EAGLE User Chat (English) Help Optimizing
  • Views 808 views
Help Optimizing
I have been playing with Eagle Lite for over five years and have not yet
figured out what the Optimize icon (in the board editor) is supposed to do
or how the Optimize command is supposed to work. I read "Help Optimize"
again today, and looked in the manual. The text is plain enough...
and then I tried over and again to join two wire segments on a PCB.
Nothing happened.  I am left with an airwire.
Is there some special case or circumstance besides requiring the lines being
the same width and in the same layer? I can't do anything with it. Very
frustrating.
Any ideas what I might be doing wrong? Does Optimize work for other users,
or is that little icon sitting on my Eagle PCB console a Cadsoft prank? Naah
that couldn't be, and yet...
Thanks for any advise.
    "Brett Holden" <bretth2o@bellsouth.net> wrote in message
    news:is68ul$igm$1@cheetah.cadsoft.de...
    being the same width and in the same layer? I can't do anything with it.
    Very frustrating.
    Naah that couldn't be, and yet...
    Thanks Morten and James. The "Help" text does not state that, as a
    prerequisite the target wire segments must be contiguous as in overlapping,
    but I suppose it should be "understood".
    Actually, yesterday was the ONLY time I tried to "optimize" non-contiguous
    segments; expecting an air-wire to get routed... which does not make much
    sense now that I think about it. (That is what ROUTE is for.)
    Naturally I feel somewhat stupid because all of a sudden it seems to work OK
    on contiguous wire segments. HOWEVER I don't remember having any luck with
    it before but I don't even remember the last time I tried. It was many moons
    ago.
    I tested Altium and Protel and one of my biggest beefs with those products
    was that while making library components I would very often wind up with
    lines that were made up of many individual segments. It was very hard to
    move things without having them break apart. Maybe there was an similiar
    command available in those products, I don't know. Don't care.
    I'll play around with Optimize some more and try to figure out what I was
    doing wrong.
    Thanks again.
    Morten Leikvoll wrote on Thu, 02 June 2011 10:44
    users,
    prank? Naah
    It works. Try drawing a horizontal or vertical wire/net, copy it and
    paste
    as an extension to the first, either continuing one end or overlapping.
    Now
    optimize it and it will become one wire instead of two.
    The two wires also need the same angle and a ommon point. That will
    be
    difficult to obtain on tilted wires.
    The reason it may not seem to work is that there is a setting in the
    Options to always use optimize.  So when you draw a net in two segments it
    will auto-optimize it.  So there is no need in that case for optimize.
    Turn that setting off and then you'll notice it.  I did that once by
    mistake and it I noticed right away.
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    It works. Try drawing a horizontal or vertical wire/net, copy it and paste
    as an extension to the first, either continuing one end or overlapping. Now
    The two wires also need the same angle and a ommon point. That will be
