EAGLE Support (Deutsch) using mouse as measuring tape
  • Subscribers 187 subscribers
  • Views 808 views
on creating new packages from existing parts it's somehow tricky to get all
pads and holes on the right coordinates - especially on items that use
different grids for the pads.
So I thought about a measuring aid to control the package layout.
Such a measuring aid could work that kind, that one uses a mouse-click to
fix the virtual measuring tape. Then on moving the mouse away, the distance
from that point is shown (both units, inch and mm).
The measuring could support 2 different modes, an so called ortho-mode,
where only the major difference between the coordinates is displayed
(either x2-x1 or y2-y1) and a free mode, where the right distance in any
direction is calculated and shown.
The measuring mode could be terminated with a mouse-click or i.e. by hitting
esc-key...
kind regards
Reinhard Mantey
    Oliver Betz wrote:
    Joerg wrote:
    Old trick, works also with Eagle: Temporarily move the part so that the
    origin of your desired measurements falls onto 0.0/0.0 and switch the
    grid to the precision you need. Now your cursor always shows the
    distance. When done move it back so it is centered again.
    What is the benefit over "MARK" mentioned by Joern three weeks ago?
    There are many ways to do that in Eagle, just wanted to point out the
    one that has worked for me. When you close the library and move on to do
    something else or work on another library, then come back, your mark
    point is gone. A part that has been temporarily moved to provide a
    convenient pivot will retain its temporary position until you manually
    center it again.
    Regards, Joerg
    "gmail" domain blocked because of excessive spam.
    Use another domain or send PM.
    Oliver
    Reinhard Mantey wrote:
    esc-key...
    Regards, Joerg
    Reinhard Mantey schrieb:
    esc-key...
    kind regards
    Reinhard Mantey
    Try MARK
    Gruß
    Jörn
