design. Additionally, Embest offers various optional modules for the SBC8600B which greatly enhance the functions of this board.
The Mini8600BMini8600B processor card is a small form-factor controller board based on TI’s Sitara AM3359 ARM Cortex-A8 processor. The tiny module integrates 2*256MBytes DDR3 SDRAM and 512Mbytes NAND Flash and uses two 0.4mm space 2*40-pin board-to-board male expansion connectors to bring out many hardware peripheral signals and GPIOs from the CPU.
Ordering Information:
MPNDescription
SBC8600BSBC8600B Single Board Computer Only
SBC8600B with 4.3"LCDSBC8600B with 4.3"LCDSBC8600B Single Board Computer with 4.3"LCD
SBC8600B with 7"LCDSBC8600B with 7"LCDSBC8600B Single Board Computer with 7"LCD
Mini8600BMini8600BMini8600B Processor Card (Standalone)
Key Applications: Industrial Automation, Building Automation, Home control, Consumer Electronics, Security and Instrumentation.
imageMore Embest Development KitsimageEmbest CooCox Development Tools
imageKnode Development Kits & Platform Roomimageelement14 Knode
Development Tools
Software Development Tools:
IDETexas InstrumentsCode Composer Studio (CCStudio)TI ARM MCUsCCStudio is an integrated development environment (IDE) for TI embedded processor families. CCStudio comprises a suite of tools used to develop and debug embedded applications. It includes compilers for each of TI's device families, source code editor, project build environment, debugger, profiler, simulators, a real-time operating system and many other features. Learn More
IDEARMDS-5ARM CortexTm-A  / CortexTm-R / ARM9Tm / ARM11Tm
The ARM Development Studio 5 (DS-5) tool enable developers to get the best from their ARM technology-based systems. Whether implementing an ARM processor-based SoC or writing software for an Application Specific Standard Product (ASSP), ARM tools enable you to deliver the best solution with the highest performance and lowest power. Learn More
Hardware Development Tools:
Debuggers, Emulators & JTAG ToolsARMDSTRM-KT-0181ADSTRM-KT-0181AARM7 / ARM9 / ARM11 / Cortex-A / Cortex-R / Cortex-MDSTREAM Debug and Trace Unit
Debuggers, Emulators & JTAG ToolsSeggerJ-LinkJ-LinkARM CortexTm-M  / Cortex-R4 / Cortex-A / ARM7Tm / ARM9TmJTAG/SWD Emulator with USB interface
ProgrammerSeggerFlasher ARMFlasher ARMARM CortexTm-M  / Cortex-R4 / Cortex-A / ARM7Tm / ARM9TmFlash Programmer for ARM and Cortex cores
Back to top
Technical Documents
Learning Center
TypeDescription
User GuideEmbest: User Manual for SBC8600B Single Board Computer
Quick Start GuideEmbest: Quick Start Guide for SBC8600B Single Board Computer
User Guide
Embest: User Guide for Mini8600B Processor Card
DatasheetTexas Instruments: Datasheet for AM335x ARM Cortex-A8 Microprocessors
White PaperTexas Instruments: White Paper for EtherCATRegistered on SitaraTm AM335x ARMRegistered CortexTm-A8 Microprocessors
White PaperTexas Instruments: White Paper for Profibus on AM335x and AM1810 Sitara ARM Microprocessor (Rev. A)
Design Elements
TypeDescription
CAD ModelTexas Instruments: CAD Model for AM3359 (.bxl format file)
Simulation ModelTexas Instruments: AM335x ZCE IBIS Model
Simulation ModelTexas Instruments: AM335x ZCZ IBIS Model (Rev. B)
Simulation ModelTexas Instruments: BSDL Model for AM335x
Back to top
Video
Back to top
Kit Features
Hardware Features
CPU Board (Mini8600BMini8600B for SBC8600B)
  • Processor
    • TI AM3359AM3359 ARM Cortex-A8 microprocessor
      • 720-MHz ARM Cortex-A8 32-bit RISC MPU
      • NEONTm SIMD Coprocessor
      • 32KB/32KB of L1 Instruction/Data Cache with Single-Error Detection (parity)
      • 256KB of L2 Cache with Error Correcting Code (ECC)
      • SGX530 Graphics Engine
      • Programmable Real-Time Unit Subsystem
  • Memory
    • 2*256MByte DDR3 SDRAM
    • 512MByte NAND Flash
  • Expansion Interfaces and Signals Routed to Pins
    • Two 0.4mm space 2*40-pin board-to-board male expansion connectors
      • TFT LCD Interface (support 24-bpp parallel RGB Interface LCD)
      • Two USB 2.0 OTG Ports With Integrated PHY, High-Speed
      • Three inter-integrated circuit (I2C) Bus interfaces
      • Six UART interfaces
      • SPI interface
      • Two 10/100/1000 Mb/s Ethernet MAC (EMAC) with Management Data Input/Output (MDIO) module
      • Multichannel audio serial ports (McASP)
      • 8-channel 12-bit ADC interfaces
      • Two 4-line SD/MMC card interfaces
      • GPMC bus
Expansion Board of SBC8600BSBC8600B
  • Audio/Video Interfaces
    • Audio input interface (3.5mm audio jack)image
    • Two-channel audio output interface (3.5mm audio jack)
    • TFT LCD interface / 4 line Resistive Touch Screen interface (50pin FPC connector)
  • Data Transfer Interfaces
    • Serial port:
      • 3 line Debug serial port, RS232 voltage (UART0 brings out by DB9 connector)
      • 3 line serial ports, RS232 voltage (UART2 brings out by DB9 connector)
      • Three 3 line serial port, TTL voltage (UART3/4/5 brings out by J6 and J7 2.54mm pitch 2*5-pin expansion connectors)
    • USB ports:
      • USB2.0 Host ports with Integrated PHY (High-speed, 480Mbps, USB-A Type)
      • USB2.0 OTG port with Integrated PHY (High-speed, 480Mbps, Mini-USB Type)
    • TF card slot
    • Two Ethernet: 10/100/1000 Mbps, RJ45 connectors (only one Ethernet supported in WinCE)
    • CAN2.0 interface (brings out by 8-pin Phoenix Connector)
    • RS485 interface (brings out by 8-pin Phoenix Connector)
    • GPIOs
  • Input Interfaces and Other Facilities
    • RESET button
    • Two User buttons (MENU and BACK)
    • Power indicator
    • Two User LEDs
    • Buzzer
Mechanical Parameters
  • Dimensions: 95mm x 95mm (expansion board)
  • 60mm x 27mm (CPU board Mini8118)
  • Working Temperature: 0~70 Celsius
  • Humidity Range: 20% ~ 90%
  • Input Voltage: 12V
Software Features
OS
Item
Remark
Linux
BIOS
SPL
(First boot loader)
NAND
MMC/SD
FAT
U-boot
(Second boot loader)
NAND
MMC/SD
FAT
NET
Kernel
Linux-3.2.0
Supports    ROM/CRAM/EXT2/EXT3/FAT/NFS/ JFFS2/UBIFS file systems
Driver
NAND Flash, SDRAM,    Serial port, RTC, Ethernet, TFT LCD, Touch screen, TF card, USB OTG, Audio input/output, LED, Key, CAN, RS485, Power Management (backlight, PWM, ADC)
(provided with source code)
2D/3D (not provided    with source code)
Android
Kernel
Linux-3.1.0
Gingerbread
Driver
NAND Flash, SDRAM,    Serial port, RTC, Ethernet, TFT LCD, Touch screen, TF card, USB OTG, Audio input/output, LED, Key, Power Management (backlight, PWM)
WinCE7
BIOS
X-loader
(First boot loader)
NAND
MMC/SD
FAT
EBOOT
NAND
MMC/SD
FAT
NET
OAL
OAL    module
Boot    parameter
KILT(EMAC)
Serial    debug
REBOOT
Watchdog
RTC
Kernel    profiler
System    timer
Interrupt    controller
MMU
Driver
NAND Flash, SDRAM,    Serial port, RTC, Ethernet, TFT LCD, Touch screen, TF card, USB OTG, Audio input/output, LED, Key, RS485,  Power    Management (backlight)
CAN, 2D/3D (not provided with source code)
Back to top
Kit Contents
The Embest SBC8600BSBC8600B  Single Board Computer supplied with below contents:
  • SBC8600B Board (including CPU board and expansion board)
  • 12V power adapter
  • Crossover serial cable
  • Ethernet cable
  • Product DVD (including user manual, schematic in PDF format, datasheet, Linux 3.2.0, Android 2.3 and WinCE 7 BSP)
  • LCD Options
    • Without LCD
    • With 4.3 inch LCD
    • With 7 inch LCD
Back to top
Add-on Modules
Part NumberDescriptionInterface to BoardLinuxAndroidWinCE
VGA8000VGA8000VGA Module
LCD
Support*Support*Support*
WF8000-UWF8000-U
WiFi Module
USB Host
Support*
Not yet
Not yet
CDMA8000-UCDMA8000-U
3G Module (CDMA2000 standard)
USB Host
Support*
Not yet
Not yet
WCDMA8000-UWCDMA8000-U
3G Module (WCDMA standard)
USB Host
Support*
Not yet
Not yet
CAM8100-UCAM8100-U
Digital Camera Module
USB Host
Support*
Not yet
Not yet
LVDS8000LVDS8000
RGB-to-LVDS Module
LCD
Support*
Support*
Support*
* = Provided with Source Code
Back to top
  • cortex-a8
  • wcdma8000-u
  • sbc8600b
  • vga8000
  • am3359
  • wf8000-u
  • cdma8000-u
  • mini8600b
  • cam8100-u
  • arm
  • lvds8000
  • embest
