EAGLE User Chat (English) Re: Circuit duplication
  • Views 470 views
Hi, that´s working for the schematic, but when it start duplicating on the
board, there´s an error.
"Can´t execute while command is running in other window"
How can I fix that?
The error message comes for every line in the script, several times.
It´s like I copy and paste on the schematic, I still need to route on the
board, and that´s not what the script should do, right?
  • Morosh
    Morosh over 15 years ago
    "KR" <k.rusnok@maccor.com> wrote in message
    news:glt2ud$66b$1@cheetah.cadsoft.de...
    This question has already been put to Tech Support, but I will add it here
    as well in case someone has the answer..
    How do we duplicate a section of both the schematic and its layout?
    I have a design that has a common circuit (contains isolated power) that
    needs to be replicated many times, with each part AND signal being UNIQUE.
    I've seen that by adding an underscore & number at the end of each part
    name, such as R22_1 for example, that part in the copy correctly
    increments as expected: R22_2, R22_3, ect.
    The signals do NOT do that, and I haven't seen how to do the same auto
    increment of them in the manual (not sure what search words to use).
    Equal to that in need is to replicate the circuit layout.  When a copy is
    made on the schematic, all the new parts are deposited outside the board
    border.
    There must be a way to make unique schematic & layout copies of circuit
    sections...
    Using Professional Edition 5.3.0
    Thanks!
    Hi:
    Try "duplicating_v41.zip" in ulp download area. v42 is on the way
    Regards
    Maurice
    autodeskguest over 15 years ago
    border.
    sections...
    Thanks!
    Hi:
    Regards
    Maurice
    Maurice,
    Have never used any scripts or ulp before..
    Unable to get this working- yet..
    Comments added to "duplicating.txt" below.
    How to duplicate modules in Eagle easily:
    Preliminary:
    1- unzip,
    2- copy the script files to the default script directory
           (normally "c:
    Program Files
    eagle-4.11
    scr
    3- copy the ulp files to the ulp default directory
           ( normally "c:
    Program Files
    eagle-4.11
    ulp
    4- Launch Eagle
    >>> Copied ulp and scr files.
    5- open your personal library, ex: "open mylib"
    >>> No such library under control panel/libraries.  Created a
    "personal" one.
    6- inside, run the script: "script markers.scr"
    >>> No such file found, only "duplicate.scr" and "markers.scr"
    >>> Stopped here.
        This will add the markers MRK_DOWN_LEFT, MRK_UP_RIGHT,
           MRK_DELTA and NBR_MOD to your personal library
    6- Save your library "write", close it
    7- if you like assigning CTRL+D to the whole operation,
        open eagle.scr and add:
         assign C+D  'script duplicate', save and close.
    8- If necessary, open "duplicate_schematic_v4.ulp" and
        "duplicate_board_v4.ulp" and set the variable scr_path
        (if you don't use the default value), save and close
    KR
