EAGLE User Chat (English) Element14 - Attachment got through to newsg roup
  • Replies 17 replies
  • Subscribers 182 subscribers
  • Views 1528 views
FYI
I see an attachment to a post done at Element14 got through to the
newsgroup. (eagle.support.eng -  Where is the Package Editing mode button
in the gui?)
Let's see if this image gets back to Element14
Warren
    Former Member over 14 years ago in reply to Former Member
    warrenbrayshaw wrote on Mon, 26 September 2011 16:18
    When the total message size exceeds 50k (message/attachment/wrapper) it
    will
    not be accepted by NNTP.
    This is another good reason why the forum should never send NNTP messages
    with attachments.  The file already has a known fixed URL on the E14
    servers, so the NNTP message should go out only with a reference, not the
    actual attachement.  This should be a simple clickable link in the NNTP
    message, so shouldn't cause much hardship there.
    A side advantage of this is that placement can be preserved.  If a forum
    user posts a picture in line with the text, the clickable link can appear
    in the same location in the NNTP message.  This preserves more of the
    original information than a attachment would, and of course avoids
    replicating the data to every NNTP user.  Other forums, like Eagle Central,
    could grab the file and display it in line as it originally appeared if
    they choose to implement that.
    Quote:
    What needs to happen at E14 as the message is submitted
    1) The message size is determined and it is announced that the message
    will
    not be accepted by NNTP due to total size.
    No!
    Now you're dumbing down the forum experience to suit NNTP.  I agree that
    Farnell should put some effort into doing a good job mapping the forum
    posts to NNTP, and I think there are reasonable ways to achieve this.
    However, none of this must come at the expense of the forum users.
    The forum is a richer environment where more information can be expressed.
    Some information will have to be lost in translation to a text based format
    like NNTP or SMTP.  I think this loss can be kept minimal and quite
    tolerable with some cleverness and the willingness to do it.  But in the
    end it's the forum at the core, and it's unreasonable to penalize the forum
    users because some people prefer to receive messages via NNTP.
    Progress marches on.  While I think we should do the best we can for the
    NNTP users, we must not hold back everyone else in the process.
    >> it will
    messages with attachments.  The file already has a known fixed URL on
    the E14 servers, so the NNTP message should go out only with a
    reference, not the actual attachement.  This should be a simple
    clickable link in the NNTP message, so shouldn't cause much hardship
    there.
    forum user posts a picture in line with the text, the clickable link
    can appear in the same location in the NNTP message.  This preserves
    more of the original information than a attachment would, and of
    course avoids replicating the data to every NNTP user.  Other forums,
    like Eagle Central, could grab the file and display it in line as it
    originally appeared if they choose to implement that.
    >> message will
    No!
    that Farnell should put some effort into doing a good job mapping the
    forum posts to NNTP, and I think there are reasonable ways to achieve
    this. However, none of this must come at the expense of the forum
    users.
    expressed. Some information will have to be lost in translation to a
    text based format like NNTP or SMTP.  I think this loss can be kept
    minimal and quite tolerable with some cleverness and the willingness
    to do it.  But in the end it's the forum at the core, and it's
    unreasonable to penalize the forum users because some people prefer
    OK, Some vaid points. So following  your thinking a link to the image is the
    way to go. It's a simple fix for E14 and does not damage NNTP, which is what
    we are tryng to achieve here.
    I have two reservations with the method.
    (1) I can download an image/attachment from NNTP far faster than accessing
    E14. I just do not wish to visit E14 due to delays that site incurs, not
    helped by having to download a big fat lazy files permitted there.
    (2) NNTP stored attachmants will be there two years later but links to files
    stored around the net are often broken.
    Warren
    news.cadsoft.de
    warrenbrayshaw wrote on Mon, 26 September 2011 17:52
    accessing
    not
    That's a implementation detail.  In this case we're only asking the E14
    server to provide a single non-html file.  There is no reason this needs to
    be slow.
    files
    I'm not talking about links users added to a message.  Those would be as
    before.  I'm talking about in line images and attachments people added to
    their E14 forum posts.  These would be sent in NNTP by reference.  Since
    these are part of the forum database, they should be available as long as
    the forum is.
    >> accessing
    >> not
    be slow.
    I'll second the motion for a simple reference.  No navigation necessary.
    wget can pull it.  All you need is an http client.  Now who does not
    have one of those?
    >> files
    The link would be valid as long as the referring message is valid.  They
    should be the same age.  When two years rolls around, both would be
    deleted at the same time.
    Enjoy,
        - Chuck
    Chuck Huber wrote on Tue, 27 September 2011 08:43
    They would both go away together whenever the element 14 administrators
    decide old forum posts should be purged.  Where did you get the two years
    from?  Is there a policy at E14 that posts of that age are purged?  That
    would be surprising since I would think they would want to build up a
    searchable database.  Most likely the post and its associated files would
    be available a lot longer than in a pure NNTP world.
  • fustiniadmin
    fustiniadmin over 14 years ago in reply to Former Member
    After reading these recent posts, I would agree that the best approach
    would be to include URLs to reference each asset (image or other file
    type) in element14 posts exported to NNTP.  I will explore how this
    could be implemented and provide feedback.
    As was pointed out, one potential risk with this method is that the
    assets would only be stored on the element14 servers.  However, there is
    no policy to remove content after a certain period of time, and the
    intention would be to host it indefinitely.
    Drew Fustini
    afustini@element14.com
    element14 Community Dev Team
    autodeskguest over 13 years ago in reply to fustiniadmin
    I'm amazed anyone can even use element14.
    If they changed to phpbbs I might try them again but not until.
    Their software is dismal to say the least.
