Technical Library
  • Technical Library
Technical Library
Documents Texas Instruments: TMDXDOCKH52C1 - H52C1 Concerto Experimenter Kit
  • Author Author: sangeetack
  • Date Created: 30 Nov 2011 10:03 AM Date Created
  • Last Updated Last Updated: 10 Jan 2013 11:08 AM
  • Views 1009 views
Buy Now Development ToolsTechnical DocumentsVideoFeaturesKit Contents
Kit Overview
The C2000 Experimenter Kits from Texas Instruments are ideal products for initial device exploration and testing. The Concerto H52C1 Experimenter Kit has a docking station(TMDXDOCKH52C1 ) that features access to all controlCARD (TMDXCNCDH52C1 )signals, breadboard areas and RS-232 and JTAG connectors. Each kit contains a H52C1 controlCARD. The controlCARD is a complete board level module that utilizes and industry-standard DIMM form factor to provide a low-profiles single-board controller solution. Kit is complete with Code Composer StudioTM IDE v4 and USB cable.
The Concerto family is a multi-core system-on-chip microcontroller (MCU) with independent communication and real-time control subsystems. The F28M35x is the first series in the Concerto family.The communications subsystem is based on the industry-standard 32-bit ARM CortexTm-M3 CPU and features a wide variety of communication peripherals, including Ethernet 1588, USB OTG with PHY, CAN, UART, SSI, I2C, and an external interface.
The real-time control subsystem is based on TI’s industry-leading proprietary 32-bit C28x Floating-Point CPU and features the most flexible and high-precision control peripherals, including ePWMs with fault protection, and encoders and captures—all as implemented by TI’s C2000 Piccolo and Delfino families.
Ordering Information:
MPN
Description
TMDXCNCDH52C1 H52C1 Concerto controlCARD
TMDXDOCKH52C1 H52C1 Concerto Experimenter Kit
Key Applications: Industrial Automation,Solar and Renewable energy,Smart grid,Server Farm,Digital Power
imageTexas Instruments Development KitsimageTexas Instruments Development Tools
Development Tools
Software Development Tools:
IDETexas InstrumentsCode Composer Studio (CCStudio)TI ARM MCUsCCStudio is an integrated development environment (IDE) for TI embedded   processor families. CCStudio comprises a suite of tools used to develop and debug embedded applications. It includes   compilers for each of TI's device families, source code editor, project build environment, debugger, profiler, simulators,   real-time operating system and many other features. Learn More
IDEARMDS-5ARM CortexTm-A  / CortexTm-R / ARM9Tm / ARM11Tm
The ARM Development Studio 5 (DS-5) tool enable developers to get the best from their ARM technology-based systems. Whether implementing an ARM processor-based SoC or writing software for an Application Specific Standard Product (ASSP), ARM tools enable you to deliver the best solution with the highest performance and lowest power. Learn More
RTOSMicriumuC/OS IIIColdFire / HC08 / HC12 / ARM / S08 / RS08 / PowerPC
μC/OS-III is Micrium’s newest RTOS, designed for developers who need to save time on their current and next embedded sytem projects. Using a commercial real-time kernel such as μC/OS-III provides a solid foundation and framework to the design engineer dealing with the growing complexity of embedded designs.  Learn More
RTOSSeggerembOSColdFire / HC08 / HC12 / ARM / S08 / RS08
SEGGER embOS (Real Time Operating System) follows strict, yet efficient coding and documentation standards. embOS is a priority-controlled real time operating system, designed to be used as foundation for the development of embedded real-time applications.  Learn More
Hardware Development Tools:
Tool   TypeSupplierMPNSupported   FamilyDescription
Emulator / Debugger / ProgrammerARMULINK2 ARM CortexTm-M  / ARM7Tm / ARM9TmULINK2 Debug Adapter
Emulator / Debugger / ProgrammerARMULINKPro ARM CortexTm-M  / ARM7Tm / ARM9TmULINKpro Debug and Trace Unit
EmulatorSeggerJ-Link ARM CortexTm-M  / Cortex-R4 / Cortex-A / ARM7Tm / ARM9TmJTAG/SWD Emulator with USB interface
ProgrammerSeggerFlasher ARM ARM CortexTm-M  / Cortex-R4 / Cortex-A / ARM7Tm / ARM9TmFlash Programmer for ARM and Cortex cores
Debuggers, Emulators & JTAG ToolsTexas InstrumentsXDS100V2 JTAG C2000 / C5000 / C6000JTAG Emulator
Back to top
Technical Documents
Learning Center
TypeDescription
DatasheetTexas Insruments: Datasheet for C2000 Microcontrollers (Rev. B)
WhitepaperTexas Insruments: White paper on Performance without Compromise for Implementing Real-time Control and Communication
Product BriefTexas Insruments: Product Brief for C2000 Concerto Microcontrollers(Rev. A)
Product BriefTexas Insruments: Product Brief for C2000 Microcontrollers Brochure (Rev. L)
User GuideTexas Insruments: Selection Guide for TI embedded processors based on ARM   technology
Design Elements
TypeDescription
Application LibraryTexas Insruments: Software code for C2000 Experimenter Kit Application Software
Application LibraryTexas Insruments: Software code for C280x, C2801x C/C++ Header Files and Peripheral   Examples
Application LibraryTexas Insruments: Software code for C2000 ACDC Developer's Kit Application Software
Back to top
Video
Back to top
Kit Features
TMDXDOCKH52C1 :
  • F28M35H52C1 microcontroller based controlCARD.
  • Docking station with access to all controlCARD signals
  • No external emulator required
  • Fully powered from USB connection, no external power supply needed
  • Code Composer StudioTm IDE v4 included
  • Full open source software examples and hardware files for download in controlSUITE.
TMDXCNCDH52C1 :
  • Isolated USB JTAG Interface (XDS100v2)
  • Micro-USB, Ethernet, and MicroSD communication interfaces
  • Standard 100-pin DIMM Interface
  • Analog I/O, digital I/O and JTAG signals at DIMM interface
  • Single 5V power rail for full operation
Back to top
Kit Contents
TMDXDOCKH52C1:
TMDXCNCDH52C1 :
Back to top
  • cortex_m3
  • arm_cortex_m3
  • digital
  • smart_grid
  • hybrid_electric
  • control
  • c2000
  • renewable
  • texas_instruments
  • arm
  • power
  • energy
  • motor
  • solar
  • concerto
