EAGLE User Chat (English) Solved: Creating a stencil file without vias?
  • Views 324 views
>>>>> "Richard" == Richard Hammerl <ric@cadsoft.de> writes:
    Richard> Am 12.03.2011 16:33, schrieb Marc D Ronell:
    >>>>>>> "Richard" == Richard Hammerl <ric@cadsoft.de> writes:
    Richard> Am 10.03.2011 07:37, schrieb Morten Leikvoll:
    >> >> Marc D Ronell <mronell@alumni.upenn.edu> wrote:
    >> >>> How do I create a stencil file which does not contain vias?
    >> I >>> have an Eagle Cad board design.  I would like to process
    >> a cam >>> file to generate an output stencil file.
    >> >> There is a drc setting for a via diameter limit wich masks
    >> vias >> below the chosen diameter.
    Richard> Just as addendum: The limit value refers to the drill
    Richard> diameter of the via.
    >> If I run the gerb274x.cam job and Add a job (tab) with just the
    >> Pads layer (17) and the tCream layer (31), I get a result which
    >> looks reasonable in gerbv for a potential stencil.  Does that
    >> approach seem reasonable?  Or does it miss something that I am
    >> not aware of yet?
    >> Thanks,
    >> Marc
    Richard> For  creating a Geber file  for the solder  paste mask on
    Richard> the  top side you  have to activate  layer 31 in  the CAM
    Richard> processor, nothing else.
Thanks  for the  helpful postings.   I was  just new  at this.   I had
everything  working properly, but  I was  expecting stencil  output on
library  parts  which  were  not  designed to  produce  surface  mount
technology output.
Operator error on my part, just part of the learning experience.
Thanks for the help and feedback.
marc
        >> Thanks,
        >> Marc
    technology output.
    marc
