EAGLE User Chat (English) Partial circle, straight edges?
  • Replies 9 replies
  • Subscribers 189 subscribers
  • Views 2184 views
e5frog
e5frog over 15 years ago
So another high frequency application was this geometric figure I couldn't
make in Eagle.
It was supposed to be a 60 degree slice of a circle 15mm radius and 10mm
thick.
So 20mm in diameter empty space in the middle of a 40mm filled circle then
a 60 degree slice of that...  Like if you'd cut a slice of a donut.
I gave up after about 30 minutes and the best I managed to do was that
figure but ending with round edges. So I asked the guy at the Genesis CAD
software and he fixed it by masking a negative image upon that cirle just
by putting two straight lines from the middle 60 degrees apart and then
just kept the area between these - took two minutes.
So if I wanted to do that in Eagle, could it be done? Are there any known
plans of introducing negative images on the top and bottom layer?
I guess this is one of the reasons I used Paint or other paint software to
make PCBs images back in the day. You could do anything you wanted quick
and easy.   image
    e14 Contributor over 15 years ago in reply to e5frog
    "Fredric"  a écrit dans le message de groupe de discussion :
    ihv4j4$3fq$1@cheetah.cadsoft.de...
    Book? Is there a book?
    There used to be a book provided with Eagle license enveloppe. It contained
    the printed version of the pdf's you can now find in /doc. Very cool to have
    on the bookshelf.
    Even for users with experience in Eagle it is interesting to read it again
    from time to time.
    Jerome
    The standard answer:
    There is a manual and tutorial in the Eagle/docs folder
    Read these and do the tutorial.
    Do each and every tutorial you can find on the web. A number have been
    listed here in the past.
    Then learn by doing. Think of an idea and work out how Eagle needs to do it.
    All the best
    Warren
  • e5frog
    e5frog over 15 years ago in reply to e5frog
    I thought I should post a picture of the lovely result:
    http://postimage.org/image/1wzynn4as/
    I'm sure I'd be able to get it there directly if I check exactly what
    coordinates are needed.
  • e5frog
    Just missing a space after the P, problem solved.
    Thanks again.
  • e5frog
    e5frog over 15 years ago in reply to e14 Contributor
    Yes, that gives the needed flat edges but I get an error message "Invalid
    point: (P15 120);GRID l..."
    So I have to manually use it to draw the right length.
    Is there any way of getting these flat edges in any of the menu options?
    It's likely I will never encounter this again but I was curious if it could
    be done and it turns out it's just as easy if you know how...
    Thanks Warren.
    On 01/28/2011 01:30 AM, Warren Brayshaw wrote:
    Fredric wrote:
    >> ............. It was supposed to be a 60 degree slice of a circle 15mm
    radius and
    >> 10mm thick.
    >> then a 60 degree slice of that...  Like if you'd cut a slice of a
    >> donut.
    The following will draw your required 60 degree arc from 1 o'clock, counter
    clockwise to 11 o'clock on the currently selected layer
    ARC 'mysignal' ccw flat 10 (P 15 60)(P15 240)(P15 120); (See below)
    The ARC command breaks down this way.
    'mysignal' (The signal name you give arc(wire) you are drawing.)
    ccw (The arc will be drawn counter clockwise )
    flat (The ends of the arc will be flat as opposed to rounded)
    10 (The width of the arc wire) in the current grid unit (mm )
    Then the arc itself is defined. Read the HELP /ARC to understand the three
    points.
    Warren,
    You did it... I actually pulled out the book and read it!  Very
    interesting.  I did not know that eagle could handle things like this.
    (P 15 60) is the start point of the arc.
    (P 15 240) defines the arc's /diameter/ relative to the first point
    (P 15 120) defines the arc's end point
    Since my interest has been tweaked a bit, I took some time out to
    experiment a little.
    Draws a circle around a point:  (This part came right out of the book)
    MARK (12.5 7.125)
    CIRCLE (R 0 0) (R 0 40)
    Then I added some 1206 pads radiating around three points:
    ADD R1206@smd-ipc R0 (P 50 0) R120 (P 50 120) R240 (P 50 240)
    Enjoy,
        - Chuck
    >thick.
    if I understand correctly ...
    Lorenz
    radius and
    10mm thick.
    donut.
    known plans of introducing negative images on the top and bottom
    layer?
    Hi Fredric
    Gary gave a good answer.
    Just so you understand how easy it can be when you know how, try the
    following.
    In the command line type (copy it there) this series of commands
    GRID mm; MARK (30 20); ARC 'mysignal' ccw flat 10 (P 15 60)(P15 240)(P15
    120); GRID last; MARK;
    Hit enter and observe the arc.
    The 5 commands are easier to spot when written this way. You could put them
    in one by one into the command line
    GRID mm; (Sets the grid to millimeters)
    MARK (30 20); (Sets the MARK at  your nominated centre of the arc and allows
    you to define the arc relative to this point)
    GRID last; (Restore the Gris to what it was before)
    MARK; (Remove the MARK)
    points.
    Note Polar notation is used for defining the points. Read about this and
    Relative notation as well in the HELP and Manual.
    All the best
    Warren
    make in Eagle.
    thick. So 20mm in diameter empty space in the middle of a 40mm filled
    circle then
    and easy. image
    for the top and bottom layers, the Restrict layers cause polygons to
    avoid them. so will signal wires or polygons with different "names". if
    you use the arc command you can draw arcs with arbitrary inner and outer
    radii and angles. But none of these things are intuitively obvious or
    especially convenient in eagle because that is not its purpose. It is
    for capturing schematics, and routing complex circuits. when a special
    copper pattern is desired, it is possible, even quick once you
    understand how eagle thinks, but you can't just sit down to eagle and do
    that anymore than you can route a 4 layer board with 5000 nodes in paint
    just by sitting down and trying it.
    /you need to read the manual/, and practice drawing objects. in eagle,
    arcs and lines are the same object. you also need to learn all about
    polygons and how to use their 20 or so parameters to get what you want.
    learning to use the mark and grid commands the way eagle wants you to is
    also helpful. generally, sensitive mechanical stuff is best done from
    the command line where exact numbers can be entered, just make sure the
    grid is set to finest...i still don't understand under what
    circumstances eagle snaps to the nearest grid point and under what
    circumstances it obeys the numbers you put in.
    also, to get real precision, it would help if you understood that a
    Gerber file is: a raster of vectors, like on an old plotter, with a
    given pen size. look at a Gerber file in a Gerber viewer with the paths
    turned on - it is very instructive to see how shapes are synthesized
    from pen ( apertures in Gerber speak) movements.
