EAGLE User Chat (English) Polygons
  • Views 478 views
Polygons
We use polygons on ground and other planes but we want to shut them off when
routing manually as they can mask the board and make it hard to route when
they are on the top or bottom plane. Is there a simple way to turn them on
and off.
rob
    Thanks!
    "Tilmann Reh" <usenet2007nospam@autometer.de> wrote in message
    news:ighrnv$jim$1@cheetah.cadsoft.de...
    >> when
    >> when
    >> on
    >> and off.
    SET POLYGON OFF;
    After that, RATSNEST won't calculate the polygons (until you turn it on
    again). To also hide the related airwires, use "RATSNEST ! GND" (for
    example).
    Or, after RATSNEST and before routing, enter "RIPUP @;" which will
    display all polygons as outlines only.
    Tilmann
    and off.
    SET POLYGON OFF;
    example).
    Tilmann
