EAGLE User Chat (English) Newby question about components
  • Subscribers 180 subscribers
  • Views 583 views
Please forgive this newbie question but it does not see to be addressed in
any FAQ.  I'm attempting to lay out  a simple board with the freeware
version and need to add quite ordinary components such as ceramic disk
capacitors, electrolytic capacitors and metal oxide resistors.  When I
search on those components, the list returns devices who's descriptions are
unknown to me.  Obviously, this is a program with a great deal of capacity.
Far more than I'll ever use but is there a simple answer as to what to
select when you just need to add a regular old 1K resistor or a 0.1 uF
capacitor?
Thanks.
Charlie Smith
    capacitor?
    Thanks.
    Charlie Smith
    The RCL library contains commonly used resistors and capacitors.
    -Dave Pollum
    On Sat, 9 Feb 2008 David Pollum wrote saying :
    is there a simple answer as to what to  select when you just need to
    add a regular old 1K resistor or a 0.1 uF  capacitor?
    Thanks.
    Charlie Smith
    Eagle is a CAD program, not a circuit simulator, so it's not really
    interested in whether a capacitor is ceramic, polythene, or anything
    else. What it does care about is the physical package and the schematic
    symbol. For this reason the RCL library lists components with names like
    "R-EU_R0805". This means it's a resistor, shown on the schematic with
    the European symbol, and placed in the PCB as an 0805 surface mount
    package.
    To make it easier, the "add" dialog box from which you select the
    component displays both the schematic symbol and the PCB layout (with
    silkscreen) of the selected device, so you can check before adding
    whether it's what you want. And if you get it wrong, you can use
    "Change->Package" to select a different variant when you're laying out
    the PCB.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
  • WestfW
    WestfW over 18 years ago
    just need to add a regular old 1K resistor or a 0.1 uF capacitor?
    This tutorial contains a number of hints and pithy comments about
    finding the "common" components:
    http://www.instructables.com/id/Draw-Electronic-Schematics-with-CadSoft-EAGLE/
    BillW
