EAGLE User Chat (English) How To Delete An Orphaned Trace
  • Views 1758 views
I found when I make a small modification to a project with schematic and
PCB, I'll sometimes end up with an orphaned trace. That is, a short trace
which doesn't go anywhere anymore.
I don't see a setting in the DRC rules to catch this. Is there a way to
automatically find and tag these so i can delete them? Sometimes, they are
short enough that my tired eyes miss them. I'm loathe to rip up and redo
the board as these are typically minor changes to isolated parts.
David
    warrenbrayshaw wrote on Tue, 15 June 2010 01:49
    "David Ingebretsen" wrote...
    The problem is the traces are "routed" in a sense.
    For
    example, it I delete a component, the traces to that
    component are
    not
    ripped up. So, these orphaned traces are still connected to
    the
    proper net.
    A Ratsnest command doesn't show them and they are still on
    the top
    or
    bottom layer. It can also happen if I don't fully ripup a
    trace and
    miss a
    small piece sticking out from a pad.
    When there 'are' unrouted sections to detect it can be done with the
    ULP
    ULP zoom-unrouted
    ftp://ftp.cadsoft.de/eagle/userfiles/ulp/zoom-unrouted.ulp
    It will zoom you to the first unrouted trace it finds on the board.
    After removing a part, a ratsnest will likely create an unrouted trace
    so
    you can detect the unattached  routed trace.
    Another ULP to detect a single ended wire
    find-single-ended-wire
    ftp://ftp.cadsoft.de/eagle/userfiles/ulp/find-single-ended-wire.ulp
    Warren
    Thank you Warren. Fin_Single_Ended_Wire is what I was looking for. I tried
    many other key words, but not "single ended".
    David
    For
    example, it I delete a component, the traces to that component are
    not
    ripped up. So, these orphaned traces are still connected to the
    proper net.
    A Ratsnest command doesn't show them and they are still on the top
    or
    bottom layer. It can also happen if I don't fully ripup a trace and
    miss a
    When there 'are' unrouted sections to detect it can be done with the ULP
    ULP zoom-unrouted
    After removing a part, a ratsnest will likely create an unrouted trace so
    Warren
    Peter Wilson wrote on Tue, 15 June 2010 00:13
    David Ingebretsen wrote:
    Jaya wrote on Mon, 14 June 2010 21:00
    >> > schematic and
    short
    >> > trace
    >> > way to
    >> > they are
    and
    >> > redo
    >> > Thanks
    >> > David
    >> Hi,
    >> Did you try applying the "Ratsnest" comand. Sometimes, it has helped
    me
    >> when i have unrouted connections on the board. Usually, such
    >> connections show up on the unrouted Layer 19. If you really want to
    >> check if there
    >> are any such connections present then you can switch off all the
    layers
    >> except Layer19.
    >> -Jaya
    Thanks Jaya. The problem is the traces are "routed" in a sense.
    For
    not
    proper net.
    or
    miss a
    David
    What works for me is just dragging the end of the excess trace onto
    some
    other part of the trace signal that you do want to keep, Eagle culls
    the
    unnecessary length and the implied overlay or doubled segment and
    removes the excess or duplicated portion of the trace... not automatic,
    but it works fine for me.
    Peter
    Thanks Peter. Is there an easy or straightforward way to find these
    traces?
    David
    >> > schematic and
    >> > trace
    >> > way to
    >> > they are
    >> > redo
    >> > Thanks
    >> > David
    >> Hi,
    >> Did you try applying the "Ratsnest" comand. Sometimes, it has helped me
    >> check if there
    >> are any such connections present then you can switch off all the layers
    >> except Layer19.
    >> -Jaya
    Thanks Jaya. The problem is the traces are "routed" in a sense. For
    example, it I delete a component, the traces to that component are not
    ripped up. So, these orphaned traces are still connected to the proper net.
    A Ratsnest command doesn't show them and they are still on the top or
    bottom layer. It can also happen if I don't fully ripup a trace and miss a
    David
    What works for me is just dragging the end of the excess trace onto some
    other part of the trace signal that you do want to keep, Eagle culls the
    Peter
    schematic and
    trace
    way to
    they are
    redo
    David
    connections
    show up on the unrouted Layer 19. If you really want to check if there
    except Layer19.
    -Jaya
    David
    David
    when i have unrouted connections on the board. Usually, such connections
    except Layer19.
    -Jaya
