EAGLE User Chat (English) Circular PCB with circular notches
  • Views 1391 views
what is the best way to micro-rotate the circular notches around the
circumference of the pcb?
Don
    "Lorenz"  wrote
    >............... but as said before, that is the easy part. As eagle will
    not calculate
    line intersections, or does no snap-to-end-off-line when drawing,
    there is no easy way to get a closed outline when adding the arcs for
    the board outline................................
    True, you cannot snap to the end of a line that is not on a grid but you can
    get two line ends to snap to the same grid point. Which has the desired
    effect.
    So if you manually get the ends very close you can subsequently snap them to
    There is an element of error that can be introduced but it's up to you to
    make the error acceptable by selecting a grid that is fine enough. In my
    example the error was <0.5mil but I could have made it much less.
    Make the grid or alt grid very small (not to small) and with Move command
    activated (and zoomed all the way in) hold the CTL so the line end snaps to
    the grid. Do the arc end first as the short straight short lines of the
    notch are already accurately placed. When you have the end placed as close
    as your chosen grid permits. Drop it and then snap the end of the straight
    line to the same point. Verify the coords for both lines are the same with
    INFO.
    Warren
    Don Golding wrote:
    >The idea would be to group an arc plus two short straight segments together
    >and rotate the entire object by maybe a degree or so.  I then want to copy
    >and paste five of these objects around the circumference.
    That's the easy part 8-)
    just draw your arc + attached segments and group them.
    Then enter  'rot r72' on the command line, press
    assuming that the center of rotation (center of board) is the point of
    origin.
    repeat 4 times, done
    but as said before, that is the easy part. As eagle will not calculate
    the board outline.
    So either construct the board outline in a CAD program and import them
    via dfx (see appropriate ULP), or draw one notch and one attached
    outline arc using precalculated coordinates, then complete the outline
    per copying as described above.
    And see the help text for the wire command (especially the radius and
    curve options) and the chapter 'command syntax' (about coordinate
    modifiers).
    Lorenz
    "Don Golding" wrote
    Yes, there are 5 total.
    The other option is to import a DXF file, right?
    I was wondering if it is possible within Eagle...
    Thanks for the help,
    Don
    Don
    Although not what you have said, are notches 2 and 3 in the attached
    what you wish to achieve?
    Warren
    Yes you can also import it via  a DXF. using a ULP. See Cadsoft download
    pages. (import_dxf_polygons_03.zip) I have no experience with this.
    You can do it directly in Eagle. See attached.
    There are a number of skills/techniques needed so if your Eagle drawing
    skill are low then expect to be spending time getting them up to a standard
    to draw your example.
    If you can, post a drawing of your board back here showing sizes and angles.
    That should enable specific help if you do draw it.
    You could build the board outline as a package so that you can design it
    once and then use it again in another project/same enclosure.
    Most board houses require the board outer shape to be defined with a
    continuous line so you need to ensure the arcs and lines all connect
    exactly.
    Warren
    M_]C_X `02D9)1@`!`0```0`!``#_VP!#``P)"0L)" P+"@L.#0P/$Q\4$Q$1
    M$R8;'1<?2@PRPH+"LR.$@],C5$-BLL/E4_1$I,4%%0,#Q87E=.7DA/4$W_
    MVP!#`0T.#A,0$R44%"5-,RPS34U-34U-34U-34U-34U-34U-34U-34U-34U-
    M34U-34U-34U-34U-34U-34U-34U-34W_P `1" &5`9<#`2(``A$!`Q$!_\0`
    M'P```04!`0$!`0$```````````$"`P0%!@<("0H+_\0`M1 ``@$#`P($`P4%
    M! 0```%]`0(#``01!1(A,4$&$U%A!R)Q%#!D:$((TQP152T? D,V)R@@D*
    M%A7J#A(6&AXB)BI3E)66EYB9FJCI6FIZBIJKSM6VM[BYNL#Q,7&
    MQ\C)RM+3U-76U]C9VN'BX3EYN?HZ>KQ\O/T]?;W/GZ_\0`'P$``P$!`0$!
    M`0$!`0````````$"`P0%!@<("0H+_\0`M1$``@$"! 0#! <%! 0``0)W``$"
    M`Q$$!2$Q!A)!40=A<1,B,H$(%$*1H;'!"2,S4O 58G+1"A8D-.$E\1<8&1HF
    M)R@IC4V-S@Y.D-$149'2$E4U155E=865IC9&5F9VAI:G-T=79W>'EZ@H.$
    MA8:'B(FDI.4E9:7F)F:HJ.DI::GJFJLK.TM;:WN+FZPL/$Q<;'R,G*TM/4
    MU=;7V-G:XN/DY>;GZ.GJ\O/T]?;W/GZ_]H`# ,!``(1`Q$`/P#S+[!>?\D
    M_P#W[-3VEE=+,Q:VF \J0<QGJ4.H58LO]>W_73_P! :@`^P7G_`#Z3_P#?
    MLT?8S_GTG_[]FJ]% %^TLKI9F6TP'E2#F,]2AQ4'V"\_Y])_\`OV:++_7M
    M_P!<I/\`T!JKT 6/L%Y_SZ3_`/?LU/:65TLS%K:8#RI!S&>I0XJA5BR_U[?]
    M<I/_`$!J`#[!>?\`/I/_`-S1]@O/?2?_OV:KT4`7[>RNEAN@;:8%H@!F,\
    MG>M0?8+S_GTG_P"_9HMO]1>?]<A_Z&M5Z +'V"\_Y])_^_9J>WLKI8;H&VF!
    M:( 9C/)WK5"K%M_J+S_KD/\`T-: #[!>?\^D_P#W[-'V"\_Y])_^_9JO10!?
    MM[*Z6&Z!MI@6B &8SR=ZU!]@O/\`GTG_`._9HMO]1>?]<A_Z&M5Z`+'V"\_Y
    M])__9J>WLKI8;H&VF!:( 9C/)WK5"MRW\.:K'#="YM#9;H@%VNMMN^=<X\
    MPKG'?'3(]10!E_8+S_GTG_[]FC[!>?\`/I/_`-^S5W[!I4'_`!\ZSYN?N_8;
    M5Y,?[WF>7CVQGOG'&3[;H\/S6D2RN>"+V[,B8]A&L9S)'7CN "&WLKI8;H
    M&VF!:( 9C/)WK4'V"\_Y])__9K4M]9C2&Z:TTG3K:01#YQ&\V1O7C;*SK.
    M,\=:@_X234TYMYHK-^\EE;QVSD>A:-5)'MG'`]* *7V"\_Y])_\`OV:G2RNA
    M8S+]FFW&5"!Y9R1A_P#$5-_PD^O?]!O4O_ N3_&IT\2ZZ;&9O[:U'<)4`/VI
    M\@8?W]A0!E_8+S_GTG_[]FC[!>?\^D__`'[-;NB:]K-UJT"W.LZD]M'NGG3[
    M9("T4:EW`PW4JI Y')'(ZUS]U<RWMU-=7#[YIG:21L 98G).!QU-`%I+*Z%C
    M,OV:;<94('EG)&'_`,14'V"\_P"?2?\`[]FA/^0?/_UUC_D]5Z +'V"\_P"?
    M2?\`[]FITLKH6,R_9IMQE0@>6<D8?_$50JPG_(/G_P"NL?\`)Z #[!>?\^D_
    M_?LT?8S_GTG_P"_9JO10!?2RNA8S]FFW&5"!Y9R1A_\14'V"\_Y])_^_9H
    M3_D'S_\`76/^3U7H`L?8+S_GTG_[]FIWLKHV,*_9IMPE6<@83_ U!]@O/?2?_OV:'_Y!\'_763257H`L?8+S_GTG_[]FIWLKHV,
    M9IMPE<D>6<@83``-4L/_`,@#_KK)_)*`#[!>?\`/I/_`-S1]@O/^?2
    M?_OV:KT4`7WLKHV,*_9IMPE6<@83_``-0?8+S_GTG_P"_9H?_`)!\'_76
    M3257H L?8+S_GTG_P"_9J=[Z-C"OV:;<)7)'EG(&$_P-4L/\`\@#_KK)
    M_)* #[!>?\^D_P#W[-%5Z* "K%E_KV_ZY2?@-1]@O/?2?_`+]FI[2RNEF8
    MM;3 >5(.8SU*'% %"BK'V"\_Y])__9HP7G_/I/_P!S0`67O;_KE)_P"@
    M-5>K]I972S,6MI@/*D',9ZE#BH/L%Y_SZ3_]S0!7JQ9?Z]ON4G_H#4?8+S
    M_GTG_P"_9J>TLKI9F+6TP'E2#F,]2AQ0!0HJQ]@O/^?2?_OV:/L%Y_SZ3_\`
    M?LT`%M_J+S_KD/\`T-:KU?M[Z6&Z!MI@6B &8SR=ZU!]@O/^?2?_OV:`]6
    M;_47G_7(?\`H:T?8S_`)])_P#OV:GM[Z6&Z!MI@6B`&8SR=ZT`4*VH/#
    M
    4*76HI)%$1N6W0$S2CT `.S/'+XX.5#8Q3_MVIVOR:19SZ9&.-T"L)G_WI
    M?O'/&0,)D9"B@!?0R"&Z.I>7IBF(9^V$HX&]<'RP#(03QD*1GOP<0>=HMI
    MS#;W.HR=0UT1!']#&A+'UR)%YQQQS#;V5TL-T#;3`M$`,QGD[UJ#[!>?\^D_
    M_?LT`7?$CU*BQG_LZ/H$L1Y&1V#,OS/CL7'KSR<TK;_47G_7(?AK1]@O
    M/?2?_OV:GM[Z6&Z!MI@6B &8SR=ZT`4*L?8+S_GTG_P"_9HP7G_/I/\`
    M]S0`6WHO/^N0_]#6J]7[>RNEAN@;:8%H@!F,\G>M0?8+S_`)])_P#OV: *
    M]6$_Y!\__76/^3T?8S_`)])_P#OV:G2RNA8S]FFW&5"!Y9R1A_\10!-;?Z
    M)X>O9SP]ZZVD8/(9%(DD/L01#U[,>O;K<UFRNH5LK".VFVL"E]L9 ,K_.^
    M1V9=RQGO[&<=!E_8+S_`)])_P#OV: !/0?/_UUC_D]5ZOI970L9E^S3;C*
    MA \LY(P_(J#[!>?\D__?LT`5ZL)_R#Y_\`KK'_`">C[!>?\^D__?LU.EE=
    M"QF7[--N,J$#RSDC#_XB@"A15C[!>?\`/I/_`-S1]@O/?2?_OV: !/^0?/
    M_P!=8_Y/5>KZ65T&9?LTVXRH0/.2,/_B*@P7G_/I/_P!S0!7JP__`"#X
    M/NLG\DHP7G_/I/_P!^S4[V5T;&%?LTVX2N2/+.0,)_@: *%%6/L%Y_SZ3_
    M`/?LT?8S_GTG_[]F@`?_D'P?]=9/Y)5>K[V5T;&%?LTVX2N2/.0,)_@:@^
    MP7G_`#Z3_P#?LT 5ZL/_`,@#_KK)_)*/L%Y_P`D_\`W[-3O971L85^S3;A
    M*Y(\LY PG!H`H458P7G_/I/_W[-'V"\_Y])_\`OV: !_\`D'P?]=9/Y)5>
    MK[V5T;&%?LTVX2N2/+.0,)_@:@P7G_/I/\`]S0!7JP_P#R#X/NLG\DHP
    M7G_/I/\`]^S4[V5T;&%?LTVX2N2/+.0,)_@:`*%%6/L%Y_SZ3_\`?LT4`5ZL
    M67O;_KE)_Z U5ZL67O;_KE)_Z U %>BBB@"Q9?Z]ON4G_`* U5ZL67O;
    M_KE)_P"@-5>@`JQ9?Z]ON4G_H#57JQ9?Z]ON4G_H#4`5Z*** %M_JS_K
    MD/\`T-:KU8MO]1>?]<A_Z&M6HK&VM(DN-4=CO4,EG"VV9E/W6%2JCD9RQX
    M^7#!J ]EI\M[O96BBABQYDTSA$3/ZDX!(506.#@'%:5O?6NGPW7]D+9Q$,
    MWEPJAQ\ZXV(,B,C/WMS-E005Y%9M[J$M[L5EBBABSY<,*!$3/ZDX`!9B6.!D
    MG%-MO]1>?]<A_P"AK0!#++)/\LSM)[%G=SDL3R23W--HHH`L6WHO/N0_
    M]#6J]6+;_47G_7(?^AK5>@`JQ;?ZB\_ZY#_T-:KU8MO]1>?]<A_Z&M %>BBB
    M@"Q;?ZB\_P"N0_\`0UJO5BV_U%Y_UR'_`&M5Z "MC0;:ZF"W*;[:.59YTR
    M06BC21W QW*J0.1R1R.M8];5H93PIJ,VT;;V>.U4GG(7]X^/0@BKV8]>P!
    ME75S+>W4UU</OFF=I)&P!EB<DX''4U%110!83_D'S_\`76/^3U7JPG_(/G_Z
    MZQ_R>J] !5A/0?/_P!=8_Y/5>K"?\@?_KK'_)Z`*]%%% %A/\`D'S_`/76
    M/3U7JPG_(/G_P"NL?\`)ZKT`%6'_P"0?!_UUD_DE5ZNP6TM[#96MNF::Y:
    M.-4``(!2?\`Y!\'_763^257JW<1206B13(T<J3RJZ.,%2 @(([&
    MJE !5A_0?!_UUD_DE5ZL/\`\@#_KK)_)* *]%%% %A_P#D'P?]=9/Y)5>K
    M#_\`(/@_ZZR?R2J]`!5A_P#D'P?]=9/Y)5>K#_\`(/@_ZZR?R2@"O1110!8^
    MP7G_`#Z3_P#?LU/:65TLS%K:8#RI!S&>I0XJA5BR_P!>W_7*3_T!J #[!>?\
    MD__`'[-'V"\_P"?2?\`[]FJ]% %TLKI9F+6TP'E2#F,]2AQ4'V"\_Y])_^
    M_9HLO]>W_73_P! :J] %C[!>?\`/I/_`-^S4]I972S,6MI@/D',9ZE#BJ%
    M6+`%[?]<I/0&H`/L%Y_SZ3_\`?LT?8S_`)])_P#OV:KT4 =+H,#Q6UXD
    M<$EOJCJ/L]Q,AVK\PX!R`C>C$-@X.8]I8Y%UI^J"ZE-Y:7GVAFW2>=&V\D\Y
    M.1G)SFH;;_47G_7(?^AK5BVU!6@6ROU\VT&0KJBF6#)SE&/)&23L)VG+="=P
    M`*_V"\_Y])_^_9J>WLKI8;H&VF!:( 9C/)WK3;S3FMXA<P2+<63MA)5(R">@
    M=<DHW!X/!VG:6 S45M_J+S_KD/\`T-: #[!>?\^D_P#W[-'V"\_Y])_^_9JO
    M10!?M[*Z6&Z!MI@6B &8SR=ZU!]@O/\`GTG_`._9HMO]1>?]<A_Z&M5Z`+'V
    M"\_Y])_^_9J>WLKI8;H&VF!:( 9C/)WK5"K%M_J+S_KD/_0UH /L%Y_SZ3_]
    MS1]@O/?2?_`+]FJ]% %WLKI8;H&VF!:(`9C/)WK4'V"\_Y])__9HMO\`
    M47G_`%R'_H:U7H L?8+S_GTG_P"_9K;U:SN8=-M=/CMY2L,4,AVH0'>16D9L
    M>H#HA/?8.G '/1123RI%"C22NP5$09+$\ `=S6SK\L<VHZRT#J\`OML)0Y7R
    MQO"!<<;0H &., 8H`S/L%Y_SZ3_]S1]@O/?2?_`]FJ]% %]*Z%C,OV:;
    M<94('EG)&'_Q%0?8+S_GTG_[]FA/0?/_P!=8_Y/5>@"Q]@O/?2?_OV:G2R
    MNA8S]FFW&5"!Y9R1A_\15"K"?\`(/G_`.NL?\GH`/L%Y_SZ3_\`?LT?8S_
    M`)])_P#OV:KT4 7TLKH6,R_9IMQE0@>6<D8?_$5!]@O/^?2?_OV:$_Y!\_\`
    MUUC_`)/5>@"Q]@O/^?2?_OV:V]'L[FVLYKTV\HDM$E:(%""9'"(A![,NXR#'
    M/[LXQC(YRMFY\RU\)V$)47ES+<$<'>J!40V&\X8_/M0!G?8+S_`)])_P#O
    MV:/L%Y_SZ3_]^S5>B@#H4DN+C3K>UU6TN;E$9D27#M-;)A<;`3@KQ]UN." 5
    M))K-N]&OK2;RVMY)%(W))&C%9%/0CC]#@@Y!`((J!_\`D'P?]=9/Y)4MG?1Q
    MQ&VO86N;,MO\M7V.C?WD8@[2< '@@@#(R%(`(OL%Y_SZ3_\`?LU.]E=&QA7[
    M--N$KDCRSD#"?X&HKVR^S;)8I/.M)L^5,!C=CJI'\+#(RON""002U_\`D'P?
    M]=9/Y)0`?8+S_GTG_P"_9HP7G_/I/\`]S5>B@"^]E=&QA7[--N$KDCRSD#
    M"?X&H/L%Y_SZ3_\`?LT/_P`@^#_KK)_)*KT`6/L%Y_SZ3_\`?LU.]E=&QA7[
    M--N$KDCRSD#"?X&J%6'_`.0?!_UUD_DE`!]@O/\`GTG_`._9HJO10 58LO\`
    M7M_URD_]`:C[!>?\^D__`'[-3VEE=+,Q:VF \J0<QGJ4.* *%%6/L%Y_SZ3_
    M`/?LT?8+S_GTG_[]F@`LO]>W_73_P! :J]7[2RNEF8M;3 >5(.8SU'%0?8
    M+S_GTG_[]F@"O5BR_P!>W_7*3_T!J/L%Y_SZ3_\`?LU/:65TLS%K:8#RI!S&
    M>I0XH H458P7G_/I/\`]S1]@O/^?2?_OV:`"V_U%Y_UR'_`*&M5ZOV]E=+
    M#= VTP1`#,9Y.]:@^P7G_/I/_W[- !9WL]A*9=E!9=KZZ..N&5@01D \
    MCJ >H%:EO96I0W3:7E+EHANLGXYWKQ$Q.7Y'"GYOF4#?R:R_L%Y_P`D_\`
    MW[-3V]E=#= VTP1 #,9Y.]: *%%;N)-4352=D\)>I"1,JA<R<]6'S\
    MDG?@5&[T34;*;RIK23=C(:/]XK#U#D'TX/4$=J`(+;_47G_7(?^AK5>K]O
    M972PW0-M,"T0`S&>3O6H/L%Y_P`D_\`W[- %>K%M_J+S_KD/_0UHP7G_/I
    M/_W[-3V]E=#= VTP1 #,9Y.]: *%%6/L%Y_P`D_\`W[-'V"\_Y])__9H
    M`;_`%%Y_P!<A_Z&M5ZOV]E=#= VTP+1 #,9Y.]:@P7G_/I/\`]S0!=\,
    M?\C5HW_7[#_Z&*I)_P`@^?\`ZZQ_R>GQ6FH02I+#!<QRHP9'1&!4CD$'L:UM
    M>T65-:BM[1TB&H-Y:)&0`H:0# `Z#B@#GJ*L?8S_GTG_[]FC[!>?\D__
    M`'[-``G_`"#Y_P#KK'_)ZKU?2RNA8S+]FFW&5"!Y9R1A_P#$5!]@O/\`GTG_
    M`._9H KU83_D'S_]=8_Y/1]@O/\`GTG_`._9J=+*Z%C,OV:;<94('EG)&'_Q
    M% %"BK'V"\_Y])__9HP7G_`#Z3_P#?LT "?\@^?_KK'_)ZKU?2RNA8S+]F
    MFW&5"!Y9R1A_\14'V"\_Y])_^_9H`ABBDGE2*%&DE=@J(@R6)X `[FMGQ#+&
    MTB00.LEO:2-;1,ARCA%12ZXX`=@S\=W/)ZE=`LKJ#4'O6MIE%G#).KF,_+(%
    MQ$<=_P!X8.1Z\9JD]E=&QA7[--N$KDCRSD#"?X&@"A15C[!>?\`/I/_`-S
    M1]@O/?2?_OV: !_0?!_P!=9/Y)5>K[V5T;&%?LTVX2N2/+.0,)_@:@^P7G
    M_/I/_P!S0`ZRO?LV*6/SK2;'FPDXW8Z,#_``L,G#>Y!!!(-G4[+[%;6RI)
    MYL,K-#C&]&5/J,@Y4@$X96&3BJGV"\_P"?2?\`[]FM:SAD;2_L%Y;RK'+(
    M[)(8F/V>3Y,/@#.T@%2!V.6<@83_ U
    M!]@O/?2?_OV: *]6'_Y!\'_`%UD_DE'V"\_Y])__9J=[*Z-C"OV:;<)7)'
    MEG(&$_P-`%"BK'V"\_Y])_\`OV:`]6++_7M_URD_\`0&JO5BR_U[?]<I/_
    M`$!J`]%%% %BR_U[?\`73_`- :J]6+7MP!<I/\`T!JKT %6+_7M_UR
    MD_\`0&JO5BR_U[?]<I/_`$!J`*]%%% %BV_U%Y_UR'_H:U7JQ;?ZB\_ZY#_T
    M-:KT`%6;_47G_7(?^AK5>K%M_JS_KD/_0UH KU=L[R-8C9WH9[-VW?*,O"
    MW3>F>_ RO 8``X(5EI44`:<EE]F@N)8I/.M)HOW4P&-V'3D?PL,C^X()!!
    M.96SH#1R_;;"YE\JWNX0A9FPJ2;U\MR3P &.">H5GQUK(EBD@E>*9&CE1BKH
    MXP5(X(([&@!M6+;_`%%Y_P!<A_Z&M5ZL6W^HO/\`KD/_`$-:`*]%%% %BV_U
    M%Y_UR'_H:U7JQ;?ZB\_ZY#_T-:KT`%;FHL+[1EU,$&:26.*Z&>?-56<_P"
    MN#DG+.)#6'6UHCQ/;75C8Y $4F'/D\ V QZ[&?'6@#%HITL4D
    M$KQ3(T<J,5='&"I'!!'8TV@"PG_(/G_ZZQ_R>J]6$_Y!\_\`UUC_`)/5>@`J
    MPG_(/G_ZZQ_R>J]6$_Y!\_\`UUC_`)/0!7HHHH L)_R#Y_\`KK'_`">J]6$_
    MY!\__76/3T[3K[==&\GDVZ_-/.1D0QY +$=O`ZDD`<D"@"VW@'E0\3
    M:BXD&."(8RPZ]PSYXXP80<'((I/_`,@^#_KK)_)*=J5[_:%_+<"/RHSA8H\[
    MO+C4!47/?"@#)Y.,FFO_`,@^#_KK)_)`]%%% %A_\`D'P?]=9/Y)5>K#_\
    M@#_`*ZR?R2J] !5A_\`D'P?]=9/Y)5>K#_\@#_`*ZR?R2@"[#_`,3BU%LW
    MS:E%M6W/>:,`CR\_Q,/EV#J1E<GY%K*IT4LD$J2PNT<J,&1T."I'((/8UH:C
    M%'<V\>IVR+&DC"*>)!@1RA1DX' 5^64<<AU PN2 57_Y!\'_`%UD_DE5ZL/_
    M`,@#_KK)_)*KT %6'_Y!\'_`%UD_DE5ZL/_`,@#_KK)_)`]%%% %C[%+
    M_?@_[_I_C4]I:2+,Q+0_ZJ0<3(?X#[U0JQ9?Z]O^N4G_`* U`!]BE_OP?]_T
    M_P`:/L4O]#_`+_I_C5>B@"_:6DBS,2T/JD'$R'^ ^]0?8I?[\'_?\`3_&B
    MR_U[?]<I/_0&JO0!8Q2_P!#_OG-3VEI(LS$M#_JI!Q,A_@/O5"K%E_KV
    M_P"N4G_H#4 'V*7^_!_W_3_&C[%+_?@_[_I_C5>B@"_;VD@AN@6AYB XF0_Q
    MK[U!]BE_OP?]_P!/\:;_47G_7(?^AK5>@"Q]BE_OP?]_P!/\:GM[200W00
    M\Q <3(?XU]ZH58MO]1>?]<A_Z&M !]BE_OP?]_T_QHQ2_WX/_Z?XU7HH O
    MV]I((;H%H>8@.)D/\:^]7=8M)E'4-T)DN8<3N)DP9D8J><\L5".W))+Y[B
    MLNV_U%Y_UR'_`&M78_])\,3)U>RNA(JKUV2KM=F]@8X@#Q@O@YR 7V7^
    M_!_W_3_&I[>TD$-T"T/,0'$R'-?>J%6+;_47G_7(?\`H:T`'V*7_!_W_3_
    M`!HQ2_WX/\`OG-5Z`+]O:2"&Z!:'F(#B9#_&OO4'V7_!_W_3_&BV_U
    M%Y_UR'_H:U7H`L?8I?[\'_?]/\:G2TDPS+NAR94/N3'1^^:H583_D'S_\`
    M76/3T :AM)-6L0"T/VVRAQQ,A\)3]<[D!FQ?X=GS9?V*7_!_W_3_`!J&
    M*62"5)87:.5&#(Z'!4CD$'L:T_MMIJ?RZE'Y5VW_`"_(3\S?WI4YW=LLN#R6
    M(<\$`A2TDPS+NAR94/N3'1^:@Q2_WX/_P"G-7YM'N[;2;BX5!<6@EC
    M/VFW.^/&& R1]T\K\K88;AD#-9% %C[%+_?@_P"_Z?XU.EI)]AF7=#DRH?\`
    M7)CH_?-4*L)_R#Y_NL?\GH`/L4O]#_`+_I_C1]BE_OP?\`?]/\:KUJ_P!B
    M_8_FUF?[!_TPV;[@_P#;/(V]C\Y7(.5W4 ):Z9P)[&I+/;!%864L#6\7S2R"9 +B7)?!.< ':H/8$X4LPI)M2#Z3<
    M6]G;QV=L98PRI\SR##'YW/+=%.!A<C(4&LB@"Q]BE_OP?]_T_P`:G>TD^PPK
    MNAR)7/\`KDQT3OFJ%6'_`.0?!_UUD_DE`!]BE_OP?]_T_P`:/L4O]^#_`+_I
    M_C5>B@"]I)]AA7=#D2N?]<F.B=\U!]BE_OP?]_T_P`:'_Y!\'_763257H`
    ML?8I?[\'_?\`3_&IWM)/L,[H<B5S_KDQT3OFJ%6'_Y!\'_763^24 'V7^_
    M!_W_`$_QJ[I@-K+,EP8FM;F(PS!)X\X."&'S#)5E5L9&=N"0":RJ* -:_P!)
    MGLHQ:R/;LT<SD.LR[74JA5E)(R",$>Q![U1Q2_WX/\`OG^-:;!M0\*Q,6S
    MILC@C_`)8,5R<_[,CCU)\WT6L2@"Q]BE_OP?\`?]/\:G>TDPPKNAR)7/
    MN3'1.:H58?_`)!\'_76324`'V7^_!_P!_T_QHJO10`58LO]>W_73_P!
    M:C[%+_?@_P"_Z?XU/:6DBS,2T/\`JI!Q,A_@/O0!0HJQ]BE_OP?]_P!/\:>=
    M-N1$LI$0B9BJN9DP2,$@'/49'YB@!EE_KV_ZY2?^@-5>K]I:2,Q0_ZJ0<3
    M(?X#[U!]BE_OP?\`?]/\: *]6++_`%[?]<I/_0&HQ2_WX/_P"G^-3VEI(L
    MS$M#_JI!Q,A_@/O0!0HJQ]BE_OP?]_T_QHQ2_WX/_Z?XT`%M_J+S_KD/\`
    MT-:KU?M[200W00\Q <3(?XU]Z@Q2_WX/\`OG^- %>K%M_JS_`*Y#_P!#
    M6C[%?@P"_Z?XU/;VD@AN@6AYB`XF0_P`:] %"BK'V*7_!_W_3_&C[%
    M_?@_[_I_C0`6WHO/N0_P#0UJ[I/_(.UW_KR7_THAJ&WM)!#= M#S$!Q,A_
    MC7WJ[I5I(-/UP%H>;)1Q,A_Y>(?>@##JQ;?ZB\_ZY#_T-:/L4O\`?@_[_I_C
    M4]O:2"&Z!:'F(#B9#_&OO0!0HJQ]BE_OP?\`?]/\:/L4O]#_O\`I_C0`6W
    MHO/N0_]#6J]7[>TD$-T"T/,0'$R'-?>H/L4O\`?@_[_I_C0!7JPG_(/G_Z
    MZQ_R>C[%+_?@_P"_Z?XU.EI)]AF7=#DRH?\`7)CH_?- %"BK'V*7^_!_W_3_
    M`!HQ2_WX/\`OG^- $MG=7%E;23VD\L$R2IMDB<JPRK@X(YZ&K']OW$_P#R
    M$K>VUONND/F$]B94*R-@<8$8QQP,0I:2?89EW0Y,J'_7)CH_?-0?8I?[\'
    M_?\`3_&@"[_:.F3?+<:)%$@Y!LKB2-\^YD,@Q^ /3GL9TN]'BL9G@TJXD82I
    M\EU>;XR</U"(C=,]&'..W!R_L4O]#_OG^-3I:2?89EW0Y,J'_7)CH_?- $
    MW_"1:A'Q9/%IX'"FRB6%PO\`=,BC>PZ?>8YP"<GFLJK'V*7^_!_W_3_&C[%+
    M_?@_[_I_C0`)_P`@?\`ZZQ_R>J]7TM)/L,R[H<F5#_KDQT?OFH/L4O]#_O
    MG-`%>K#_\`(/@_ZZR?R2C[%+_?@_[_`*?XU.]I)]AA7=#D2N?]<F.B=\T`
    M4*L?8I?[\'_`'_3_&C[%+_?@_[_`?XT #_`/(/@_ZZR?R2J]7WM)/L,*[H
    M<B5S_KDQT3OFH/L4O]#_O\`I_C0!7JP_P#R#X/NLG\DHQ2_WX/_Z?XU.
    M]I)]AA7=#D2N?]<F.B=\T 4**L?8I?[\'_?]/\:/L4O]#_OG^-`%NPO?[/
    M6TN#'YL8EE66/.WS(V15=<]LJ2,CD9RK:E9?V??RVXD\V,8:3&WS(V`9&Q
    MVRI!P>1G!J5[23[#"NZ'(E<_ZY,=$[YJZ;22_P!"`+0FXTXXXF3F!V^N!MD;
    MW)\WT6@##JP__(/@_P"NLG\DHQ2_P!#_OG-3O:2?885W0Y$KG_7)CHG?
    M- %"BK'V7^_!_W_`$_QHH KU8LO]>W_`%RD_P#0&JO5BR_U[?\`73_`- :
    M@"O707MXNG)9:;);Q3VBVL4DP*J&=I1YNY6P2C .JY&<^6NX$?+69I%G'?ZI
    M;P3EEM]V^=D/1-TC#W"ACT/3H>E17]Y)J&H7-[,%66XE:5P@P`6))Q[<T`
    M:$>FJ!=V$_VJT6*3<6"I'\A'SQAB0,D?,"591G)VC'JYI4\EM>=$0'6*
    M4C*A@?D;@@\$'H0>".M6=EKJ_P#J1%9WYY97D6.";UVYP(SWP3M.3C;A5(!E
    M58LO]>W_`%RD_P#0&J&62"5XID:.5&NCC!4C@@CL:FLO\`7M_URD_]`:@"
    MO1110!8MO]1>?]<A_P"AK5>K%M_JS_KD/\`T-:KT %6;_47G_7(?\`H:U7
    MJQ;?ZB\_ZY#_`-#6@"O1110!8MO]1>?]<A_Z&M79/]!\/0H/EFU!S(_J84.$
    MP1VB3(/>-#@8!-'M!>2W$4DH@@$0::8C(B3S$RV.^.PZDX`Y(JOJ5[_:%_
    M<"/RHSA8H\[OC4!47/?"@#)Y.,F@"K5BV_U%Y_UR'_`*&M5ZL6WHO/N0
    M_P#0UH KT444`6;_47G_7(?^AK5>K%M_JS_KD/_0UJO0`583_D'S_]=8_Y
    M/5>K"?\`(/G_`.NL?\GH`KT444 6$_Y!\_\`UUC_`)/5>K"?\@^?_KK'_)ZK
    MT %6$_Y!\_\`UUC_`)/5>K"?\@?_KK'_)Z *]%%% %A/0?/_UUC_D]5ZL)
    M_P`@^?\`ZZQ_R>J]`!5A_P#D'P?]=9/Y)5>K#_\`(/@_ZZR?R2@"O1110!8?
    M_D'P?]=9/Y)5>K#_`/(/@_ZZR?R2J] !5A_0?!_UUD_DE5ZL/\`\@#_KK)
    M_)* ]%%% %A_P#D'P?]=9/Y)5WPY]UF"S;_5WV;-@>0/,56([[6N!ZJ.
    M1U%)_P#D'P?]=9/Y)5>@`JP__(/@_P"NLG\DJ[XA_?:E]O'*:@@N\]M[9\P`
    M=0!()%&>RCKU-)_^0?!_UUD_DE %>BBB@"Q]BE_OP?\`?]/\:GM+219F):'_
    M`%4@XF0_P'WJA5BR_P!>W_7*3_T!J -33+22UT_4K[=#O$8M8B)D.UITZ#H]R\EVQ7HR9\M WJ5,<N/0/
    MQU-95 %TM)%F8EH?]5(.)D/\!]Z@Q2_P!#_OG^-%E_KV_P"N4G_H#57H
    M`VXI!<Q);ZJL4J(H6.>&:)9HQT&3G]XH&,Q!^4`,HSE@T>XLYM[26TL#IL
    M<T4Z,CX0].<CJ"00" 1D"L>M1[^>SFE1&6\L3^=;LQ\N8!&P& (S['J.H(
    M/- %7[%?@[_I_C1]BE_OP?]_T_P`:N_V;;ZC\^D28D/'V*>0&;_@859,
    M\8 P^3@<;CF2Q202O%,C1RHQ5T<8D<$$=C0!=M[200W0+0\Q <3(?XU]Z@
    MQ2_WX/_P"G-%M_J+S_KD/_0UJO0!8Q2_WX/_P"G-3V]I((;H%H>8@.
    M)D/\:]4*L6WHO/N0_]#6@`Q2_P!#_OG^-/BTVYGE2*$122NP5$29"6
    M)X `SR:2RTZXOM[QKMMXL&:X<'RX0>A8@<=#@=2>`"<"K$M\MC$]II<S!74I
    M<794S@\%1W$?L>6ZMV50"_+%]ET^YTVUEMY(VCCEGE$Z'?".!S@*FYU!'W
    MCDY(*A<;[%`'X/^Z?XT6WHO/N0_]#6J] %C[%_`'X/^_Z?XU/;VD@A
    MN@6AYB XF0_QK[U0JQ;?ZB\_ZY#_`-#6@ Q2_WX/_Z?XT?8I?[\'_?]/\`
    M&J]%`%WM)!#= M#S$!Q,A_C7WJ#[%+_`'X/_Z?XT6WHO/N0_]#6J] %C
    M[%`'X/^Z?XU.EI)]AF7=#DRH?]<F.C]\U0JPG_(/G_P"NL?\`)Z #[%_
    M`'X/^_Z?XT?8I?[\'_?]/\:KT4 7TM)/L,R[H<F5#_KDQT?OFH/L4O\`?@_[
    M_I_C0G_(/G_ZZQ_R>J] %C[%+_?@_P"_Z?XU.EI)]AF7=#DRH?\`7)CH_?-4
    M*L)_R#Y_NL?\GH`/L4O]#_`+_I_C1]BE_OP?\`?]/\:KT4`7TM)/L,R[H<
    MF5#_`*Y,='[YJ#[%?@P"_Z?XT)_R#Y_\`KK'_`">J] %C[%_`'X/^_Z?
    MXU.]I)]AA7=#D2N?]<F.B=\U0JP__(/@_P"NLG\DH /L4O\`?@_[_I_C1]BE
    M_OP?]_T_QJO6E%I]M;Q)/JEPT>]0Z6L*YF=3RI)/RHI'0G+<@[""#0`Q[23[
    M#"NZ'(E<_P"N3'1.:FL_#.L:A$9;&PDNH@VTO"0X!ZXR#UY'YU.LFSL8?[
    M&A-@/-?]]OWW'1/^6F!MZD?(%R.#GK67>7]WJ$HEOKJ>ZE"[0\TA<@=<9/;D
    M_G0!?D\,ZE"YCN!:6\HZQ7%[!$Z_56<$>O(J5_#]Y]AA7SM.R)7/_(2M\=$[
    M[ZPZL/\`\@#_KK)_)* +O\`PCU[_P`]M-_\&=M_\<H_X1Z]_P">VF_#.V_
    M.5E44 ;C'[S[#"OG:=D2N?^0E;XZ)WWU!_PCU[_P`]M-_\&=M_\<JD_P#R
    M#X/^NLG\DJO0!T%_ITG]AV8FN$W-M(\0"7LDQ-\Z@!6/1_,))P?G7KVSGM
    M)/L,[H<B5S_`Y,=$[YJA5A_P#D'P?]=9/Y)0`?8I?[\'_?]/\`&BJ]% !5
    MBR_U[?\`7*3_`- :C[%+_?@_[_I_C6IX=TG[9KUG:W#H(9W\IS',A8!@0<<G
    MGGTH`@U_]U>6]H.$M;6&/R^\;E \BGOGS'DR#T.1QC RJT+\7.H:A<WLQMEE
    MN)6E<).@`$DX^;IS5?[%_?@_[_`*?XT %E_KV_ZY2?^@-5>K]I:2,Q0_
    MZJ0<3(?X#[U!]BE_OP?]_P!/\: *]6+7MURD_] :C[%_`'X/^_Z?XU/:
    M6DBS,2T/JD'$R'`] %"M+6YO2&@@U&&-0L:W08F,#@!74JX4#.%W;>
    M2<9YJK]BE_OP?]_T_P`:/L4O]^#_`+_I_C0!J6\FB7,-UN@O;%C$&=XG6=!\
    MZ\*C;2!GH2[$`=^M0?V78/\`,FO6*H>5$L4X<#_:"QL`?7!(]SUJ&WM)!#=
    MM#S$!Q,A_C7WJ#[%?@P"_Z?XT`7?L6CP_<:O+*YY!LK0R)CW,C1G/X$=
    M.>PGMYM(LX;K[-;RZBWE`EKP&%,;UXV1OG/0[M.<;>]9?V*7_!_P!_T_QJ
    M>WM)!#= M#S$!Q,A_C7WH BO=2N]0V"YES''GRXD4)''GKM10%7.,G &3R:J
    MU8Q2_WX/_Z?XT?8I?[\'_?]/\`&@`MO]1>?]<A_P"AK5>K]O:2"&Z!:'F(
    M#B9#_&OO4'V*7^_!_P!_T_QH`KU8MO\`47G_`%R'_H:T?8I?[\'_`'_3_&I[
    M>TD$-T"T/,0'$R'^-?>@"A15C[%+_?@_[_I_C1]BE_OP?]_T_P`:`"V_U%Y_
    MUR'_`*&M5ZOV]I((;H%H>8@.)D/\:]0?8I?[\'_`'_3_&@"O5A/0?/_P!=
    M8_Y/1]BE_OP?]_T_QJ=+23[#,NZ')E0_ZY,='[YH`H458Q2_P!#_OG-'
    MV*7^_!_W_3_&@ 3_`)!\_P#UUC_D]5ZOI:2?89EW0Y,J'_7)CH_?-0?8I?[\
    M'_?]/\: *]6$_P"0?/\`]=8_Y/1]BE_OP?\`?]/\:G2TDPS+NAR94/N3'1
    M^: *%%6/L4O]#_`+_I_C1]BE_OP?\`?]/\: !/^0?/_P!=8_Y/5>KZ6DGV
    M&9=T.3*A_P!<F.C]\U!]BE_OP?\`?]/\: ]6'_Y!\'_`%UD_DE'V7^_!_W
    M_3_&MBQLEM]-6^N?LTGE2R+#$TJ$22%%P>3@JF Q'.?E!&&R`"IMBT7B>"*X
    MU'O%"4MO3<,X:3/53E5Z,"20F9++)/\LSM)*[%G=SDL3R23W-69;>YGE>6
    M::25V+.[W$L3R23NY-,Q2_P!#_OG- `_\`R#X/^NLG\DJO5][23[#"
    MNZ'(E<_ZY,=$[YJ#[%`'X/^Z?XT 5ZL/_`,@#_KK)_)*/L4O]#_`_I
    M_C4[VDGV&%=T.1Y_P!<F.B=\T 4*L?8I?[\'_?]/\`&C[%+_?@_P"_Z?XT
    M`#_\@^#_`ZR?R2J]7WM)/L,[H<B5S_`*Y,=$[YJ#[%+_?@_P"_Z?XT`5ZL
    M/_R#X/\`KK)_)/L4O\`?@_[_I_C4[VDGV&%=T.1Y_UR8Z)WS0!0HJQ]BE_
    MOP?]_P!/\:* *];O@O\`Y'#2/^OA:PJU_#,C0ZR)XSB6"WN)XV_NND+LI]\$
    M`T 9%%%%`%BR_P!>W_7*3_T!JKU8LO\`7M_URD_]`:J]`!5BR_U[?]<I/_0&
    MJO5BR_U[?]<I/_0&H KT444`6+;_`%%Y_P!<A_Z&M5ZL6W^HO/\`KD/_`$-:
    MKT %6+;_`%%Y_P!<A_Z&M5ZL6W^HO/\`KD/_`$-:`*]%%% %BV_U%Y_UR'_H
    M:U7JQ;?ZB\_ZY#_T-:KT`%6;_47G_7(?^AK5>K%M_JS_KD/_0UH KT444`
    M6+;_`%%Y_P!<A_Z&M5ZL6W^HO/\`KD/_`$-:KT %6$_Y!\__`%UC_D]5ZT(8
    M%;P_>W!)WI=0(!VPR3$_^@B@#/HHHH L)_R#Y_\`KK'_`">J]6$_Y!\__76/
    M3U7H *L)_R#Y_\`KK'_`">J]6$_Y!\__76/3T`5Z*** +"?\@^?_KK'_)Z
    MKU83_D'S_P#76/\`D]5Z`"MWQ)^Y,%@.$T]GM,=MZA?,(/4@R&1AGLPZ=!4\
    M/Q1R:W:M.BR00,;B:-AD/'&#(ZX/!)52`#P2>,:A-B[A;_`$*Y/]FL.M7P]_R$9O\`KRN__2>2@"E]FB_Y_8/R
    M?_XFC[-%_P`_L'Y/_P#$U7HH`OVEO&)FQ=PMZDX`?\`N'_9J#[-%_SP?D_
    M_P`319?Z]O\`KE)_Z U5Z 'V:_`)_8/R?_`.)J>TMXQ,V+N%OW4G #_P!P
    M_P"S5"K%E_KV_P"N4G_H#4 'V:+_`)_8/R?_`.)H^S1?\_L'Y/\`_$U7HH O
    MV]O&(;K%W"<Q#D!/G7_`&:@S1?\_L'Y/\`_$T6WHO/N0_P#0UJO0!8^S
    M1?\`/[!3_\`Q-3V]O&(;K%W"<Q#D!/G7_9JA5BV_U%Y_UR'_H:T 'V:+_G
    M]@_)_P#XFC[-%_SP?D__P`35>B@"_;V\8ANL7<)S$.0'X=?]FH/LT7_/[!
    M3__`!-%M_J+S_KD/_0UJO0!8S1?\_L'Y/_`/$U/;V\8ANL7<)S$.0'X^=?
    M]FJ%6+;_`%%Y_P!<A_Z&M !]FB_Y_8/R?_XFC[-%_P`_L'Y/_P#$U7HH`OV]
    MO&(;K%W"<Q#D!/G7_9J#[-%_P`_L'Y/_P#$T6WHO/^N0_]#6J]`&E#IEI)
    M&'?6[")C_ Z3DC\HB/UK4ATVU'AZ]B&M6#(UW;L90DU2$FPI_=YR<DC`(4
    MY(XSS-:MO_R*NH_]?MK_`.@3T -?2K-49AKVG.0,A52XR?89BQ53[-%_S^P?
    MD_\`\35>B@"EO']AF'VN'!E3G#X'#_[/<5!]FB_P"?V#\G_P#B:$_Y!\__
    M`%UC_D]5Z 'V:_`)_8/R?_`.)J=+>/[#,/M<.#*G.'P.'_`-G_`#BJ%6$_
    MY!\__76/3T`'V:+_G]@_)__`(FC[-%_SP?D_\`\35>B@"^EO']AF'VN'!E
    M3G#X'#_[/^<5!]FB_P"?V#\G_P#B:$_Y!\__`%UC_D]5Z -SP_;QC4)L7<+?
    MZ%=\`/\`\^\G^S5)[>/[#"/M<.!*_.'P>$_V?\YJ;P[SJC(.7DM;F-%[L[0.
    MJJ/4DD #N2!5)_\`D'P?]=9/Y)0`?9HO?V#\G_)HS1?\`/[!3_\`Q-5Z
    M* +[V\?V&$?:X<"5</@\)_L_P"<U!]FB_Y_8/R?_P")H?\`Y!\'_763257
    MH L?9HO?V#\G_\`B:G>WCPPC[7#@2OSA\'A/\`9_SFJ%6'_P"0?!_UUD_D
    ME !]FB_Y_8/R?_XFC[-%_P`_L'Y/_P#$U7HH`OO;Q_881]KAP)7YP#PGS_
    M`)S4'V:+_G]@_)__`(FA_P#D'P?]=9/Y)5>@"Q]FB_Y_8/R?_P")J=[>/[#"
    M/M<.!.'P>$P!G_.:H58?_`)!\'_763^24`'V:+_G]@_)__B:KT4`%;G@
    MU0_BW3(W`9))?=2,AE8$,I'<$$@CN#67]FB_P"?V#\G_P#B:V_!T$:>M)9
    M;F)RA?E4/D_FHH`YRBK'V:_G]@_)__`(FC[-%_SP?D_\`\30`67O;_KE
    M)_Z U5ZOVEO&)FQ=PMZDX ?X?]FH/LT7_/[!3_P#Q- %>K%E_KV_ZY2?
    M@-1]FB_Y_8/R?_XFI[2WC$S8NX6_=2<`/_</S0!0HJQ]FB_Y_8/R?\`)H^
    MS1?\_L'Y/_\`$T %M_J+S_KD/_0UJO5^WMXQ#=8NX3F(<@/Q\Z_[-0?9HO\`
    MG]@_)_\`XF@"O5BV_P!1>?\`7(?^AK1]FB_Y_8/R?_XFI[>WC$-UB[A.8AR
    M_'SK_LT`4**L?9HO?V#\G_)HS1?\`/[!3_\`Q- !;?ZB\_ZY#_T-:KU?
    MM[>,0W6N$YB'(#\?.O^S4'V:_G]@_)_P#XF@"O5BV_U%Y_UR'_`*&M'V:+
    M_G]@_)__`(FI[>WC$-UB[A.8AR 'SK`- %"BK'V:_G]@_)__`(FC[-%_
    MSP?D_\`\30`6WHO/\`KD/_`$-:KU?M[>,0W6+N$YB'(#\?.O\`LU!]FB_Y
    M_8/R?_XF@"O5A/\`D'S_`/76/3T?9HO?V#\G_^)J=+>/[#,/M<.#*G.'P.
    M'_V?\XH`H458S1?\_L'Y/\`_$T?9HO?V#\G_\`B: !/^0?/_UUC_D]5ZOI
    M;Q_89A]KAP94YP^!P_\`L_YQ4'V:+_G]@_)__B: *]6$_P"0?/\`]=8_Y/1]
    MFB_Y_8/R?_XFITMX_L,PUPX,J<X? X?_9_SB@"A15C[-%_SP?D_P#\31]F
    MB_Y_8/R?_P")H $_Y!\__76/3U7JEO']AF'VN'!E3G#X'#_P"S_G%0?9HO
    M?V#\G_)H "\DT_4:]A"M;RK@<9!D$9]N*NZW9QV$\MK 6:".ZF$L
    M<EX\(4;(X(*X((X(.15+[-%_SP?D_\`\36U>PKJ>AVUTMS#YMGYN&^<[U
    M54? 7@!0B'C&=G)+' image
    M\'_763257J]O']AA'VN' E?G#X/"?[/^<U!]FB_P"?V#\G_P#B: *]6'_Y
    M!\'_`%UD_DE'V:+_`)_8/R?_`.)J=[>/[#"/M<.!*_.'P>$_V?\`.: *%%6/
    MLT7_`#P?D__`,31]FB_Y_8/R?\`)H`'_Y!\'_763257J]O']AA'VN' E
    M?G#X/"?[/^<U!]FB_P"?V#\G_P#B: *]6'_Y!\'_`%UD_DE'V:+_`)_8/R?_
    M`.)J=[>/[#"/M<.!*_.'P>$_V?\`.: *%%6/LT7_`#^P?D__`,310!7JQ9?Z
    M]O\`KE)_Z U5ZL67O;_`*Y2?@-0!=\2?/KMUW_`%RD_P#0&H K
    MT5H6VCW$T"W4[Q6=FV=MQ<DJKX.#M !9\'@[0<9YP.:E^W6%AQIMK]HE_P"?
    MFC5O^8>4'4@[B_8C::`(=,LKJ_%W#96TUS+Y.=D*%VQO3G`J;_`(1V_'#M
    M8Q./O1RW\$;J?1E9P5(G=0W=[/+ L89(2Y\M#O4#:GW5 !P``
    M`!P*RJ -7_A&=:;F'3FYC[2VJ&>-OHZ94^G!X.15?[<61OH+N"6"9(EW1R
    MH589=",@\]#5M?3M7NH+XMW,=S:QQ?+!<()%4%UW!<\IG/)4@YP<Y ( ,B
    MBM7_`(E6H?\`4)N/!RVY_G(G V\DPBLYMI;.=H)TVR+CC((((R""."""
    M""."""* 'VWHO/N0_]#6J]6;_`%%Y_P!<A_Z&M5Z "K%M_JS_KD/_0UJ
    MO5BV_P!1>?\`7(?AK0!7HHHH L6WHO/^N0_P#0UJO5BV_U%Y_UR'_H:U7H
    M`*L)_P`@^?\`ZZQ_R>J]6$_Y!\__`%UC_D] %>BBB@"PG_(/G_ZZQ_R>J]6$
    M_P"0?/\`]=8_Y/5>@ JPG_(/G_ZZQ_R>J]6$_P"0?/\`]=8_Y/0!7HHHH L)
    M_P`@^?\`ZZQ_R>J]6$_Y!\__`%UC_D]5Z "M"UO)+""WGB"L?,F1E<<.K(JL
    MIQS@J2."#SP0>:SZL/\`\@^#_KK)_)* +&HZ=Y&Z[LUEETN1\0SL,XSDA'(&
    M!( .1[9&5()SZL6=Y)92ET"NCKLDB<921>ZL/3@'C!! (((!%W^RUU+]YHB2
    MR'HUF\BO.I_V0 #(".?E7*X.0 `S`%)_^0?!_P!=9/Y)5>K#_P#(/@_ZZR?R
    M2J] !5A_0?!_P!=9/Y)5>K#_P#(/@_ZZR?R2@"O1110!8?_`)!\'_76325
    M7JP__(/@_P"NLG\DJO0`58?_`)!\'_763^257JP__(/@_P"NLG\DH KT444`
    M6/LT7_/[!3_`/Q-3VEO&)FQ=PMZDX`?^X?]FJ%6+`%[?]<I/0&H`U(
    M>.Y\.W<'VN%WM)DN4X<!(V^20_=YRWD#'/3C'-9?V:+_`)_8/R?_`.)J[X=_
    M>:LEF>1?(]H%/W2\BE8RWL'-WQMR.0RJ ]I;QB9L7<?NI. '_N'_`&:@
    MS1?\_L'Y/\`_$T67O;_KE)_P"@-3K*P:\WNTL5O;QX\R>;=L4GH/E!))P<
    M``G@GH"0`%8B>5(H;F25V"HB)(2Q/ `&WDUK65O8:9Y:[M[V_5)-H30Q
    M$?O90B7OP#MX'@XJAJBV\3VVEUM"RE))\D37"]P_) 4\_(O'3)8J&JK9
    M?Z]ON4G_H#4`2W)>]G:>[U-)YGQNDE,C,<#`R2N>@J+[-%_SP?D_\`\35>
    MB@"_;V\8ANL7<)S$.0'X=?]FH/LT7_/[!3_P#Q-%M_J+S_`*Y#_P!#6J]
    M%C[-%_SP?D__P`34]O;QB&ZQ=PG,0Y ?CYU_P!FJ%6+;_47G_7(?AK0 ?9
    MHO\`G]@_)_\`XFM"VNHA`MGJ%TEW8IDI$'=6A.<YC8H0N3U&"#W&0I&/10!L
    MSZ9'9&X5;V*6&6!9(I=CC<A=<$\$9!!4@$X8$=C6=]FB_P"?V#\G_P#B:TM&
    ME6ZMK2KB1(HIMK1SR'B&3<JY)/1&R-QZ_*IYVX./%)!\4R-'C%71Q@J1
    MP01V- $WV:+_`)_8/R?_`.)J>WMXQ#=8NX3F(<@/Q\Z_[-4*L6WHO/N0_]
    M#6@`S1?\_L'Y/\`_$T?9HO?V#\G_\`B:KT4 7[>WC$-UB[A.8AR 'SKL
    MU!]FB_Y_8/R?_P")HMO]1>?]<A_Z&M5Z`'V:_G]@_)_P#XFITMX_L,P^UP
    MX,J<X? X?_9_SBJ%6$_Y!\__`%UC_D] !]FB_P"?V#\G_P#B:/LT7_/[!^3_
    M`/Q-5Z* Z6\?V&8?:X<&5.</@</_L_YQ4'V:_G]@_)_P#XFA/^0?/_`-=8
    M_P"3U7H`L?9HO?V#\G_`/B:G2WCPS#[7#@RISA\#A_]G_.*H583_D'S_\`
    M76/3T 'V:+_`)_8/R?_`.)HS1?\_L'Y/\`_$U7HH OI;Q_89A]KAP94YP^
    M!P_S_G%0?9HO?V#\G_`/B:$_Y!\_\`UUC_`)/5>@"Q]FB_Y_8/R?\`^)J=
    M[>/[#"/M<.!*_.'P>$_V?\YJA5A_^0?!_P!=9/Y)0 ?9HO\`G]@_)_\`XFC[
    M-%_SP?D_P#\35>B@#HVU"*(W.D_1?6FT[NP^=6P,!<=H?
    MLGAR?YO[1N[+''E5]IS[[L1XFT].O.!E/_`,@^#_KK)_)*KT :\FE::SDV
    M_B"T\KM]H@G1_P`0J,!^#'\.E2OI5G]AA']OZ=@2OSY=Q@\)_P!,O\YK#JP_
    M_(/@_P"NLG\DH N_V39?]#!IO_?NY_\`C5']DV7_`$,&F_\`?NY_^-5E44 ;
    MCZ59_881_;G8$K\7<8/"?],O\`.:@_LFR_Z&#3?=S\`&JI/_P`@#_K
    MK)_)*KT`:L^BQPV(O$U:QFB,GE#8LP);&3C=&,XXSCIN7/45"]O']AA'VN'
    ME?G#X/"?[/\`G-3:K_H]AI=B/E9(#<2IUQ)*<@Y]XA#P.!['-4G_`.0?!_UU
    MD_DE`!]FB_Y_8/R?_P")HJO10 58LO\`7M_URD_]`:C[-%_S^P?D_P#\34]I
    M;QB9L7<?NI.`'_N'_9H`H5J^(OWFK/>#D7R)=EA]TO(H:0\;<'D&J
    M7V:G]@)__`(FM64T@L+>)'LS>6^Y8;QO-WPH3N 0`!00S.=Q!(W#&"H-
    M`"6FG+I<S2:J`MPL4A73W5A(WR'!DZ;%Z\9W'C `8,,V]U&XOMB2-MMXLB&W
    M0GRX0>H4$\=!D]2>22<FI;2WC$S8NX6_=2<`/_</^S4'V:+_`)_8/R?_`.)H
    M`KU8LO\`7M_URD_]`:C[-%_S^P?D_P#\34]I;QB9L7<+?NI.`'_N'_9H`H45
    M8S1?\_L'Y/_`/$T?9HO?V#\G_)H +;_47G_7(?AK5>K]O;QB&ZQ=PG,0
    MY ?CYU_V:@S1?\`/[!3_\`Q- %>K%M_J+S_KD/_0UH^S1?\_L'Y/\`_$U/
    M;V\8ANL7<)S$.0'X=?]F@"A15C[-%_SP?D_P#\31]FB_Y_8/R?_P")H +;
    M_47G_7(?^AK5W7?WSV-\>'O;59''4[U+1,Q/<L8RY/JQZ]3#;V\8ANL7<)S$
    M.0'X^=?]FKJV\<WA=PUW#BTO5V$!\?O4.[/R_P#3!<8_VL]L`&'5BV_U%Y_U
    MR'_H:T?9HO\`G]@_)_\`XFI[>WC$-UB[A.8AR 'SKLT 4**L?9HO\`G]@_
    M)_\`XFC[-%_SP?D_P#\30`6WHO/N0_P#0UJO5WMXQ#=8NX3F(<@/Q\Z_
    M[-0?9HO?V#\G_\`B: *]6$_Y!\__76/3T?9HO?V#\G_\`B:G2WCPS#[7
    M#@RISA\#A_\`9_SB@"A15C[-%_SP?D__P`31]FB_P"?V#\G_P#B: !/0?/
    M_P!=8_Y/5>KZ6\?V&8?:X<&5.</@</\`[/\`G%0?9HO^?V#\G_\`B: *]6$_
    MY!\__76/3T?9HO?V#\G_\`B:G2WC^PS#[7#@RISA\#A_\`9_SB@"A15C[-
    M%_SP?D__P`31]FB_P"?V#\G_P#B: !/0?/_P!=8_Y/5>KZ6\?V&8?:X<&5
    M.</@</\`[/\`G%0?9HO^?V#\G_\`B: *]6'_`.0?!_UUD_DE'V:+_G]@_)__
    M`(FIWMX_L,(UPX$K\X?!X3_`&?\YH H458S1?\_L'Y/_\`$T?9HO\`G]@_
    M)_\`XF@`?_D'P?\`763257J]O']AA'VN' E?G#X/"?[/\`G-0?9HO^?V#\
    MG_\`B: *]6'_`.0?!_UUD_DE'V:+_G]@_)__`(FIWMX_L,(^UPX$K\X?!X3_
    M`&?\YH H458S1?\_L'Y/_\`$T?9HO\`G]@_)_\`XF@`?_D'P?\`76324[2
    M[^TM5L['S/TSI#OQG;N8#.._6I7MX_L,(UPX$K\X?!X3_9_SFKNDV\=K
    M:ZAJ!NX?W<)MHSA\>9,"N"-N?]7YI!]5&?0@&;J=[_:.I7-V(_*25R4BSD1I
    M_"@]E& .G %-?_D'P?\`76324?9HO\`G]@_)_\`XFIWMX_L,(UPX$K\X?!
    MX3_9_P`YH H458S1?\`/[!3_\`Q-% %>K%E_KV_P"N4G_H#57JQ9?Z]O\`
    MKE)_Z U %>BBB@"Q9?Z]ON4G_H#57JQ9?Z]ON4G_H#57H`L67^O;_`Y2
    M?@-5>K%E_KV_P"N4G_H#4 5Z***`%M_JS_KD/_0UJO5BV_P!1>?\`7(?
    MAK5>@ JQ;?ZB\_ZY#_T-:KU8MO\`47G_`%R'_H:T`5Z*** %M_JS_KD/\`
    MT-:NZ=^^T768&X2-(KL$==ZR",#Z8F;\0/?-*V_U%Y_UR'_H:U=T[]SHNLSM
    MRDB16@`Z[VD$@/TQ"WXD>^ #JQ;?ZB\_P"N0_\`0UJO5BV_U%Y_UR'_`&M
    M`%>BBB@"Q;?ZB\_ZY#_T-:KU8MO]1>?]<A_Z&M5Z`"K"?\@^?_KK'_)ZKU83
    M_D'S_P#76/\`D] %>BBK%G9R7LI1"J(B[Y)7.$C7NS'TY XR22 `20" "?\`
    M(/G_`.NL?\GJO6XCZ38V,P2*34Y5E3+2L8H2<.,!1\[#J0=R$Y&5&"#!_P`)
    M#>P\:=Y6F(.GV)?+?'<&3F1@3SAF(Z>@P 956$_Y!\__`%UC_D]7?^$GU[_H
    M-ZE_X%R?XU.GB76VL9C)JU[/-0%99FD5@0^5L2"#CD$8/>@##HK5_MF*?_
    M`(_]*L9R>#)$AMW5?]D1D)GK@LC>^0,4?V?:ZCSH[2B;O9W#KO/8>6_ D)/\
    M(4-\P #<D %)/^0?/_UUC_D]5ZMM%)!:744R-'DZZ.,%2 X(([&JE !5A_
    M0?!_P!=9/Y)5>K#_P#(/@_ZZR?R2@"O1110!8?_`)!\'_763257JP__(/@
    M_P"NLG\DJO0`58?_`)!\'_763^257JP__(/@_P"NLG\DH KT444`6'_Y!\'_
    M`%UD_DE7=:_T/R-(7_ERW>=[W#8\S_OG:J<$@^7N'WJL:1_H>G_VNW_+E*WD
    M]PP7R_=K/R"#Y>T_>K"H`*L/_`,@#_KK)_)*KU8?_D'P?]=9/Y)0!7HH
    MHH L?9HO?V#\G_)J>TMXQ,V+N%OW4G`#_W#_LU0JQ9?Z]O^N4G_H#4`'V:
    M+_G]@_)__B:/LT7_`#^P?D__`,35>B@"_:6\8F;%W"W[J3@!_P"X?]FH/LT7
    M_/[!^3__`!-%E_KV_P"N4G_H#57H`L?9HO\`G]@_)_\`XFI[2WC$S8NX6_=2
    M< /_`'#_`+-4L67^O;_`Y2?@-0 ?9HO\`G]@_)_\`XFC[-%_SP?D_P#\
    M35>B@"_;V\8ANL7<)S$.0'X=?\`9J#[-%_SP?D_P#\31;?ZB\_ZY#_`-#6
    MJ] %C[-%_P`_L'Y/_P#$U/;V\8ANL7<)S$.0'X=?]FJ%6+;_47G_7(?AK0
    M`?9HO?V#\G_`/B:/LT7_/[!3__`!-5Z* +]O;QB&ZQ=PG,0Y ?CYU_V:NW
    M5O';^']/M_M<M<2273$!\.F1&F?EYLDN,]`_'4U5T>T%Y+<122B" 1!IIB
    M,B)/,3+8[X[#J3@#DBJ^I7O]H7\MP(_C.%BCSN\N-0%1<]\ ,GDXR:`&_9
    MHO\`G]@_)_\`XFI[>WC$-UB[A.8AR 'SKLU0JQ;?ZB\_ZY#_T-: #[-%_S
    MP?D_P#\31]FB_Y_8/R?_P")JO10!?M[>,0W6+N$YB'(#\?.OS4'V:+_G]@
    M_)__`(FBV_U%Y_UR'_H:U7H`L?9HO?V#\G_`/B:G2WCPS#[7#@RISA\#A_
    M]G_.*H5H:?9R7\$L$153YBNS.>$54D9F..<!03P">. 3Q0!)9:7;R1R7=U>1
    MBS@95D\L/N9F#%4&5XSM;YL$``G!.%*WER+B(6L-Y%!8(VZ.V!D(STWM\HW.
    M<G8]A@``5]2O(>/[#,/
    MM<.#*G.'P.'_`-G_`#BH/LT7_/[!3__`!-"?\@?_KK'_)ZKT 6/LT7_/[!
    M3__`!-3I;Q_89A]KAP94YP!P_S_G%4*L)_P`@?\`ZZQ_R>@`^S1?\_L'
    MY/\`_$T?9HO^?V#\G_\`B:KT4 =!%-!>:6]KJ%[!M1D6&Y6)MT9"L%#D)N=<
    M8'.2H QTVMF7.F_8YV@GNH%D7''SD$$9!!"X(((((X(((J)/^0?/_P!=8_Y/
    M5JQECOEATV\=44MMM[ES@0$GHQ_YYDG)_NDEA_$&`*OV:+_G]@_)_P#XFIWM
    MX_L,(UPX$K\X?!X3_9_SFJ4L4D$KQ3(T<J,5='&"I'!!'8U,_\`R#X/NLG
    M\DH`/LT7_/[!3__`!-'V:+_`)_8/R?_`.)JO10!?>WCPPC[7#@2OSA\'A/
    M]G_.:@S1?\`/[!3_\`Q-#_`/(/@_ZZR?R2J] %C[-%_P`_L'Y/_P#$U.]O
    M']AA'VN'`E?G#X/"?[/<U0JP_\`R#X/NLG\DH`/LT7_/[!^3__`!-/BL1/
    MD4-S%)[!41$D)8G@`#;R:J5JVO_$LTU[UO^/B\22"W7NB'"R2'/4$%HQP>
    M=YR"@R 6M6BM8K&TL(RW962423*699I3MW,N >,!5'8A0W!) R/LT7_/[!
    M3__`!-#_P#(/@_ZZR?R2J] %C[-%_SP?D__P`34[V\?V&$?:X<"5^</@\)
    M_L_YS5"K#_\`(/@_ZZR?R2@`S1?\_L'Y/\`_$T57HH`*L67O;_`*Y2?^@-
    M1LL_>\__?D?_%5/:):<VV:8GRI.L0'&PY_BH H458V6?\`SWG_`._(_P#B
    MJ-EG_P`]Y_\`OR/_`(J@`LO]>W_7*3_T!JKU?M$M?.;;-,3Y4G6(#C8<_P`5
    M0;+/_GO/_P!1_\`%4 5ZL67O;_`*Y2?@-1LL_>\__?D?_%5/:):^<VV:
    M8GRI.L0'&PY_BH H458V6?\`SWG_`._(_P#BJ-EG_P`]Y_\`OR/_`(J@`MO]
    M1>?]<A_Z&M5ZOVZ6ODW6)IB/*&<Q#@;U_P!JH-EG_P`]Y_\`OR/_`(J@"O5B
    MV_U%Y_UR'_H:T;+/_GO/_P!1_\`%5/;I:3=8FF(\H9S$.!O7_:H H4Z**2
    M>5(H4:25V"HB#)8G@ #N:MVUG!>3K!!+.TC9X\I0``,DDE\```DD\ `DU=DD
    MT[3HY;>RO9)YI 5DNXX,#81RB!B",\AB0"?NC SO`#?%8Z;?V$+)--(B-<3H
    M05&UUQ&A'5<G+'H2%QPH9L6K]NEKY-UB:8CRAG,0X&]?]JH-EG_SWG_[\C_X
    MJ@"O5BV_U%Y_UR'_`&M&RS_`.>\_P#WY'_Q53VZ6ODW6)IB/&<Q#@;U_VJ
    M`%%6-EG_P`]Y_\`OR/_`(JC99_\]Y_(H +;_47G_7(?^AK5>K]NEKY
    M-UB:8CRAG,0X&]?]JH-EG_SWG_[\C_XJ@"O6VH;3_"LK!L2ZE(@X_Y86P<
    M_P"U(A]"/]&K,V6?_/>?_OR/_BJV_$VPU/5H3*(XM;= (@=B1AT11\W.
    M%4#)YXYSF@#G**L;/\`Y[S_`/?D?_%4;/_`)[S_P#?D?\`Q5 `G_(/G_ZZ
    MQ_R>J]7T2UPS?OIMOFID4,YP_^U]:@V6?_`#WG_P"_(_\`BJ *]6$_Y!\_
    M_76/^3T;/\`Y[S_`/?D?_%5.B6OV&;]]-M\U,GRAG.'_P!KZT 4**L;/\`
    MY[S_`/?D?_%4;+/_`)[S_P#?D?\`Q5 `G_(/G_ZZQ_R>J]7T2U^PS?OIMOFI
    MD4,YP_U]:@V6?_`#WG_P"_(_\`BJ +NJ?Z=:V^JKS(_P"YNO:51PY_WUP<
    MDY9UD/:J3_\`(/@_ZZR?R2M324M;FUU#3_.F(EA-PF8@`KP@ON]G_5:H'3
    M+#/3(I.EK]AA_?3;?-?!\H9SA/\`:^E %"BK&RS_`.>\_P#WY'_Q5&RS_P">
    M\_\`WY'_`,50`/\`\@#_KK)_)*KU?=+7[##FV:^#Y0SG"?[7TJ#99_\`
    M/>?_`\C_P"*H KU8?\`Y!\'_763^24;/\`Y[S_`/?D?_%5?M"#4%M6.X
    MD7S)G'F/$ J#"[F;YN%4#)/8`GM0!5TVSCN)?.NRT=A"RFXD4X.#_"N>KM@X
    M'L2<`$B]O)+^Z:>4IVJBJ@X154*JC/. H`Y)/'))YJY=7-BT"6EK+<QVJ$
    M,<PKNE?&-[?/[D =%!/4EF:GLL_>\__`'Y'_P`50 /_`,@#_KK)_)*KU?=
    M7[##^FV:#Y0SG"?[7TJ#99_\]Y__(_*H KU8?_`)!\'_76324;/_
    M`)[S_P#?D?\`Q53NEK]AA_?3;?-?!\H9SA/]KZ4`4**L;+/_`)[S_P#?D?\`
    MQ5% %>K%E_KV_P"N4G_H#57JQ9?Z]O\`KE)_Z U %>BBB@"Q9?Z]O^N4G_H#
    M57JQ9?Z]ON4G_H#57H`*L67O;_`Y2?^@-5>K%E_KV_P"N4G_H#4 5Z**
    M`%M_JS_KD/_0UJO5BV_P!1>?\`7(?^AK4,44D\J10HTDKL%1$&2Q/ `'<T
    M`-K7T[3':RN+J]<V=D\7RS.A)EPZY$8_B/!'90<`E<BF_9K?2?FOTBNKSI]B
    M)<"(]_-(P<XZIR#G<05M7^TRWAOIYWW2-$O. ``'0``#@````#@ `"@!]S
    MJK/ UI91_8K)L;XHW8F;!X,A/WB,#L%!R0JY.<^BB@"Q;?ZB\_ZY#_T-:KU8
    MMO\`47G_`%R'_H:U7H *L6WHO/N0_]#6J]6+;_`%%Y_P!<A_Z&M %>BBB@
    M"Q;?ZB\_ZY#_`-#6J]6+;_47G_7(?^AK5>@#0T*VBO=?TRUN$WPS744<BY(R
    MI< C(YZ&F3W,M[#>W5P^^::Y621L`98[R3@<=33-O?[-U6SOO\S[-.DVS.
    M-VU@<9[=*LZC9?V;)J=CYGF?9KP0[\8W;?,&<=NE`&91110!83_D'S_]=8_Y
    M/5>K"?\`(/G_`.NL?\GJO0`583_D'S_]=8_Y/5>K"?\`(/G_`.NL?\GH`KT4
    M44 6$_Y!\_\`UUC_`)/5>K"?\@^?_KK'_)ZKT 6M,O?[.U*VNS'YJ1."\6<"
    M1/XD/LPR#UX)JSJUE_9Q:T$GFI%<RA)<8$B83:X]F&".O!%9E;6K2B[T/2+K
    M!\S]Y;2L>-S1A I Z8$9B7ZJ<I ,6BBB@"P_P#R#X/NLG\DJO5A_\`D'P?
    M]=9/Y)3:UNV=82"6>9\[8XD,<#)P!ST%`#(HI)Y4BA1I)78*B(,EB> `
    M.YK8OY$L='@L;64,SN_VR1"&5W&TA%8=4'RYQP6!.6 0BO++'ID3VUJZR73J
    M4GN$.0H/!CC(ZCLS#KT'RY+U7_Y!\'_76324 5Z*** +#_\@#_`*ZR?R2J
    M]6'_`.0?!_UUD_DE5Z "K#_\@^#_`*ZR?R2J]6'_`.0?!_UUD_DE`%>BBB@"
    MQLL_>\__?D?_%5/:):<VV:8GRI.L0'&PY_BJA5BR_U[?\`7*3_`- :@ V6
    M?_/>?_OR/_BJ-EG_`,]Y_P#OR/\`XJJ]% %^T2U\YMLTQ/E2=8@.-AS_`!5!
    MLL_>\__`'Y'_P`519?Z]O\`KE)_Z U5Z +&RS_Y[S_]1_\54]HEKYS;9IB
    M?DZQ <;#G^J%6++_7M_P!<I/\`T!J #99_\]Y_(*HV6?\`SWG_`._(
    M_P#BJKT4`;.F:;'>17C1S2I;I&OG7$D($<0+`@DACZ' ZGH`3@$-WIMK;M!I
    M[7 =UR7<D $K>J@"0A%(P#C'YOFPQ6HMOS#:7=M<1BXLV3<T38!!+("4
    M;!*-TY'!VKN#`8J.YTU1`UW83_:K1<;BP5)8^<?/&&) R1\P)7YE&<G:`"OL
    ML_\`GO/_`-1_P#%5/;I:3=8FF(\H9S$.!O7_:JA5BV_P!1>?\`7(?^AK0`
    M;+/_`)[S_P#?D?\`Q5&RS_Y[S_\`?D?_`!55Z* +]NEKY-UB:8CRAG,0X&]?
    M]JH-EG_SWG_[\C_XJBV_U%Y_UR'_`*&M5Z +&RS_`.>\_P#WY'_Q53VZ6ODW
    M6)IB/*&<Q#@;U_VJH58MO]1>?]<A_P"AK0`;/\`Y[S_`/?D?_%4;/_`)[S
    M_P#?D?\`Q55Z* +]NEKY-UB:8CRAG,0X&]?]JH-EG_SWG_[\C_XJBV_U%Y_U
    MR'_H:U7H`L;/_GO/_WY'_Q5;>OK;/=WD[2RAKIHN3$0P'EB,A ^;IES].!
    MSUKGVYY%NO"5O)G][:3BV=1P A\R1#[DLTHX[.!U(!F;+/_GO/_P!^1_\`
    M%4;+/_GO/_WY'_Q55Z* Z):_89OWTVWS4R?*&<X?_:^M0;/_GO/_WY'_Q5
    M"?\`(/G_`.NL?\GJO0!8V6?_`#WG_P"_(_\`BJG1+7[#-^FV:F3Y0SG#_[
    M7UJA5A/0?/_`-=8_P"3T &RS_Y[S_\`?D?_`!5&RS_Y[S_]1_\55>B@"^B
    M6OV&;]]-M\U,GRAG.'_VOK4&RS_Y[S_]^1_\50G_`"#Y_P#KK'_)ZKT`6-EG
    M_P`]Y_\`OR/_`(JMJTCM;KPU=6@DD+Q2F[B;R@7(4*LBJ-W=6#D@](N1QD<[
    M6KI=Y'826,\X9K?SY$G5!R\3JR/<J6'4=>HZT`4MEG_P`]Y_\`OR/_`(JC
    M99_\]Y_(HO[.33]0N;8JTMOT3E#D$J2#CVXJQ;:4SP+=WLGVR;.R
    M61&)FP>1&!]XC![A0< LN1D`EALXKR"W@@DF9FED(_=J,852226P``,DDX R
    M3@"G3S:?;V[V5E<S,C'$]P(0#/@Y`&6!"# (!Y)&3T4*7FHC^R4M=/66TLGE
    M?S(C-O,I`0@R$ !L'H,`#TSDG(H`L;+/_GO/_P!^1_\`%5.Z6OV&']]-M\U\
    M'RAG.$_VOI5"K#_\@^#_`*ZR?R2@`V6?_/>?_OR/_BJ-EG_SWG_[\C_XJJ]%
    M`%]TM?L,/[Z;;YKX/E#.<)_M?2H-EG_SWG_[\C_XJA_^0?!_UUD_DE5Z`+&R
    MS_Y[S_\`?D?_`!53NEK]AA_?3;?-?!\H9SA/]KZ50JP__(/@_P"NLG\DH -E
    MG_SWG_[\C_XJBJ]%`!5BR_U[?]<I/_0&HV6?_/>?_OR/_BJGM$M?.;;-,3Y4
    MG6(#C8<_Q4 4**L;/\`Y[S_`/?D?_%4;/_`)[S_P#?D?\`Q5 !9?Z]O^N4
    MG_H#57J_:):^<VV:8GRI.L0'&PY_BJ#99_\`/>?_`+\C_P"*H KU8LO]>W_7
    M*3_T!J-EG_SWG_[\C_XJI[1+7SFVS3$^5)UB`XV'/\5 %"BK&RS_`.>\_P#W
    MY'_Q5&RS_P">\_\`WY'_`,50`6WHO/N0_]#6F6UU<64ZSVD\L$R9VR1.58
    M9&#@CGH:M6Z6ODW6)IB/*&<Q#@;U_P!JH-EG_P`]Y_\`OR/_`(J@"[MLM6Y5
    MHK"/+!VVP3'_9P,1'..IV<GE `#7RW%D;Z"[@E@F2)=T<J%6&70C(//0U%
    MLL_>\__`'Y'_P`56MIII%9S6TTCWMG''D6]S#E4RX)VD.&7)()"E<XYSC%
    M`&#16VFDZ??[FTN^E:0GBSFC59L>BG<%DZ@`##,>B5GRV]O!\4TES'C%71
    M[< J1P01NX- #+;_`%%Y_P!<A_Z&M5ZOVZ6ODW6)IB/*&<Q#@;U_VJ@V6?\`
    MSWG_`._(_P#BJ *]6+;_`%%Y_P!<A_Z&M&RS_P">\_\`WY'_`,54]NEKY-UB
    M:8CRAG,0X&]?]J@"A15C99_\]Y_(*HV6?_/>?_OR/_BJ`"V_U%Y_UR'_
    M`&M5ZOVZ6ODW6)IB/&<Q#@;U_VJ@V6?_/>?_OR/_BJ`];FA+FQU*P8 M
    M=HBR,D2H&==H[LVTQC'/[P]>AR]EG_SWG_[\C_XJKME-%91BYMKF9)8;B1
    M'\E259=Q'!;!_&@#*HK7UFST^UU298))HX) L\,8C#;(Y%#HI);J%8 ^X/6J
    M&RS_`.>\_P#WY'_Q5 `G_(/G_P"NL?\`)ZKU?1+7[#-^FV:F3Y0SG#_P"U
    M]:@V6?\`SWG_`._(_P#BJ *]6$_Y!\__`%UC_D]&RS_Y[S_]^1_\54Z):_89
    MOWTVWS4R?*&<X?\`VOK0!0HJQLL_^>\__?D?_%4;+/\`Y[S_`/?D?_%4`"?\
    M@^?_`ZQ_P`GJO5]$M?L,W[Z;;YJ9/E#.</_`+7UJ#99_P#/>?\`[\C_`.H
    M`KU8?_D'P?\`763^24;+/_GO/_WY'_Q53NEK]AA_?3;?-?!\H9SA/]KZ4 7K
    MNTN5HM0D1KNEB02VLBE8@X&UG>0,&=FV[\#'+\L<$''N;F6\G:>=]TC8YP
    M```,``#@````#@``"G[+/_GO/_WY'_Q5&RS_`.>\_P#WY'_Q5 `__(/@_P"N
    MLG\DJO5]TM?L,/[Z;;YKX/E#.<)_M?2H-EG_`,]Y_P#OR/\`XJ@"O5A_^0?!
    M_P!=9/Y)1LL_>\__?D?_%5.Z6OV&']]-M\U\'RAG.$_VOI0!0HJQLL_>\_
    M_?D?_%4;+/\`Y[S_`/?D?_%4`#_\@#_`*ZR?R2J]7W2UPP_OIMOFO@^4,Y
    MPGU]*@V6?\`SWG_`._(_P#BJ *]6'_Y!\'_`%UD_DE&RS_Y[S_]1_\54[I
    M:_88?WTVWS7P?*&<X3_:E %"BK&RS_Y[S_]1_\510!7JQ9?Z]O^N4G_H#5
    M7JQ9?Z]ON4G_H#4`5Z*** +%E_KV_ZY2?\`H#57JQ9?Z]ON4G_`* U5Z "
    MK%E_KV_ZY2?@-5>K%E_KV_ZY2?@-0!7HHHH L6WHO/N0_P#0UJO5BV_U
    M%Y_UR'_H:U7H`*L6WHO/N0_P#0UJO5BV_U%Y_UR'_H:T 5ZTHM9D>)+?48
    MEO[=%"()3B2)1P`DG4 #.%.4!.=IK-HH`W+>TTV]ANC8W9M7:(#[/>GOO7&)
    M5&TY(Y+!`,CD@%AFWNFW>G[#<Q8CDSY<J,'CDQUVNI*MC.#@G!X--MO]1>?]
    M<A_Z&M.LM3O=.WBSN984DQYD:M\D@'9UZ,.3P01R?6@"K5BV_P!1>?\`7(?^
    MAK5WT--N.;[2=LG4O8S1O)ZEE974>P0*!SQTQ/;V.E30W7V;6#'^Z&XWMJ
    MT?\`&N,>69,].<XZCKS@`PZ*U?\`A&]5?_CVM?MN/O?89$N=G^]Y9;;GMG&<
    M''0UE4 6+;_47G_7(?\`H:U7JQ;?ZB\_ZY#_`-#6J] !5A/^0?/_`-=8_P"3
    MU7JPG_(/G_ZZQ_R>@"[<_P"E^'K*<<O9.UI(!P%1B9(S[DDS=.RCIWRJU=$_
    MTG[9IIYUP'R@><2I\Z87NS;3&,<_O#C.<'*H L)_P`@?\`ZZQ_R>J]6$_Y
    M!\__`%UC_D]5Z "K"?\`(/G_`.NL?\GJO5A/^0?/_P!=8_Y/0!7HHHH`L)_R
    M#Y_NL?\GJO5A/\`D'S_`/76/3U7H L/\`\@^#_KK)_)KU8?_`)!\'_76
    M3^24`5Z*** +#_\`(/@_ZZR?R2J]6'_Y!\'_`%UD_DE5Z "K#_\`(/@_ZZR?
    MR2J]6'_Y!\'_`%UD_DE %>BBB@"P_P#R#X/^NLG\DJO5A_\`D'P?]=9/Y)5>
    M@ JP_P#R#X/^NLG\DJO5A_\`D'P?]=9/Y)0!7HHHH L;+/\`Y[S_`/?D?_%5
    M/:):^<VV:8GRI.L0'&PY_BJA5BR_U[?]<I/_`$!J`#99_P#/>?\`[\C_`.*H
    MV6?_`#WG_P"_(_\`BJKT4 7[17SFVS3$^5)UB XV'/\50;/_GO/_WY'_Q5
    M%E_KV_ZY2?\`H#57H L;+/\`Y[S_`/?D?_%5/:):^<VV:8GRI.L0'&PY_BJA
    M5BR_U[?]<I/_`$!J`#99_P#/>?\`[\C_`.*HV6?_`#WG_P"_(_\`BJKT4 7[
    M=7R;K$TQ'E#.8AP-Z_[50;/_GO/_WY'_Q5%M_J+S_KD/\`T-:KT 6-EG_S
    MWG_[\C_XJI[=+7R;K$TQ'E#.8AP-Z_[54*L6WHO/N0_P#0UH -EG_SWG_[
    M\C_XJC99_P#/>?\`[\C_`.*JO10!?MTM?)NL33$>4,YB' WK_M5!LL_^>\__
    M`'Y'_P`51;?ZB\_ZY#_T-:KT`6-EG_SWG_[\C_XJI[=+7R;K$TQ'E#.8AP-Z
    M_P"U5"K%M_JS_KD/_0UH -EG_SWG_[\C_XJM7_A(KQ^C5KR\3M'>P+<H#Z
    MA9&8`^^,\GUK"HH`Z.#68)8KD75O:7,0C!*?V?'!_$O.8F1C],X_(5#]NT";
    MY;C2WB0<@V3/&^?<R/(,?@#TY['MO\`47G_`%R'_H:U7H W?-\_P#/IK/_
    M`(%1?_&ZF67PQ]CEQ::QY?F)G_2HLYPV/^6?U_2N<JPG_(/G_P"NL?\`)Z -
    MNUOO#5E=0W5O;ZRDTK)&WVF$X8'(.#'CJ*R;HZ==326YG@A=V:.+RPWEJ3
    MPN2V3@<9JE10!?17[#-^FV:F3Y0SG#_[7UJ#99_\`/>?_`\C_P"*H3_D
    M'S_]=8_Y/5>@"QLL_P#GO/\`]^1_\54Z):_89OWTVWS4R?*&<X?_`&OK5"K"
    M?\@?_KK'_)Z`#99_P#/>?\`[\C_`.*HV6?_`#WG_P"_(_\`BJKT4 7T2UP
    MS?OIMOFID4,YP_U]:@V6?_`#WG_P"_(_\`BJ$_Y!\__76/^3U7H L;+/\`
    MY[S_`/?D?_%5.Z6OV&']]-M\U\'RAG.$_P!KZ50JP_\`R#X/^NLG\DH`-EG_
    M`,]Y_P#OR/\`XJC99_\`/>?_`\C_P"*JO10!?=7[##^FV:^#Y0SG"?[7
    MTJ#99_\`/>?_`\C_P"*H?\`Y!\'_763^257H L;/\`Y[S_`/?D?_%5.Z6O
    MV&']]-M\U\'RAG.$_P!KZ50JP_\`R#X/^NLG\DH`-EG_`,]Y_P#OR/\`XJC9
    M9_\`/>?_`\C_P"*JO10!?=7[##^FV:^#Y0SG"?[7TJ#99_\`/>?_`+\C
    M_P"*H?\`Y!\'_763^257H L;+/\`Y[S_`/?D?_%5.Z6OV&']]-M\U\'RAG.$
    M_P!KZ50JP_\`R#X/^NLG\DH`-EG_`,]Y_P#OR/\`XJBJ]% !5BR_U[?]<I/_
    M`$!J** ]%%%`%BR_P!>W_73_T!JKT44 %6++_7M_URD_\`0&HHH KT444`
    M6;_`%%Y_P!<A_Z&M5Z** "K%M_JS_KD/\`T-:** *]%%% %BV_U%Y_UR'_
    M`&M5Z*`"K%M_JS_KD/_0UHHH`KT444 6;_47G_7(?^AK5>BB@ JPG_(/
    MG_ZZQ_R>BB@"O1110!83_D'S_P#76/\`D]5Z** "K"?\@^?_`*ZQ_P`GHHH`
    MKT444 6$_P"0?/\`]=8_Y/5>BB@`JP__`"#X/^NLG\DHHH KT444`6'_`.0?
    M!_UUD_DE5Z**`"K#_P#(/@_ZZR?R2BB@"O1110!8?_D'P?\`763^257HHH *
    5L/\`\@^#_KK)_)*** *]%%% '__9
    end
    Don
    "Warren Brayshaw" <warrenbrayshaw@paradise.net.nz> wrote in message
    news:i5bss0$khm$1@cheetah.cadsoft.de...
    "Don Golding" wrote >
    >>together
    >> copy
    Don
    Although not what you have said, are notches 2 and 3 in the attached image
    Warren
    Don
    Warren
    M_]C_X `02D9)1@`!`0$!+ $L``#_VP!#``@&!@<&!0@'!P<)"0@*#!0-# L+
    M#!D2$P\4'1H?'AT:'!P@)"XG("(L(QP<*#<I# Q-#0T'R<Y/3@R/"XS-#_
    MVP!#`0D)"0P+#!@-#1@R(1PA,C(R,C(R,C(R,C(R,C(R,C(R,C(R,C(R,C(R
    M,C(R,C(R,C(R,C(R,C(R,C(R,C(R,C+_P `1" #[`0`#`2(``A$!`Q$!_\0`
    MU=;7V-G:XN/DY>;GZ.GJ\O/T]?;W/GZ_]H`# ,!``(1`Q$`/P#WBBB@ HH
    MHH **** "BBB@ HHHH **R]2\0Z9I5PMK<3R/=L@D%K:P27$^S)&\QQJSA,C
    M&[&,X&<D53_M'Q+>_P#'GH,%A&?D,FIWB^8A_OB*$.KJ,C@RH201\HPQ`.@H
    MKG_[!U:Z^;4/%%]\_$L%A#%;PLO3"DJ\R9'4B7=DDJ5X`/\`A"?#LG_'[I_]
    MIXY_:LTE]Y?KL\]GV9XSMQG`SG H T-3UW1]$\KUM5L;#SL^7]KN$BWXQG
    M&XC.,CIZBC3-=T?6_-_LG5;&_P#)QYGV2X279G.,[2<9P>OH:SY;71_"%FSZ
    M-HEC;W5Y+';QP6D*0&XD)(7<57.U06=B`Q5%=L'!%:&F:9]A\VXN)OM.H7&#
    M<7)7;NQG:BKD[(UR=JY.,DDLS,S $FI:MINC6ZW&J:A:6,#.$62ZF6)2V"<`
    ML0,X!./8U8@GANK>XMY8YH)4#QR1L&5U(R""."".<U7U+38=3MUCD:22-Q
    M)!<1$"2"0 @.A((S@D$$$$$JP*D@\WI_AWPWJEY?PZMX7T-]7MY0;J3[!'BX
    MWC<)UW MM?+#DG#K(NYMNX@'845S_P#PB%E!\VG7VJZ=(O$7V>_D:.$?W4@D
    M0A<<!=F%'W0" 0?8?$NG?-9ZO!JL8Y,.IQ%(Q/&!-"H5%'!P86).1D`C:
    M=!17/_\`"17EC\NLZ#?6^.//L$-]"S=0%$8\[IU1*H((R?E;%C?V>IV<=Y
    M87<%W:R9V302"1&P2#AAP<$$?A0!8HHHH **** "BBB@`HHHH **** "BBB@
    M`HHHH **** "BHYYX;6WEN+B6.&")"\DDC!510,DDG@`#G-8?VO4?$/_`""Y
    M_L.DMRNI(5::?'>%'1D\LG&)&SN .U<,DE %S4M=MM/N%LHTDO=3=!(FGVK(
    M9V3)!<AF4*@P?F8@9PH)8@&G_96L:OSK-_\`8[<_\N.E3.F?]^XPLC<@,-@B
    MQDJV\5J:;I5CI%NT%A;1P([F20KRTKD`%W8\NYP,LQ)/<FKE`%/3=*L=(MV@
    ML+:.!'<R2%>6E<@`N['EW.!EF))[DU<HHH **** .?\`$W[J\.7K\6]MJJ
    M:_\`=\V&:!..IS)-&O'3=DX`)'05'/!#=6\MO<11S02H4DCD4,KJ1@@@\$$<
    M8K#\S6="_<1V$^M6`XA>X3[7&.R/YKKJ,']YOWG*@JQ#2$`Z"N?T[]_P".
    M=>N8_FABM.R=NF)D,TKCV2>(YZ?-C.00#[=KVJ_P"CV^D3Z-&>);N]EA>1
    M`>\,<;2S<$9<J%)4XD`UL6-C;Z=9QVMK'Y<*9(!8L22269F.2S$DDL2222
    M2230!8HKC_"OB?6-7\7*-%U:SL;;R?LGEK:2OGS8V<Y=@N[H.BC)'/6N
    MPH *Q[[PSIUY>27T8GLK]\%KNQF:%W8`!#(%.V7;C@2!U'(Q@D'8HH Y_P"U
    M:[HO%];_`-KV*_\`+U:(%N8U]9(>DF "2T9#,2 L-;%C?V>IV<=Y87<%W:R9
    MV302"1&P2#AAP<$$?A5BL>T!)+R34=,G_LW4Y,>;<0Q*PN0``JSJ1\48'.
    M5<#(5UW'(!L45CV.N9O(]-U>.#3]5DR8H!/YB7"@$DPN54O@`[AM#+CD;2K-
    ML4 %%%% !1110 4444 %%%% !1110 57OKZWTZSDNKJ3RX4P"0I8DD@*JJ,E
    MF)(`4 DD@ $FB^OK?3K.2ZNI/A3`)"EB22 JJHR68D@!0"22 `2:S[&QNV
    M\CU758_F3)M,L&%H"""S$9#3$$@L,A02BD@N\@!'!87VJW$5YK(CCMXW$U
    MMIJKGRW!RK3.&(D=<!@%`5&)YDHXW** "BBB@`HHHH`**** "BBB@`HHHH
    M`Y?0_#=YIGCOQ7KDTD#6NK_8_LZ(Q+KY411MP(P,D\8)_"NHHHH`****`"BB
    MB@"O?6-OJ-G):W4?F0O@D!BI!!!5E88*L" 0P(((!!!%9<%Y?:1<16NLW$=S
    M;S.([;4%B\OYR<+', <!VXPZ[59B5VH=@?<J.>"&ZMY;>XBCF@E0I)'(H974
    MC!!!X((XQ0!)16'!/-H5Q%8WTLDVGRN([2\E8LT;$X6&9CR23@)(?O<*WS[6
    MEW* "BBB@ HHHH **** "BBN?US_`(G5Y_PC4?,$D0DU4]"+5Q(H13_>D9"O
    M`X19.48H2 %G_P`5)>&E;2>56L$'WM@`PN#_`'E#9$8QM^7S`6S&4Z"B
    MB@`HHHH`***`"BBB@`HHHH`**`"BBB@`HHHH`***`"BBB@`HHHH`KWUC
    M;ZC9R6MU'YD+X) 8J000596&"K @$,""" 0016?I-]<)>3Z1J4F[@:WF90
    MIO(,^]P/EW*S;'"]P&VHLB6Q67KNFS:A9))9-&FIV;FXL))2=BS;&4!P`<
    MHRNRMQG#$KA@" #4HJGI>I0ZM8=PK(@O&\<@`:.1'*.AP2,JRLN02#C()&
    M#5R@`HHHH **** *>JZE#I&EW%_.LCI"F1'$`7E;HJ("1N=F(51W) [U7T+3
    M9M/LGDO6C?4[QQ<7\D1.QIMBJ0@(&$5455XSA06RQ)-/4/\`B9^+;#3#\]K8
    MQ'4+E.WF%MEN&!X9<B=\`9#PQG(XW=!0`4444 %%%% !1110`4444 %%%% !
    M1110`4444 %%%% !1110`4444 %%%% !1110!S]Q_P`2Q''=Q8:O+Y=T3R
    M(5TV'5]N"=I$29,"2(@/$W570D':ZL
    M`RGL0#VJOX<U*;5O#]G=W2QI>%#'=QQ@A8[A"4F09)X6177.2#C()'- &I11
    M10`445S_`(T_?^%[K3%YFU;&FQ@<L/..QG"_Q;$+R$?W8VY R0`'@[_2=#_M
    MAN9-9E;4-QX)C? @##H&6!84('&5)R22QZ"BB@`HHHH`****`"BBB@`HHHH`
    M***`"BBB@`HHHH`**`"BBB@`HHHH`***`"BBB@`KG[?_`(EWCF[MAQ#J
    MUH+U%7G]]"5BE9B>F4>U``X_=L<`\MT%<_XK_P!&BTK5SS'IFH1SR@\`1NKP
    M.[-_"J,TA)XQ&<X!R #H**** "N?U?_`$KQ?X<LON^1]IU?UW>7&(-F.V?
    MM>[/QC'S9'05S]M\^(>I[_`)O(TJT\K=SY?F2W._;Z;O+CSCKL7/W10!T%
    M%%% !1110 4444 %%%% !1110 4444 %%%% !1110 4444 %%%% !1110 44
    M44 %%%% !6?KNF?VWX>U/2?.\G[=:2VWF[=VS>A7=C(SC.<9%:%%`&?H6I_V
    MWX>TS5O)\G[=:17/E;MVS>@;;G SC.,X%:%<_P"#/E\/O$.(X=0OH(D'2.-+
    MN5$11V5555 '```'`KH`"N?T#]YX@\52O\`-(FH10YY*QBT@<(#_=#22,!
    MTR['J36K?1ZC)Y?V"ZM8,9W^?;-+GIC&'7'?U_"N8T*#6SK'B<1:CIZN-302
    MEK%V#-]DM^5'G#:-NT8.>03GG EM]C6-.5W-G\0_P#04TO_
    M`,%LG_QC[/XA_Z"FE_"V3_`./T<S[?E_F5[&'_`#\7_DW^1K45D_9_$/\`
    MT%-+_P#!;)_\?HS(?@II?_@MD_P#C]',WY?YA[&'_/Q?^3?Y&M163]G\
    M0_\`04TO_P`%LG_QC[/XA_Z"FE_"V3_P"/T<S[?E_F'L8?\_%_Y-_D:U%9
    M/V?Q#_T%-\%LG`,?HS(?^@II?\`X9/_C]',WY?YA[&'_/Q?\`DW1
    MK45D_9_$/_04TO\`\%LG_P`?HS(?\`H*:7_P""V3_X_1S/M78>QA_P`_
    M%_Y-_D:U%9/V?Q#_`-!32_\`P6R?_'Z/L_B'_H*:7_X+9/\`X_1S/M78>Q
    MA_S\7_DW1K57O;R.P@6:56*M-%"`HYS(ZH/PRPS[51S(?@II?_@MD_\`
    MC]<OK6JZO=6$7V.ZM=2@%W;'SK73RL>[STV@2/<!7887.""&=1$ZGMCH
    MPV#56HESJUU??\[6]#OJYVQN]6U'S!;:UI9DCQYD3Z7DD><XW(TP9<XR,@
    M9'(XJY]G\0_]!32__!;)_P#'ZI3OJE79C#J#Y932?I_Y$UJ*R?L_B'_H
    M*:7_`."V3_X_1]G\0_\`04TO_P`%LG_QGS/M7^9/L8?\_%_P"3?Y&M163]
    MG\0_]!32_P#P6R?_`!C[/XA_P"@II?_`(+9/_C]',WY?YA[&'_`#\7_DW^
    M1K45D_9_$/\`T%-+_P#!;)_\?HS(?@II?_@MD_P#C]',WY?YA[&'_/Q?
    M3?Y&M163]G\0_\`04TO_P`%LG_QC[/XA_Z"FE_^"V3_P"/T<S[?E_F'L8?
    M\_%_Y-_D:U%9/V?Q#_T%-\%LG`,?HS(?^@II?\`X9/_C]',^WY?YA[
    M&'_/Q?\`DW1K45D_9_$/_04TO\`\%LG_P`?HS^(?\`H*:7_P""V3_X_1S/
    MM78>QA_P`_%_Y-_D5?#GR:KXH@7Y88M5'EQCA4WVMO(V!VR[NQ]69CU)KH
    MXW0H-;.L>)Q%J.GJXU-!6L78,WV2WY4><-HV[1@YY!.><#KXA((4$SJ\H4
    M;V1=JD]R`2<#VR?K33;Z$3A&.TD_2_ZI#ZY_0_W'B7Q/;2?-=PWJ+US"]O
    M'$K9]W@E&.ORYQ@@GH*Y'_1_B'>;\OVW2H/L_??Y$LWF_3;]HAZXSOXS@X
    M9F=!1110`4444 %%%% !1110`445G76J[+A[2SMI;R[7`946.(D9&0\#JI
    MC+X8$12;2WA"4W:)HUERZNTTSV^E0?31L4E?S@D,+#JKOR=W!^558CC<
    M%!!IO]E7%_\`-J]SYD9_Y<K?0@>CG[TO4@YPC#J@-:<44<$0PQK'%&H5$0
    M850.``!T%+51I:G3W]Y_A_F_P`/5F9_8GVSYM9N/M__`$[[-EL/V63NZ _
    M.7P1E=M'B/\`Y!D/_7_9_P#I3%6M63XC_P"09#_U_P!G_P"E,53**478TH59
    M3KT^9]5Z;]MBW?:99ZCY9N8<R1Y\N5&*21YQG:ZD,N<8.",C@\54\_5--XNH
    MO[0M1_RWMUVS*/5X^CX`R2G))PL=:U%4X]48QK-+EEJNS_3M_5RO9W]KJ$)E
    MM)UE56V.!]Y&[JP/L,CG!'<58JC>:7'=S"XCGGM;I5VB>W?#8]&4@JXY;&
    MY3C<2,$YJO\`VC=Z;QK"Q&#M>VR/L'<8G)B`'\19E4DE<@$YFOB*]DI_PO
    MNZ_\'\_(UJ9%+'/"DT,BR12&1T.58'D$$=13ZHP:MHPHHHH **** "BBB@
    M`HHHH Y_PS]OO$=ZG-O<ZJWE/\`WO*AA@?CJ,20RSUVY&003T%<_X?PT
    MERO,-Y=W=[ W]&:XDEC;';*.IP>1G! .1704 %<_K/C>*O#5XG,DTMQI[
    M]!&\+3DC_:W6L8!Z8+<9((Z"L/QA!--X3OWM8I)KNU1;VVA12QDF@831I@<D
    M%XU!`Y()`(/-`&Y14<$\-U;Q7%O+'-!@>.2-@RNI&001P01SFI`"BBB@`H
    MHJC>ZM:V4PMR6FO&7<EK`N^5@> <#[JY&-[84'J12;2WA"4W:N7JSKK6;>
    M"X>T@26]O$QNMK4!F3(R-Y)"ID*B\C5-2YNI?[/M3_RPMVW3,/1
    MY.B9!P0G((RLE:%K:V]E;I;VEO%!`F=L<2!%7)R<`<=232NWL:\M.G\6K[+;
    MYOK\OO1G_8-1U#G4KO[/#_SZV$CG_>FX<\@$;0F.0=PK0M;6WLK=>TMXH(
    M$SMCB0(JY.3@#CJ2:FHH44M2)U927+LNRV_KS>OF%%%%49A63XC_`.09#_U_
    MV?\`Z4Q5K5D^(_\`D&0_]?\`9_\`I3%4S^%F^%_CP]5^9K44451@%%%%`&7+
    MHL:3/<Z=,UA<NQ=S$,Q2L>29(S\K$G&6&'(&-PIO]M_8_EUFW^P?]/&_?;'_
    M`:X&WJ!\X3).%W5K45/;8W5;FTJ*_Y_?\`YI^5@HK)_LJXL/FTBY\N,?\`
    ME<9>$CT0_>BZ #&44=$)J6UU97N$L[V[%?-G9#)(I$V!R8F'WP,'L&`P65
    M<C)S=&)T;KF@[K\?N_RNC1HHHJC$***`"LOQ+J4VC>%=7U2W6-I[RFN(UD
    M!*ED0L <$'&1ZBM2N?\`$O\`I=YH6E#E;G4$GF"??2. &<./1?-2!"2,?O,<
    M%E- &II.FPZ-HUCI=NTC065O';QM(06HH4$X &<#T%7** "BBB@#FO#MU;
    MZ)I=WI-]<16J:/84,SA$6U9LVQ!;!A"L6X]7B<98@DVY;G4]741Z9YFG6Y
    M/SWEU;?O'7H1%&Q!5AS\TBX!`^1P<B\=)T]M6&JM9PMJ`B6);AERZH-V`">G
    MWVZ=<\U<J=;FEZ:C9*[_`"_KO'4Y_\`L/6X/WEMXMOI9A]U+TMI(3Z[EBC
    MB<\=,.O.,Y&098?$UFFZVU#_`$35(^)!<RR-_MQ*HW2QG!(8T!W!65E7;K
    MG]<_<>)?#%S'\LTMW-9.W7,V\DKCW>"(YZ_C."06[]"8\J?O3^O4M8U3
    M4_EEC_LVS;ADW[KEQW&Y#MBZ=5D@\%&'%ZSL73X3%:0+$K-O<C[SMW9B>6
    M8X&6.2>YJQ1244M2YU927M%V7]:_,***HR"BBB@ HHHH *R?$?_(,A_P"O
    M^S_]8JUJR?$?_(,A_Z_[/\`]8JF?PLWPO\>'JOS-:BBBJ,`HHHH **** "
    MH;JUM[VW>WN[>>!\;HY4#JV#D9!XZ@&IJ!IM.Z,-=)U'3AIMU"6X@;):
    MQU"9G4DA0"DQ#.F,$X.\')X7J=KK-O/<):3I97CYVVUT K/@9.P@E7P.3L
    M8R,X/%:-<]XX19_"LUG(H,=[<6UDY(Y19IXXBZ^CJ'><,`<'&CEM\)NZ
    MRJ?Q5?S6_P`^_P`]7W)9]2U+4;B6VT%;01PN8YM0N@SQI(#RD<:D&4@@JQWH
    M%)QEF5T5BCQ79N)9IM)U2.'@@MI.0#NRLTDBLW& AV`D\NN.=N""&UMXK>
    MWBCA@B0)''&H544#```X``XQ4E6<Z*ECJ=GJ/F"VFS)'CS(G4I)'G.-R, RY
    MQD9 R.1Q7->'_/UGQSKN2_-8V>-)TT_O4X=URVUOE.90J;QU\G';)Z6^TR
    MSU'RS<PYDCSY<J,4DCSC.UU(9<XP<$9'!XJ/1='LO#^BV>DZ?$(K6UB$<:@`
    M$XZL< 98G))[DD]Z2OU-)SWA?T??7[E\R_1113,PHHHH ***R_$,^H6NBS
    MW.FJ7EA'F21I%YDKQC[XB'3S<9@@@L`",'(&.3=F[%J_U*QTNW^T:A>VUG
    M!G'F7$JQKG!.,D@=`3%9MG!-JJ0:S=1206]NCK8VTJD/\`/@&>13]QRH*J
    MN RJ[[N7)-I^DZ2YMM4B$5_<%?-AU"5A,Y#+]Y'ZI#'A,+\QP`#6M25^I4
    MU!:1U"BO-_$OAWPGHL5;_1_$CUO7[N5K6VN51[F5V4#RXY-H:*&-0#NS^[
    M'.<X![#PKIJ:5X7TZQUK4?[1U*&(+/=8^<\#)Y; PNX\MC)Y)ID&Q1110`
    M4444`%%%% !63XC_`.09#_U_V?\`Z4Q5K5D(_\`D&0_]?\`9_\`I3%4S%F
    M%_CP]59K44451@%%%%`!1110`4444`%9^MZ9_;&CSV2S>1,VV2"?;N\F9&
    M#QR;<C=M=5;:>#C!X)KB_$6GVVAV6M:EXAUSQ/=/<O<7-N^DM=QBSA5!MC"Q
    M,8EXR'D"ACDMT-=1X.GU>Z\':5<:[:3:E;J\TEHP:-
    J05^4DKM)
    _+G
    M.WC%`%S3-3^W>;;W$/V;4? N8MNVYSM=6P-\;8.UL#.""%965="L_5-#TS
    M6A#]OM%ED@8-#,"4EB.Y6^1U(9<E%S@C..:RYKZZT77=TB:6_74&DV1S(Q
    M>WBC`+R&4 @HN40!QN9I!E^N);:Z&D81DOBU\_\`/_.QTE%%%49A1110`444
    M4 %%%% '/M_Q36HR3'G2=1NTW =;6XDH,.L<CD$X&1([,=P=C'T%1SP0W5
    MO+;W$4<T$J%)(Y%#ZD8((/!!'&QX)YM"N(K&EDFT5Q':7DK%FC8G"PS,
    M>22<!)#][A6^?:TH!GMX'QXEO=?A\2:S#?W:"(L%M7$40)(BCWPL40$YP#R>
    M6R>:Z2QMY;2SC@FO9[V1<YGG"!WR2>0BJO'3@#IZ\U8HH **** "BBB@`HHH
    MH R?$?_`"#(?OS_\`2FM:LGQ'_R#(?\`K_L__2F*IG\+-\+_`!X>J_,U
    MJ**HP"BBB@`HHHH`*** .3_P"$=\36CZLNF>*XU@OKB2XB-_8M=2VA=0-L
    M;><J[%()52A S@Y[['AS0+'PMX?L]%TU9!:6J%4\QMS,22S,3ZEB3Q@<\ #B
    MM2J]]?6G6<EU=2>7"F 2%+$DD!551DLQ) "@$DD``DT`5]8UFST.S2XNW:
    M65>WA4@//,YPD:9(!8GU( Y)( )%?0=)N#[9>:C<_:=2OI?-E;@K"@^Y!&
    M=H)C0$X)`RS.V 7(HL;&XO;R/5=5C\N9,FTLRP86@((+,1D-,02"PR%!**2"
    M[R;%`!1110`4444`%%%%`!1110`5'/!#=6\MO<11S02H4DCD4,KJ1@@@\$$<
    M8J2B@#G_`#KSPWS>W/VK1%^47#@F:S7L9G)/F1]C)@,@`+[P7D7<@GANK>*X
    MMY8YH)4#QR1L&5U(R""."".<U)6'/I5]I]Q>:%&?,<O+IMR^RWD=CEI%<(
    MSQN3AC@%6.[-U^QUX:S#26VH(A>2QNE\N=5!`+!3]] QV^8A
    M9"0<,:U`"BBB@`HHHH`R?$?_(,A_Z_[/\`]*8JUJR?$?\`R#(?^O\`L_\`
    MTIBJ9_"S?"_QX>J_,UJ***HP"BBB@ HHHH ***Y__A(7UC]UX96"]7^/4)2W
    MV2,'C,!B=@<_(A ^5@SH<9 -#4]9L]\J.9_,N[C(M;.,@S7+#&0BDC.,C)
    M.%4<L54$BO8Z9>37D>HZU-!-=19-M! I$-KN!!(+',DF"5\PA?EX54W.&L:9
    MI:;YLKW,]Y>38$UW<[?,D"YVK\JJJJN3A5 &2QQN9B="@`HHHH`***`"BB
    MB@`HHHH`***`"BBB@`HHHH`IZEI=IJUNL-VDA".'C>5XI(VP1E'0AE."02
    M",AB.A(K_XJ1OH_:#_KG!>_Z##R?F6U5_C8UT%% &7INOV.I7#68:2
    MVU!$R6-TOESJH(!8*?OH&.WS$(2#AC6I5/4M)TW6;=;?5-/M+Z!7#K'=0K
    M*H;!&0&!&<$C/N:R_P#A&KBTYTKQ#JMJH^80W$HO(W?U<S!I=IX!59$X'&TD
    MM0!T%%<_]I\66GRRZ=I6HQIRTUO=/;R2CJ0D+HRANP#38)&25!X/$JS_\`
    M(2T'7+'=_J_]#U[_7_CV,NW''WMN<\9P< '05D(_\`D&0_]?\`9_\`I3%5
    M7_A-O#L?_'[J']F9^Y_:L,ECYGKL\]4WXXSMSC(SC(K-UWQIX5N=/B2#Q+HT
    MKB\M7I?Q,0JSQLQX;H%!)/8`FIG\+-\+_'AZK\SLJY_P#X3OP?_P!#7H?_
    M`(,8?_BJ/^$STAN8DU6>,\K-;Z/=RQR#LR.D15U/4,I((Y!(JC Z"BN?_M[5
    MKKY=/\+WWS\Q3W\T5O"R]<L`SS)D= 8MV2 P7D@S*=1XN;VQT>$\,E@#=3
    M<<AEEE547)X*F%N <-DC: =!7/\`_"4I?<>'[&?6%/ NH&5+12>A,S$!USD,
    M8A(5VD$9P"?\(=I=S\VL>?K<AY;^TW\V,GLP@ $,!QN5 <9R268GH .?\`
    M[!O-6?Q#>;">?[-M"8[8#^[(?OS\%E.XK&XQF(&N@HHH **** "BBB@ HH
    MHH **** "BBB@ HHHH **** "BBB@ HHHH **** "BBB@ K.UJUFN["*.!-[
    MK=VTA&0/E2='8\^BJ3^%:-%)JZL73FX34UTU"BBBF0%%%% !1110`4444 %%
    1%% !1110`4444 %%%% '_]D`
    end
    Don
    "Don Golding" <dgolding@sbcglobal.net> wrote in message
    news:i5bot3$4m1$1@cheetah.cadsoft.de...
    Don
