EAGLE User Chat (English) 2013 June EAGLE Bug Poll
  • Replies 8 replies
  • Views 743 views
Hello everyone,
Vote for what bug you would like to see fixed
http://www.easypolls.net/poll.html?p=51ac92bae4b0604d061ed8dc
The poll will let you selet multiple items--just pick the items that are
important to you. Items are in order of most votes over past months and
prefixed by the number of previous votes in parenthesis.
If you would like a bug added to the list please reply to this post and
make your case.
Disclaimer: I can make no promises these will actually get fixed, but this
should help inform CadSoft as to which bugs should be fixed next. Items in
the list are added at my discretion as well as the decision of bug vs
feature on this poll.
Cheers,
James.
Specializing in CadSoft EAGLE
  • Electronic Design Services
  • EAGLE Enterprise Toolkit
    autodeskguest over 13 years ago in reply to autodeskguest
    On 14.06.2013 10:57, Johann Glaser wrote:
    My wish is to have ULP as a full and complete interface to Eagle, which
    can do everything you want, with and without a graphical interface, with
    and without querying the schematic and board inventory, with and without
    changing the schematic and board inventory, ...
    I'm totally with you. Please, please, please!
    Markus
    Am Freitag, den 14.06.2013, 07:40 +0200 schrieb Christian Bohrer:
    "Eric Stevens" <estevens@gdimeters.com> a crit dans le message de news:
    kpd32a$ar1$1@cheetah.cadsoft.de...
    On 06/12/2013 03:43 PM, Johann Glaser wrote:
    Hi!
    Am Montag, den 03.06.2013, 08:50 -0400 schrieb James Morrison:
    Hello everyone,
    make your case.
    Please add ULP commands which can perform the very same things as is
    currently reserved to scripts. Precisely, remove the necessity for the
    dirty workaround to generate a script and execute it after quitting the
    ULP.
       Johann Glaser
    You can do this now. Concatenate a string with the same commands you would use in the script and
    then pass the string to the exit() function.
    For example,
    string cmd;
    string s;
    board(B)
      B.elements(E)
        if (ingroup(E))
          sprintf(s, "ROTATE R22.5 %s %d;\n", E.name);
          cmd+= s;
    exit(cmd);
    That we are asking is to execute a command without leaving the ulp (non modal).
    An other function as exec(cmd) instead exit(cmd) is needed;
    Thanks for making the point more precise. The exit() thing is an
    especially nasty problem.
    On the other hand, I'd really like normal ULP commands which do the job,
    not again sprintf()'ing strings and then handing them over to the Script
    interpreter.
    For example,
    board(B) {
      B.elements(E) {
        if (ingroup(E)) {
          rotate(E,22.5);
      Hansi
    "Eric Stevens" <estevens@gdimeters.com> a écrit dans le message de news:
    Hi!
    Hello everyone,
    make your case.
    ULP.
       Johann Glaser
    For example,
    string cmd;
    string s;
    board(B)
      B.elements(E)
        if (ingroup(E))
          cmd+= s;
    exit(cmd);
  • Johann.Glaser@gmx.at
    Johann.Glaser@gmx.at over 13 years ago in reply to autodeskguest
    Am Donnerstag, den 13.06.2013, 14:29 -0400 schrieb Eric Stevens:
    Hi!
    Hello everyone,
    make your case.
    ULP.
       Johann Glaser
    would use in the script and then pass the string to the exit() function.
    Arrrm, that was exactly what I was criticizing as a dirty workaround?
    Bye
      Hansi
    Hi!
    Hello everyone,
    make your case.
    ULP.
       Johann Glaser
    For example,
    string cmd;
    string s;
    board(B)
       B.elements(E)
         if (ingroup(E))
           cmd+= s;
    exit(cmd);
    Oops. Ignore that extra %d in the sprintf() statement.
    autodeskguest over 13 years ago in reply to Johann.Glaser@gmx.at
    Hi!
    Hello everyone,
    make your case.
    ULP.
       Johann Glaser
    For example,
    string cmd;
    string s;
    board(B)
       B.elements(E)
         if (ingroup(E))
           cmd+= s;
    exit(cmd);
    ULP.
    Count me in image
    Hi!
    Hello everyone,
    make your case.
    ULP.
      Johann Glaser
