EAGLE User Chat (English) Couple of library questions???
  • Subscribers 189 subscribers
  • Views 601 views
image Can anyone tell me how to move the libraries around? I know they are listed alphabetically, but what I would like to do is put my personal library at the top of the list, making it easier and quicker to access. Also,
How does one goes about deleting an individual component in a library. I have created a couple of almost duplicate components for my personal library and now wish to delete one of them. I know if I use the DROP feature, I lose the complete library, not the individual component as I would like.
Thanks to everyone  for helping. In time I hope to be able to receiprocate and help others.
Jeff
    Thank You Lorenz. Your help is very much appreciated and also very helpful.
    Jeff
    e14 Contributor over 14 years ago in reply to Morosh
    Thank You Morosh for taking the time to answer my questions. Very helpful.
    Jeff
    I would suggest strongly to put your own libraries in a separat
    directory. Then edit library path in
    in the library editor "remove" the device by typing
         "remove partname.dev"
    on the command line. If the associated symbol and packages are no
    longer used by other devices you then can remove them too (name.sym,
    name.pac).
    Lorenz
  • Morosh
    Morosh over 14 years ago
    Jeff
    The libraries are alphabetically sorted, rename your library, to look
    like 111.
    you should delete your components from inside your library, open your
    library, then type remove xx.dev (for devices) or remove xx.pac (for
    packages) or remove xx.sym (for symbols), save, close
    Regards
  • Morosh
    Jeff
    like 111.
    Regards
