EAGLE User Chat (English) CadSoft forums now available on element14
  • Replies 92 replies
  • Subscribers 191 subscribers
  • Views 6314 views
  • eagle
  • forums
  • cadsoft
ChristyZ
ChristyZ over 16 years ago
Greetings CadSoft users. The CadSoft forums are now available on www.element-14.com/cadsoft. Fear not, your beloved forums will remain available for you to access via your favorite newsgroup reader, but now you can also read and post to them via element14. Anything posted on one will sync and be avialable to users on the other.
We hope this will allow us to serve even more members of the engineering community and share with them the benefits of EAGLE.
Sincerely,
Christy Zurcher - element14 Manager
    e14 Contributor over 11 years ago in reply to e14 Contributor
    HI, i just got my new raspberry pi I've plugged everything in (apart from a keyboard, does that make a difference ?) and everything on the screen (apart from the time so the screen is on ) is blank why and how do you fix it because I am really excited !!   HELP PLEASE
        U
        U
    e14 Contributor over 16 years ago in reply to e14 Contributor
    Oliver Betz schrieb:
    >>Most of this discusion should not be here. Both Element14 and EagleCentral
    >>should be hosting their own contact/discussion/support  forums about 'their'
    >>tool.
    if you mean that they should stopp message exchange with the Cadsoft
    groups: Splitting communities is a bad thing.
    I think he was only referring to the discussion about the bugs and
    behaviour of the gateways themselves, not the technical content related
    to EAGLE.
    Tilmann
    >tool.
    Oliver
    tool.
    What is required is for everyone to communicate their issues directly to
    Element14 and EagleCentral. This includes Cadsoft who should also be
    sending them a strong message when they feed posting that are not clean NNTP
    styled or have errors like those that attribute postings to others.
    Very good points, I fully agree.
    Tilmann
    e14 Contributor over 16 years ago in reply to kcadsoft
    Am 13.07.2010 13:36, schrieb Klaus Schmidinger:
    It's probably a bad idea to stir up this thread again, but I just can't
    leave this sentence uncommented.
    If something is to be reasonably displayed on various systems (forums vs. news
    groups), IMHO it makes the most sense to use the least common denominator.
    And that is clearly NNTP.
    Anyway, as long as I have a say here, the CadSoft support groups' database
    will be the NNTP server on news.cadsoft.de. Web forums may interface to these
    groups and do their best to display the postings correctly and send their
    postings to the news server in a proper way. However, there is only one
    place that is the ultimate reference, and that's news.cadsoft.de.
    Klaus Schmidinger
    Thank you very much for this final (hopefully) word image
    Gruß / regards
    Joern
    Klaus Schmidinger
    Thank you...thank you...thank you.
    This business with Element-14 etc. has made some people nervous about
    the direction of Eagle but more and more it seems there is nothing to
    worry about.
    "Oliver Betz"  wrote
    >That would leave Cadsoft alone with their NNTP interface, and give clear
    >guidance (and point responsibility) to whoever wants to relay it.
    Surely that is the point!
    It's irrelevant which system is the best or the most preferred.
    Both Element14 and EagleCentral built their web interface for their own
    reasons, dare I say commercial reasons.
    It is encumbent upon them to provide both a functional tool and support for
    any issues it has.
    All the real issues are to do with them breaking the NNTP presentation or
    failing to present an NNTP posting correctly on their site. In both cases
    it's their problem.
    Both Element14 and EagleCentral can 'bling' their interface as much as they
    like but they must process every post they take via their site and only feed
    the NNTP with stripped data that simulates a direct post to the NNTP.
    Because of this any item posted in Element14 should appear as an NNTP post
    on EagleCentral and visa versa.
    tool.
    Element14 and EagleCentral . This includes Cadsoft who should also be
    styled or have errors like those that attribute postings to others .
    Warren
    Am 13.07.2010 18:34, schrieb Olin Lathrop:
    Oliver Betz wrote on Tue, 13 July 2010 11:09
    >> since it seems to be sooo difficult for todays users to get a NNTP
    >> client running,
    It's probably not difficult, but many just don't want to. I did Usenet and
    NNTP in the 1980s. Things have moved on since then, and I really don't
    want to go back. In any case, you can't tell people what they want to use.
    You can either accomodate them or not. If I remember right, the forums at
    Eagle Central have over 5000 members. That's a lot of people that voted
    with their feet. Whether they did it for silly reasons or whether you
    agree with them is immaterial.
    Eagle Central seems to list anybody who has ever posted in news.cadsoft.de
    as a member of its forum. So you may consider subtracting at least my name
    from the member list. Maybe even Tilmann's and some more.
    Quote:
    >> what about a web interface to news.cadsoft.de?
    As I said before, that doesn't address the issues. You're still dumbing
    things down to the level of NNTP, and things are still stored in lowest
    common denominator form with information irreversibly lost. That would
    serve nobody's goal.
    It would serve mine, if done correctly. Maybe even Tilmann's and some more.
    client running,
    agree with them is immaterial.  The fact is that the demand is there.
