EAGLE User Chat (English) Element14 - Attachment got through to newsg roup
  • Replies 17 replies
  • Subscribers 190 subscribers
  • Views 1785 views
FYI
I see an attachment to a post done at Element14 got through to the
newsgroup. (eagle.support.eng -  Where is the Package Editing mode button
in the gui?)
Let's see if this image gets back to Element14
Warren
    autodeskguest over 13 years ago in reply to fustiniadmin
    I'm amazed anyone can even use element14.
    If they changed to phpbbs I might try them again but not until.
    Their software is dismal to say the least.
  • fustiniadmin
    fustiniadmin over 14 years ago in reply to e14 Contributor
    On 09/27/2011 08:43 AM, Olin Lathrop wrote:
    Chuck Huber wrote on Tue, 27 September 2011 08:43
    >> When two years rolls around, both would be
    >> deleted at the same time.
    They would both go away together whenever the element 14 administrators
    decide old forum posts should be purged.  Where did you get the two years
    from?  Is there a policy at E14 that posts of that age are purged?  That
    would be surprising since I would think they would want to build up a
    searchable database.  Most likely the post and its associated files would
    be available a lot longer than in a pure NNTP world.
    After reading these recent posts, I would agree that the best approach
    would be to include URLs to reference each asset (image or other file
    type) in element14 posts exported to NNTP.  I will explore how this
    could be implemented and provide feedback.
    As was pointed out, one potential risk with this method is that the
    assets would only be stored on the element14 servers.  However, there is
    no policy to remove content after a certain period of time, and the
    intention would be to host it indefinitely.
    Drew Fustini
    afustini@element14.com
    element14 Community Dev Team
    On 09/26/2011 07:32 PM, Olin Lathrop wrote:
    warrenbrayshaw wrote on Mon, 26 September 2011 17:52
    >> I have two reservations with the method.
    >> (1) I can download an image/attachment from NNTP far faster than
    >> accessing
    >> E14. I just do not wish to visit E14 due to delays that site incurs,
    >> not
    >> helped by having to download a big fat lazy files permitted there.
    That's a implementation detail.  In this case we're only asking the E14
    server to provide a single non-html file.  There is no reason this needs to
    be slow.
    I'll second the motion for a simple reference.  No navigation necessary.
    wget can pull it.  All you need is an http client.  Now who does not
    have one of those?
    Quote:
    >> (2) NNTP stored attachmants will be there two years later but links to
    >> files
    >> stored around the net are often broken.
    I'm not talking about links users added to a message.  Those would be as
    before.  I'm talking about in line images and attachments people added to
    their E14 forum posts.
    The link would be valid as long as the referring message is valid.  They
    should be the same age.  When two years rolls around, both would be
    Enjoy,
        - Chuck
    accessing
    not
    be slow.
    files
    their E14 forum posts.  These would be sent in NNTP by reference.  Since
    these are part of the forum database, they should be available as long as
    the forum is.
    Olin Lathrop wrote:
    warrenbrayshaw wrote on Mon, 26 September 2011 16:18
    >> When the total message size exceeds 50k (message/attachment/wrapper)
    >> it will
    >> not be accepted by NNTP.
    This is another good reason why the forum should never send NNTP
    messages with attachments.  The file already has a known fixed URL on
    the E14 servers, so the NNTP message should go out only with a
    reference, not the actual attachement.  This should be a simple
    clickable link in the NNTP message, so shouldn't cause much hardship
    there.
    A side advantage of this is that placement can be preserved.  If a
    forum user posts a picture in line with the text, the clickable link
    can appear in the same location in the NNTP message.  This preserves
    more of the original information than a attachment would, and of
    course avoids replicating the data to every NNTP user.  Other forums,
    like Eagle Central, could grab the file and display it in line as it
    originally appeared if they choose to implement that.
    Quote:
    >> What needs to happen at E14 as the message is submitted
    >> 1) The message size is determined and it is announced that the
    >> message will
    >> not be accepted by NNTP due to total size.
    No!
    Now you're dumbing down the forum experience to suit NNTP.  I agree
    that Farnell should put some effort into doing a good job mapping the
    forum posts to NNTP, and I think there are reasonable ways to achieve
    this. However, none of this must come at the expense of the forum
    users.
    The forum is a richer environment where more information can be
    expressed. Some information will have to be lost in translation to a
    text based format like NNTP or SMTP.  I think this loss can be kept
    minimal and quite tolerable with some cleverness and the willingness
    to do it.  But in the end it's the forum at the core, and it's
    unreasonable to penalize the forum users because some people prefer
    to receive messages via NNTP.
    OK, Some vaid points. So following  your thinking a link to the image is the
    way to go. It's a simple fix for E14 and does not damage NNTP, which is what
    we are tryng to achieve here.
    (1) I can download an image/attachment from NNTP far faster than accessing
    E14. I just do not wish to visit E14 due to delays that site incurs, not
    (2) NNTP stored attachmants will be there two years later but links to files
    Warren
    news.cadsoft.de
    When the total message size exceeds 50k (message/attachment/wrapper) it
    will
    This is another good reason why the forum should never send NNTP messages
    with attachments.  The file already has a known fixed URL on the E14
    servers, so the NNTP message should go out only with a reference, not the
    actual attachement.  This should be a simple clickable link in the NNTP
    message, so shouldn't cause much hardship there.
    A side advantage of this is that placement can be preserved.  If a forum
    user posts a picture in line with the text, the clickable link can appear
    in the same location in the NNTP message.  This preserves more of the
    original information than a attachment would, and of course avoids
    replicating the data to every NNTP user.  Other forums, like Eagle Central,
    could grab the file and display it in line as it originally appeared if
    1) The message size is determined and it is announced that the message
    will
    No!
    Now you're dumbing down the forum experience to suit NNTP.  I agree that
    Farnell should put some effort into doing a good job mapping the forum
    posts to NNTP, and I think there are reasonable ways to achieve this.
    However, none of this must come at the expense of the forum users.
    The forum is a richer environment where more information can be expressed.
    Some information will have to be lost in translation to a text based format
    like NNTP or SMTP.  I think this loss can be kept minimal and quite
    tolerable with some cleverness and the willingness to do it.  But in the
    end it's the forum at the core, and it's unreasonable to penalize the forum
    users because some people prefer to receive messages via NNTP.
    Progress marches on.  While I think we should do the best we can for the
    NNTP users, we must not hold back everyone else in the process.
    martinuser wrote:
    On 23/09/2011 01:10, Drew Fustini wrote:
    >> Alrighty, so a small 3 KB image got though ok from element14 to NNTP
    >> when included as an actual attachment in the element14 "advanced
    >> mode" WYSIWYG editor.
    >> Now, if that does work consistently, then I think it would be ok for
    >> savvy element14 users.
    I wonder if we could get the reply to always go to the advanced editor
    for certain forums?  We could also include an informational text to
    inform users to 'attach' images until a more technical solution can be
    found.
    Or on the inline reply have a message 'please use the advanced editior
    to attach files and images. Make sure to use the attach file facility
    to ensure images are transferred to the newsgroup'
    Martin
    If you go for a simple solution, such a workaround will haunt you. In fact
    if only some of the attachments and messages get through, you have solved
    nothing, just changed the problem.
    You have another consideration as you ponder a solution.
    When the total message size exceeds 50k (message/attachment/wrapper) it will
    not be accepted by NNTP. A NNTP user quickly sees the message is missing and
    learns/corrects  this very quickly.
    For Element14 users, they see no issue and can see their posting but wonder
    why they are not getting the response from the community they expected and
    are disappointed with it....bad press
    Consider this scenareo:
    A thread is progressing and an E14 user posts a folllowup  message with an
    attachment that causes the post not to be accepted by NNTP.
    Not getting the answers expected, a third message in posted and refers to an
    NNTP users attempt to find the attachment on the previous messages by this
    user and cannot find any.
    At this point it is deamed E14 still has attachment issues.....more time
    wasted or time spent ignoring E14 postings by  NNTP users.
    1) The message size is determined and it is announced that the message will
    not be accepted by NNTP due to total size. You need to explain why reaching
    NNTP is important to the user and suggest reducing the attachment size to
    solve the issue. That will be attachments around 45kB. Some testing will
    need to be done.
    My interest is to cleanup the corruption Element14 has induced into the
    NNTP. Good progress so far with emoticons. Your focus as you do this is to
    give the E14 users the best experience you can. So roll up your sleeves and
    create a full  solution to the attachment problem..
    HTH
    Warren
    news.cadsoft.de
    when included as an actual attachment in the element14 "advanced mode"
    WYSIWYG editor.
    found.
    to attach files and images. Make sure to use the attach file facility to
    Martin
  • fustini
    fustini over 14 years ago in reply to e14 Contributor
    No reception of the image attachment from NNTP on this element14 thread.  I'm curious to see if I can find any successfull NNTP->element14 attachements.  element14->NNTP looks to be in better shape (aside from the requirement to explicity attach the image as a file).
    Drew
