Ole Olesen wrote:
>Thanks! I couldn't make it work before but it does now! Didn't realize I
>had to press the GO button ("stop-light signal") after the command.
looks like you left out the ';'
Lorenz
Also try
"display all;ripup @;display last;" either in command line, or in an
exit("") command for an ulp.
A hotkey ought to do this for you.
@Lorenz:
Web access to CadSoft support forums at www.eaglecentral.ca. Where the CadSoft EAGLE community meets.
Ole Olesen wrote:
>Think I got the answer here:
>* "ripup" all the signal polygons on a board. (that is,
what about 'ripup @;'
Lorenz
return them to their unfilled state; this shouldn't
actually ripup any routed signals unless you happen
to have a signal at the exact start point of the first
wire of a polygon.
board(B) {
string s;
string cmd = "grid mm; ";
B.signals(S) {
S.polygons(P) {
P.wires(W) {
s="";
sprintf(s, "ripup (%f %f);", u2mm(W.x1), u2mm(W.y1));
cmd+=s;
cmd+="und;";
cmd += "grid last;";
exit(cmd);
It rips up all polygons on all layers, and undo's every time. The undo is
undoing eventually wire rip-up. Use on own expense!
It seem to work for me, but no guaranties
Quote:
Hello, Bill!
You wrote on Sun, 25 Mar 2007 02:39:03 -0700:
B.signals(S) {
S.polygons(P) {
P.wires(W) {
s="";
cmd+=s;
break;
exit(cmd);
start (gulp)
(gulp) Maybe I should find another hobby
..end (gulp)
I turn white when I look at some of the ULPs
Thanks! But it seem to only rip up the polygon in the bottom layer(?). How
should the script be modified to rip-up polygons in every layer?
(that would really make life easier, hope someone can help!).
Best regards
Ole,
