EAGLE User Chat (English) Need advice (maybe OT)
  • Views 1087 views
LS,
On a design I use four 1N4148 diodes to rectifiers a 20 KHz square signal.
Now I am thinking of replacing it by a rectifier bridge.
Does anyone has a suggestion what device to use?
Harry
    Harry H. Arends schrieb:
    I need more space on the board.
    Maybe I could use a SMD version.
    --> TS4148 RYTS4148 RY by Taiwan Semi, in 0603 or 0805 chip size.
    Eventually, dual diodes are also possible in your application: BAV99 or
    the like, two (signal) diodes in one SOT23. That's what Warren suggested.
    Tilmann
    "Tilmann Reh"  schreef in bericht news:jcaugm$qev$1@cheetah.cadsoft.de...
    >> signal.
    It depends on the voltage and current of the circuit.
    Just take one of the easy to look up parts vendors by specs and hunt
    some down. digkey has a easy to use search for parts interface.
    But take care: most rectifier bridges are really slooooow and suitable
    for line frequencies only. Maybe it's better keeping the 4148...
    What's the reason for your replacement intention?
    Tilmann
    Harry H. Arends wrote:
    LS,
    signal. Now I am thinking of replacing it by a rectifier bridge.
    Harry
    You may entertain using diode pairs in two sot packages.
    Warren
    news.cadsoft.de
    Tilmann
    On 12/14/2011 11:08 AM, Harry H. Arends wrote:
    LS,
    Harry
    Paul R.
