EAGLE User Chat (English) Component backdrop
  • Views 547 views
Component backdrop
I like to fill the box a chip uses with a color as it looks better to my
publishers.
Most programs have this option but not Eagle that I can find. I figured a
way to do it with the symbol as I build the device but sometimes the color
isn't the same as what's shown in the symbol when I put it in my schematic.
Is there an easy way to do this?
Rob
    Thanks Warren,
    I think you may be right.
    "Warren Brayshaw" <warrenbrayshaw@paradise.net.nz> wrote in message
    news:ib9jgf$asp$1@cheetah.cadsoft.de...
    "Neil Allison" wrote in message news:ib8hob$mpd$1@cheetah.cadsoft.de...
    (see previous in thread)
    Thanks Neil
    Now back to the original post
    >>Rob Wrote
    >>..............but sometimes the color isn't the same as what's shown in
    >>the
    I imagine that the different color is because a different palette is being
    used for the schematic.
    Likely WHITE for the library and  COLORED for the schematic
    If so you need to get the color being used for the symbol fill into both
    palettes and in the same position in those palettes.
    The alpha channel of the colors should also be set to 255  as some
    transparency, when using a colored background may be the color difference
    you are detecting.
    Warren
    Thanks Neil
    >Rob Wrote
    >..............but sometimes the color isn't the same as what's shown in the
    you are detecting.
    Warren
    Hi Warren,
    >> I use 8 custom layers with 8 different colors for "highlighting" parts
    >> on a board printout for manual assembly of SMT prototypes.  I do this in
    >> the PCB (actually on a separate copy of the .brd file) and do not modify
    >> the library parts.  A ULP is helpful to automate the process.
    explain more fully how your part highlighting works.
    Imagine a silkscreen or tDocu printout that you use multiple highlighter
    pens to mark all parts that have the same value with the same colour.  I
    think some other CAD packages may have this type of assembly aid print out.
    I set 8 user defined layers each with its own colour assigned in White
    Palette colours 56 to 63.  I have Eagle draw a "highlighting" rectangle
    on the appropriate user layer (colour) with its corners on the corners
    of the (element) package area.  I end up with multiple tDocu or
    silkscreen printouts/PNG/PDFs with 8 part values highlighted per page.
    I found it is not perfect as I needed to smash all the parts and accept
    that the highlighting might "overlap" where parts are close together.  I
    manually edit the text output of a mount-trace.ulp to help get useful
    results.
    Some experimenting produced results that our assembler/technician and I
    found useful.
    Neil
    Christchurch, NZ
    I often defune custom layers in the library - it works well for me.
    Neil
    Neil
    Would appreciate it if you would explain more fully how your part
    highlighting works.
    Warren
    >> my publishers.
    If that fails, you should be able to define your own layer and set it to
    any color you like. Then add a rectangle of that layer over the chip.
    I've never actually done this, and don't know if custom layers can be
    defined in the package, but it seems it should work.
    Neil
    Rob wrote on Sat, 06 November 2010 18:46
    my publishers.
    First, tell your publisher to get over it.
