EAGLE User Chat (English) Irregular SMD shape
  • Subscribers 177 subscribers
  • Views 1008 views
Irregular SMD shape
   I am trying to built a Linear Tech part which has DFN14
package(http://www.linear.com/designtools/packaging/dfn/DE14.pdf).  The
central pad is no rectangular.  When I place an SMD pad, it is
rectangular and cannot be mitered. Does this mean I need to use a
polygon and draw the shape in the signal, cream and stop layers? If so,
how far does the solder mask be from the actual pad?
Thank you,
-- A
    Amer wrote:
    Thank you,
    -- A
    Type "help smd" into the command line of your library editor (without
    the quotes).  Look for the roundness parameter.  I think that is what
    you are looking for.  It's ok if the pad on the board is rounded on all
    four corners while the part has one corner chamfered.
      Tom Sneddon
      Tom Sneddon
    Thank you.  That will work.  Is this the only way to make irregularly
    shaped SMDs?
    With the roundness parameter, how do you make sure that you have a
    specific radius?
      Tom Sneddon
    shaped SMDs?
    specific radius?
    You can not add "named" copper to a lib footprint without DRC errors but
    you can make the soldermask and cream layers to the shape you need and
    then add a polygon for the ground plane under the part and it will be a
    better heat sink then just that pad.
    Paul R.
    Paul R.
    So is this how you would create the following part?
    http://www.linear.com/designtools/packaging/dfn/DJC22.pdf
    Thank you,
    A
    but you can make the soldermask and cream layers to the shape you need
    and then add a polygon for the ground plane under the part and it will
    be a better heat sink then just that pad.
    Paul R.
    Thank you,
    A
    I would make the solder mask and cream outline equal to the copper
    outline of the body pad shown on the pdf. Then use a larger polygon
    named what ever net that pad is.
    If you add a pin to the part for the substrate then you could use a SMD
    pad centered on that area but smaller then any of the edges.
    Paul R.
