EAGLE User Chat (English) CadSoft forums now available on element14
  • Replies 92 replies
  • Subscribers 191 subscribers
  • Views 6336 views
  • eagle
  • forums
  • cadsoft
ChristyZ
ChristyZ over 16 years ago
Greetings CadSoft users. The CadSoft forums are now available on www.element-14.com/cadsoft. Fear not, your beloved forums will remain available for you to access via your favorite newsgroup reader, but now you can also read and post to them via element14. Anything posted on one will sync and be avialable to users on the other.
We hope this will allow us to serve even more members of the engineering community and share with them the benefits of EAGLE.
Sincerely,
Christy Zurcher - element14 Manager
    e14 Contributor over 16 years ago in reply to e14 Contributor
    Oliver Betz wrote on Tue, 13 July 2010 11:08
    I'm afraid that gateways will always be a source of trouble -
    especially if they don't use the least common denominator but want to
    add formatting options.
    No, this makes no sense.  Seriously, think about it.  You want to store it
    with the most information preserved so that it can be converted best to
    whatever a specific request wants.  If stored in the least common
    demominator, information is irreversibly lost.  That prevents good
    conversion back to other forms that can express this information.  Or put
    another way, this dumbs down everthing else to the level of NNTP (since
    that's the least common denominator), thereby decreasing the usefulness of
    everything else.
    Since such a system can produce a copy of a message nicely compatible with
    NNTP usage whenever needed, I really don't see the objection.  Several
    folks have objected to this, but none have provided any real reason that
    can be discussed on technical merits.
    To make a analogy, suppose you were part of a group working with raw PC
    boards, and use gerber files to manipulate these boards and describe them.
    Others design the circuits these boards implement, and they communicate
    with Eagle schematic and board files.  It wouldn't make sense to only allow
    these others to communicate with gerber files because information would be
    lost.  You may only care about the gerber files, but as long as they can be
    created on demand from the Eagle files, it shouldn't matter to you and the
    others can communicate at a higher level.
    This appears to be a emotional issue with the NNTP users somehow feeling
    threatened by the existance of the forums, even though there would be no
    loss of NNTP features.  In fact, some things get better for the NNTP users
    as I described in a earlier post.  So far the only objections have been
    that is "should be this way".  If someone has a real technical argument
    against this, please let's hear it.
    e14 Contributor over 16 years ago in reply to kcadsoft
    Klaus Schmidinger wrote:
    >Anyway, as long as I have a say here, the CadSoft support groups' database
    >will be the NNTP server on news.cadsoft.de. Web forums may interface to these
    >groups and do their best to display the postings correctly and send their
    >postings to the news server in a proper way. However, there is only one
    >place that is the ultimate reference, and that's news.cadsoft.de.
    since it seems to be sooo difficult for todays users to get a NNTP
    client running, what about a web interface to news.cadsoft.de?
    Oliver
    "Morten Leikvoll" wrote:
    >> Could you point out the benefit of your solution over web access to
    >> the NNTP groups?
    >That would leave Cadsoft alone with their NNTP interface, and give clear
    >guidance (and point responsibility) to whoever wants to relay it.
    I still don't see the benefit.
    >And we will get rid of all this noise image
    >Cadsoft should not have to worry about these external relays. They need to
    >focus on Eagle better and keep all maintenance costs low.
    Oliver
  • kcadsoft
    kcadsoft over 16 years ago in reply to e14 Contributor
    On 07/10/10 15:47, Olin Lathrop wrote:
    The reason that the underlying mechanism has to be a forum, is that it can
    store the most information.
    It's probably a bad idea to stir up this thread again, but I just can't
    leave this sentence uncommented.
    If something is to be reasonably displayed on various systems (forums vs. news
    groups), IMHO it makes the most sense to use the least common denominator.
    And that is clearly NNTP.
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
    "Olin Lathrop" <eagle@embedinc.com> wrote in message
    news:i1f59h$fs5$1@cheetah.cadsoft.de...
    So anyone making suggestions you don't like is "noise"?  That's rather
    arrogant, especially considering a number of the posts are yours.
    Are you for real? All non-eagle topics are noise. And I was trying to please
    you . (That is not easy!)
    >> The thing is we will never agree, so Ill focus on satisfying both.
    That's exactly what my suggestion addresses.  So once again, what's wrong
    with it?
    The only thing I can see wrong with your approach is that Cadsoft ends up
    with the workload if something doesn't work. That is why NNTP should still
    be the base of this forum, and those who wants colors and 'blinking ads' can
    have the workload themselves.
    Quote:
    >> If you never touch the nntp interface, you will never notice, except
    >> for some posts being boring monochrome.
    I'm not following.  I don't know what you mean by "touching" the NNTP
    interface, and what am I supposed to notice or not notice?
    I mean touching as in "using/browsing/writing to".
    Morten Leikvoll wrote on Mon, 12 July 2010 03:29
    Quote:
    Think of it flipped around for a minute.  The NNTP experience
    would still
    be the same (actually a little better in a few places, see my
    other post),
    but more and richer meta information about each post can be
    stored on a
    real forum server.  Seriously, how does this not address most
    peoples
    wants best?
    See all the noise above for the answer.
    with it?
    news:i19uq5$k5t$1@cheetah.cadsoft.de...
    You are still thinking of this as a underlying NNTP server with
    "gateways".
    Think of it flipped around for a minute.  The NNTP experience would still
    be the same (actually a little better in a few places, see my other post),
    but more and richer meta information about each post can be stored on a
    real forum server.  Seriously, how does this not address most peoples
    wants
    best?
    See all the noise above for the answer. The thing is we will never agree, so
    Ill focus on satisfying both. If you never touch the nntp interface, you
    will never notice, except for some posts being boring monochrome.
    "Oliver Betz" <obetz@despammed.com> wrote in message
    news:2ume361r3l3dl3k6eialeftjtv2an9cqvn@news.cadsoft.de...
    the NNTP groups?
    Tilmann Reh wrote on Sat, 10 July 2010 16:14
    You obviously are not aware of the footer eaglecentral automatically
    adds to all messages sent from there (including yours):
    Actually I am, but your point escapes me since I didn't put them there.
    Tilmann Reh wrote on Sat, 10 July 2010 16:08
    and keep telling us that this was the only right way.
    You need to start actually reading what I wrote.  If you look carefully,
    what I suggest would make things better for everyone.  I also don't go
    around telling people they should be using the forums, as you do with the
    newsgroups.
