EAGLE User Chat (English) "stamping" repetitive circuit. possible?
  • Views 499 views
Hello, I was designing a schematic that had a repetitive pattern (two
transistors and 5 resistors) used in 6 outputs.
I designed once and cut/pasted the others, fine with that but...
I was thinking if is possible to draw a small circuit inside a box, in
my schematic, name it like "power output" and just "stamp" (draw) a
small box where needed but when I opened the board designer all the
parts belonging to these box should appear.
Is it possible?
TIA
orlando
    Is it possible?
    TIA
    orlando
    Hi Jose,
    It sounds to me that your looking for a hiearchal structure. This means
    that once you have a building block circuit made then you stick it in a
    black box and treat the circuit as a unit.
    This type of organization is currently not possible however, it is on
    the to do list of the Cadsoft Development Team and we hope that at some
    point it will be implemented for task like this one.
    Hope this helps,
    Best Regards,
    Jorge Garcia
    Cadsoft Computer
    "Jose Orlando" <jorlando@remove.nospam.uol.com.br> wrote in message
    news:hum4vd$v9o$1@cheetah.cadsoft.de...
    I was thinking if is possible to draw a small circuit inside a box, in my
    schematic, name it like "power output" and just "stamp" (draw) a small box
    where needed but when I opened the board designer all the parts belonging
    Is it possible?
    TIA
    orlando
    if you mean duplicating, now it's possible, have a look at:
    eagle home page --> download --> ulps --> duplicating_v45.zip
    hope this could help
    Maurice
    Is it possible?
    TIA
    orlando
    Probably you could try out by creating a new library. For, the symbol
    you could draw the circuit or just a box which will help you recognize
    what part it is. And for the package, draw footprints of the two
    transistors and the 5 resistors you intend to use and combine all to
    make one package. So, on the schematic when you place the symbol, the
    entire footprint would show up on the board.
    Hope this helps.
    Best Regards,
    Jaya
