EAGLE User Chat (English) Is it possible to import Protel symbo ls and footprints into EAGLE
  • Replies 7 replies
  • Views 750 views
    LogicSwap is working with Stratford Digital to provide Import and Export
    services to the EAGLE community. We currently can support Import to /
    Export from EAGLE and the following tools:
    PCAD, Protel, Altium Designer, Orcad Layout, Allegro, Boardstation, PADS,
    Expedition, CADSTAR, Visula & CR-5000,
    Contact Mike Wilson at 215-368-5817 to discuss your needs.
    mailto:mikewilsonpcb@comcast.net
    Nihao!
    Unfortunately, I did not have the information for Protel file format,
    either. I guess this issue is temporarily insoluble.
    I recall that Protel used to have an ASCII format for its pcbs.   I have
    no idea about what Altium supports.  A quick search on Google indicated
    that Protel PCB and Schematic libraries can be saved in an ASCII format.
      With sufficient knowledge of the Protel ASCII format (from their file
    format specifcation) and Eagle scripts it might be possible to write a
    conversion tool to create scripts to import in to Eagle libraries.
    There are ULPs in the download area of the Cadsoft website to export
    from Eagle to Protel e.g. export-protelpcb.ulp.  Although this is the
    opposite direction to what you want it may provide some hints for
    writing a converter.
    Regards
    Neil
    Maybe you ask for help in a more generic cad newsgroup. Perhaps someone
    (some Protel user) can provide more information about how to obtain
    anything out of Protel files. However, maybe you'd need the Protel
    software then - which wouldn't help you either, unless the required
    export functions also work with demo versions... :-\
    Sorry,
    Tilmann
    I think this issue is more critical for EAGLE users than the users of
    Protel. I can find the Protel OrCAD symbols and footprints of Analog
    Devices components in their web site but the corresponding parts for
    EAGLE were postponed for at least more than two years. I guess the
    better way for me is to find a converter in EAGLE user community instead
    of other communities.
    OK, but then we don't know anything about Protel's (proprietary) file
    formats. So how should we be able to help?
    Tilmann
    P.S. Please correct your quoting order, reply in paragraphs below the
    quotes. Thanks.
    Thanks for your reminding. I would pay attention to the correct reply order.
    Yu-Hung
    Tilmann
    quotes. Thanks.
    Yu-Hung
    I am looking for the solutions to import the Protel symbols and
    footprints into EAGLE. Is there anybody has some good ideas?
    Since you can import about anything into EAGLE by using script files,
    it's normally a matter of exporting the data from your source.
    If Protel allows for any "processable", known data format export, it
    will surely be possible to write a converter from that format to EAGLE
    script language.
    Maybe it's better to start at that side: asking for the export
    capabilities in the Protel world.
    Tilmann
    script language.
    Tilmann
