EAGLE User Chat (English) Bugs found in Eagle 6.0
  • Replies 10 replies
  • Subscribers 189 subscribers
  • Views 1284 views
Dusan_R
Dusan_R over 14 years ago
My installation of v.6.0 crashes always immediatelly when I click with CTRL onto simple highlited object in SHOW command. With more highlited objects it works OK.
When I undo PASTE, the window become wrong displayed (some texts mirrored) and correct behavior recovers after re-opening the sheet. (btw, PASTE command now places the content of the clipboard at (0 0) coordinates when finished with ; - don't know fi this is a bug or intentionally changed behaviour). When copying -pasting groups containing nets the consistency is lost and have to be recovered manually - why? Looking forward for the bug-fix upgrade and hopin it will come soon...
    autodeskguest over 14 years ago in reply to autodeskguest
    I have installed 6.2.0 recently and most of really serious bugs seem to be fixed, including this one. Some minor ones remain (e.g. wrong highligtino of the selected pin in PINSWAP). I have reverted back to 5.11 (5.12) three months ago and now I am considering to try a new project in 6.2, so I will see...
    Now I have to clean the mess in libraries and data, because I now have two incompatible sets (5.x - 6.x). The incompatibility is why I am a bit affraid to try 6.x again...
    I think it would be useful to establish an extra thread with the found bugs in current version
    Dusan
    Am 05.03.2012 06:40, schrieb Warren Brayshaw:
    Beta 6.1.2 is available (since Feb15)
    Beta 6.1.3 is available since today and the problems are still there.
    OK, I stopped trying it after the crash I caused within seconds with the
    SHOW command as described by Dusan_R two month ago...
    Rene
    On 3/5/2012 2:06 PM, Mike Evans wrote:
    Thanks Warren. I'm wary of using beta versions though, as the fully released version is buggy and beta versions are even less tested.
    Have you used the beta? Is it better?
    I read the change list and it didn't seem to address the issues people are having - is it worth trying?
    Mike
    Hi Mike,
    It's true that usually betas are experimental, however the current
    situation is special. Right now every beta that is being release is
    consisting solely of bug fixes so our latest beta 6.1.2 is actually more
    robust then our currently "stable" 6.1.0.
    My gut tells me that we should be releasing 6.1.3 relatively soon, but I
    have nothing to go off of for that statement. I have used every single
    release of version 6 and believe me when I tell you that every beta from
    here until the release of 6.2 is worth trying, many issues have been
    corrected with each beta and there are still some to go but we're
    getting there.
    hth,
    Jorge Garcia
    Cadsoft Support
    Mike
    Mike Evans wrote:
    I have these bugs too, version 6.1.1.
    When Eagle decides to mirror the text (especially pin numbers) is a
    sure sign to save your work, get a cup of tea, and prepare to
    re-enter your work again....
    Does anyone know when the next version is out?
    Keep an open eye on the beta forum
    Warren
    news.cadsoft.de
    When Eagle decides to mirror the text (especially pin numbers) is a sure sign to save your work, get a cup of tea, and prepare to re-enter your work again....
  • Dusan_R
    Dusan_R over 14 years ago in reply to e14 Contributor
    Hi Jim,
    the same behaviour in my 6.1. I am only finishing one board I have begun in 6.1 and have  reverted to 5.11 for new things. I don´t want to waste more time testing dead horses or betas on 'hot' data. Try another problem: Pinswap and then Undo. You will loss consistency without any warning (the consistenci indicator remains green in both SCH and BRD) and only after the first ERC, which may be after hours, you find out that the consistency has been lost and spend another hours by analyzing and fixing the problem. 5.11 is a clear coice for me now, we will see after 6.2 is released. For now, upgrade means lost time and money.
    On 2/2/2012 5:59 PM, jim larson wrote:
    Here's the quickest way I have found so far to make Eagle 6.0 Crash: Start a new schematic. Place a part - say a resistor trimmer. Place another part - say a plain resistor. Move the second part to connect to the first part. Now select the mirror tool and click on the first part (to mirror it). Crash! Needless to say, I discovered this after an hour's work - which I lost!
    Back to 5.11 for me!
    Hi Guys,
    Use the latest beta 6.1.1, you'll notice quite a difference in
    stability. Many bugs have been corrected and as the betas and updates
    continue EAGLE will quickly return to the stability you're use to.
    6.0 is a dead horse right now, update and see what you think.
    Best Regards,
    Jorge Garcia
    Cadsoft Support
    e14 Contributor over 14 years ago in reply to Dusan_R
  • Dusan_R
    So after few weeks spent with fixing unexpected and unnotified consistency errors and other problems I give up, throw all work done in 6.1 and 6.0 in the bin and go back to the old good and stable and first of all WORKING 5.11.
    I recommend all who didn't yet convert their data to XML : DO NOT upgrade to 6.1 (6.0) and stay with 5.11 if you don¨t want to waste your time!! I am working in Eagle for years from I think 2.05 or earlier and do not remember so abortive upgrade.
