EAGLE User Chat (English) Oval via or solder pad
  • Views 411 views
Is it possible to create a oval via or solder pad.
I have to create a part that has a oval mounting tab that must be soldered.
Harry
    Harry
    Hi Harry,
    Anything is possible in EAGLE, it's just that sometimes they can't be
    done easily or cleanly.
    One option, within the library editor is to approximate the oval shape
    using the elongated pad option when you lay down pads in your package.
    If this solution is acceptable go with it, it's the simplest solution.
    Another option would be to use an appropriately sized circular via, and
    then using commands such as circle, wire, and polygon fill around the
    via to make the overall shape oval. This method will yield exactly the
    shape you want, however will probably generate some DRC errors (
    Obviously you can overlook them, but DRC errors seem to nag some users.)
    hth,
    Best Regards,
    Jorge Garcia
    Cadsoft Computer
