EAGLE User Chat (English) embedding version control information in schematic and board
  • Subscribers 190 subscribers
  • Views 1008 views
hi all,
after I've finally upgraded to eagle 6, I'm now experimenting with
putting my eagle files under version control (subversion in my case).
One of subversions features is putting revision information into the
files by keyword expansion.
As eagle now uses XML formatted files this now works without problems.
Just put for instance "$URL:$" or "$Revision:$" into a text and
subversion will replace it with "$URL: ULP ulp-name ulp-parameters ..."
Both solution would solve my immediate needs.
What do you think?
Lorenz
    autodeskguest over 13 years ago in reply to autodeskguest
    Jorge Garcia wrote:
    On 6/11/2013 11:12 AM, Chuck Huber wrote:
    Jorge,  Does Cadsoft have any input on this?
    I'm not very familiar with subversion to be honest, I generally use
    Bazaar and then maybe only one percent of it's functionality. On top
    of that I can speak on behalf of the developers.
    But from what I can tell an easy solution would be two use two
    attributes and a ULP. The idea would be that you would use one
    Attribute in the manner described, with the additional text. You would
    then use a ULP to read that string in EAGLE strip the extra characters
    (through an RE or simple string methods) and write that to the second
    attribute which is the one that would be displayed on the layout.
    This would look correct and use the functionality available in
    subversion without changing EAGLE. The downside is that you have an
    extraneous attribute.
    The ULP solutuion has at least two disadvantages:
    1) By running the ULP the file is changed, so that the version control
    system (VC, not necessarily subversion) sees and flags it as changed.
    2) you need to run the ULP to get the desired result. You can't just
    check-out the file and be done.
    For subversion at least there will be a solution as soon as V1.8.x is
    released (see:  "howto get 'clean' subversion revision info into
    global eagle properties" from 2013-06-11 in this news group).
    Lorenz
  • CSWalt
    CSWalt over 13 years ago in reply to dukepro
    Hi Chuck,
    some comments:
    The principal improvement in V6 wrt this was the change to XML that allows you to use
    any versioning system for tracking differences. We also avoid unnecessary changes
    to XML to keep it "diff friendly".
    To get in version info as described, my idea would be to use global attribute "SVN_VERSION" e.g.
    Couldn't you run a small "before-checkin-script" that adapts or increments the value of SVN_VERSION
    in the XML file accordingly ? This could run automatically together with checkin (using an alias
    e.g.).
    Adding a mechanism for direct versioning would require something like suggested by you and others.
    The texts or attributes need to deal with regular expressions.
    Another similar idea might be to teach maths to texts/attributes. Say MATH1 with value "=", similar to Excel. That's actually not the direction we think EAGLE should go.
    These are things where other tools are much better than we, we better focus on our core competence
    of PCB design.
    I'm not saying we don't do this in any case, but it's something considered with low prio.
    Walter Spermann
    On 06/11/13 17:12, Chuck Huber wrote:
    subversion will replace it with "$URL: <path to file in repository> $"
    and "$Revision 12345 $"  every time the file is checked out, checked
    in or updated.
    Other change management systems could be covered with regular expression
    (RE) substitution.  The substitution could be included in an attribute's
    value as well as in a text value.
    As a global attribute, the goal is to set the attribute REVISION (for
    example) to a value of "12345", which is only known after the file is
    checked into the change management system.  The value of the attribute
    as saved could be something on the order of:
        "$Revision:$|/[0-9]+/"
    The first part, "$Revision:$" would expand to a real revision number
    such as "$Revision: 12345$" as supplied by the change management
    system.  Thus, when the file is loaded by Eagle, the value of the
    attribute would be
        "$Revision: 12345$|/[0-9]+/"
    The pipe symbol would cause Eagle to pipe that text into the RE enclosed
    in the slashes.  In this case, only one or more digits would be
    included, resulting in the value of "12345".  Thus the value displayed
    would be the result of the RE.
    This has been discussed in the past in the suggest news group and
    cleaner solutions have been proposed.  See the thread titled "/regular
    expression search & replace support for text variables/" in
    eagle.suggest.eng dated March 5th, 2013.  Recapping part of that
    discussion...
    Shamelessly stealing some built-in functions from GNU Make, a more
    generic form could be:
    |$(subst |from|,|to|,|text|)|
        Replace from with to in text.
    |$(patsubst |pattern|,|replacement|,|text|)|
        Replace words matching pattern with replacement in text.
    See
    http://www.gnu.org/software/make/manual/html_node/Quick-Reference.html#Quick-Reference
    Eagle would have to maintain the formula for the attribute's value.  As
    such, an additional formula property may need to be added to UL_TEXT
    and UL_ATTRIBUTE objects that would contain the as-saved value.  The
    value property would return the calculated value, just as it does now.
    Employing the above, the saved formula for the attribute or text would be:
        $(patsubst .\(+\).,\1,$Revision: 12345$)
    The change management system would replace the /text/ portion with
    appropriate values.
    While I mention only a REVISION attribute, other attributes could be
    defined with their own formulas such as path in the repository, last
    check-in time stamp, or author.
        - Chuck
    Walter Spermann
    Softwareentwicklung
    CadSoft Computer GmbH
    Pleidolfweg 15
    84568 Pleiskirchen
    Tel.: 08635/6989-10
    www.cadsoft.de
    autodeskguest over 13 years ago in reply to dukepro
    I will ask the devs to take a look at this thread and post their
    comments.
    hth,
    Jorge Garcia
         - Chuck
  • dukepro
    dukepro over 13 years ago
    in or updated.
    attribute would be
    discussion...
    $(subst
    from
    to
    text
    $(patsubst
    pattern
    replacement
    text
    See
    appropriate values.
        - Chuck
    0250.att1.html.zip
    autodeskguest over 13 years ago in reply to igalloway
    Iain Galloway wrote:
    If I understand you correctly, I would second this approach.
    I also think that in eagle a custom string for >SVN_VERSION would be
    helpful.
    the situation has been getting better in the meantime.
    subversion 1.8 (due in about 4 week) will have custom keyword
    expansion.
    With that it will be possible to get revision info without any
    overhead into eagle properties and texts.
    If anyone want's to play with it sooner, tortoisesvn nightlies (
    http://nightlybuilds.tortoisesvn.net/latest) already ship with the
    custom keyword capabilities.
    Subversion can execute a post commit script automatically on commit.
    Subversion itself only has server-side hooks (but you probably are
    talking about tortoisesvn and its client-side hook).
    So it could keep the revision in a text file for Eagle to read.?
    that would not help much. You still need a mechanism in eagle that
    could access that information without the eagle files getting
    modified.
    Lorenz
  • igalloway
    igalloway over 13 years ago
    I also think that in eagle a custom string for >SVN_VERSION would be helpful.
    Subversion can execute a post commit script automatically on commit. So it could keep the revision in a text file for Eagle to read.?
