EAGLE User Chat (English) Eagle and shortcuts?
  • Subscribers 189 subscribers
  • Views 954 views
  • eagle
  • shortcuts
  • cad
nardev
nardev over 13 years ago
I have been using 3D modeling and CAD like tools a while and it would be impossible to achieve anything without using keyboard shortcuts.
I'm looking for Eagle shortcuts. I can't imagine that every time i want new component, i need to click on tiny icon, every time i want to group and move something, also do the same.. etc...
I was googling but so far i didn't find anything useful.
Does anyone know something about that? How is that possible that they simply didn't implement that properly?
    e14 Contributor over 13 years ago in reply to nardev
    Vedran Alajbegovic schrieb:
    Thank you for the reply.
    Help was not so helpfull in this case image
    Take the time to have a closer look.
    Open HELP, then look at "editor commands", "command entry" (or similar,
    I use the german version).
    For function keys, look at HELP ASSIGN (this is also mentioned in the
    general section about "keyboard and mouse").
    Tilmann
  • nardev
    nardev over 13 years ago in reply to e14 Contributor
    Help was not so helpfull in this case image however i pund that list of commands which you mentioned there.
    to group and move something, also do the same.. etc... I was googling
    First of all, you can simply enter any command (completely with all
    arguments, partly, or just the command itself) at the command line.
    During normal work, the command line has the focus for every keyboard
    input, so you can always just type.
    Second, all commands can be abbreviated to some extent. The list of
    commands is searched in alphabetical order and the first match is taken,
    for example
    i     means "INFO"
    d     means "DISPLAY"
    m     means "MARK"
    mi     means "MIRROR"
    mit     means "MITER"
    mo     means "MOVE"
    etc. pp.
    Third, you can ASSIGN function keys and alt/ctl-key combinations to
    specific commands. IIRC, several function keys are predefined after
    installation (however I made my own setup for the commands I need the most).
    EAGLE works somewhat different to other CAD software with single-key
    shortcuts, however once you get used to the omnipresent command line
    you'll also see the benefits. I always have one hand at the trackball
    and the other on the keyboard when working with EAGLE. It's extremely
    convenient and fast - but probably you need some training before.
    Tilmann
    P.S. Instead of googling, you might have looked at the manual, the
    tutorial, and the built-in help...
