EAGLE Support (Deutsch) "Automatically save project file"
  • Subscribers 189 subscribers
  • Views 655 views
anweid
anweid over 17 years ago
This might be a bug, or it might be by design, but at least I do not
understand it: In EAGLE 5.6.1 (Windows), the control panel features a
dialog with the check box "Automatically save project file", which is
checked by default.
One CAN uncheck it, but
  1. the next time a project is opened, it's checked again, and
  2. even if no project is opened, the next time EAGLE is started,
     it's checked again.
So what does this strange check box do, and what good is it to uncheck
it, if under lots of circumstances it's automatically checked again
shortly after one chose to explicitly uncheck it?
Andreas Weidner
  • anweid
    Klaus Schmidinger schrieb:
    Looks like there is some explanatory text missing in the online help.
    I have added this now to "Help/Control Panel/Backup/Automatically save project file":
    Yes, please - thanks. That clears things up for me. I still think it's a
    bit strange, but if I can access that information somewhere, that's OK...
    Andreas Weidner
  • kcadsoft
    kcadsoft over 17 years ago
    checked by default.
        it's checked again.
      Note that if you uncheck this option while you have a project open, this
      project will not be saved when you close it, and thus this setting will not
      be stored in the project's eagle.epf file. This means that the next time you
      open the project, this option will be checked again. If you want this option
      to remain unchecked for the current project, you need to manually select
      "File/Save all" from the pulldown menu after unchecking this option.
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
