EAGLE User Chat (English) Searching for a package in the libraries
  • Replies 8 replies
  • Views 1570 views
I am really new to eagle, like 2 days or so, but I am looking for a better
way to find the package i need from the libraries, so that i can coppy it
and make a new part. I have made one so far but it is a pain to search for
the right  package. I know i could just make my own but i dont trust my self
to the the measurements right, mabe after i print off this board.
Right now i am looking for the (SMD-220, TO-263) package for a diode but
there dose not seem to be one in the doide.lbr. i have also searched a few
other places and have not come up with anything.
Thanx
Spikes
    wow that was real easy. Thank you so much!
    cheers
    Spikes
    Spikes2020 wrote:
    Do you know about using wild cards in the 'Add' window?
    You can do a search by typing TO-263
    Scott
    Scott
    Nope and thus i am stuck agian on a nother part. I tried looking for what
    you where talking about and cant seem to find it. When i make a new part i
    go to my project and select new library, then i select package. This is the
    point where i need to upload the old package, or search for one but cant
    seem to figure it out.
    The part i am looking for is TO-252AA i have read some place that they
    renamed these diodes to something else. Not too sure on this though...
    spikes
    I went into 'Board', (You won't find it in the schematic editor b/c you
    are looking for a footprint name).
    Click on the Add button.
    In the bottom of the Add window type TO252 and hit enter.
    I show 5 places it found them likely candidates.
    Note which libraries they are located in, then open the library and
    steal the footprint from there and insert it into your library using cut
    and paste.
    Scott
    Scott
    Scott
    spikes
    Thanx
    Spikes
    Scott
    Yeah i ordered the parts off digikey and they all had datasheets. Most of
    them are soic-8 packages so it wont be too hard to make them all up. im just
    going to worry about microcontroller and all surface mout resistors,
    capacitors, and my big though-hole inductor that i got for free.
    Also some of the wires on this board are going to have up to 6 amps on them,
    i read some place that i should make the wires a bit larger. I dont know the
    excact size i should use. Its only up to 20 volts peak so nothing crazy.
    I found a hot air gun on my campus that i can use, also they have an oven
    for that but ill read more about working with surface mount parts when i got
    the board orderd.
    Thanx agian
    spikes ^^
    "Paul Romanyszyn" <pgr@arcelectronicsinc.com> wrote in message
    news:fqut6o$15f$1@cheetah.cadsoft.de...
    Ing. J.M. Rafetseder wrote:
    Try ref-packages, there are lots of packages in it image
    There are some variants for TO263. See manual & tutorial for details
    creating a new device!
    r
    Also before you make a board check to see if you can buy the part and then
    the data sheet to see if the lib is correct for your type of board and how
    you are going to place the parts.
    It is best to copy parts to your lib and in the process verify it with a
    data sheet. But some of the smaller parts (8 pins or less) it is quicker
    to just make the part from the data sheet.
    To exactly place pads and lines use the numeric input method.
    Paul R.
    Oh nice, yeah that file has almost all of them that i will ever use, got the
    part made in no time. I found a good guide for making parts here
    http://www.instructables.com/id/E4D4Y2MEK1EP286NXF/
    Still a search function for the libraries would be nice...
    Thank you so much
    Cheers
    Spikes
    Original Message -
    From: "Ing. J.M. Rafetseder" <jrafetseder@hotmail.com>
    Newsgroups: eagle.userchat.eng
    Sent: Saturday, March 08, 2008 2:03 PM
    Subject: Re: Searching for a package in the libraries
    r
    "Ing. J.M. Rafetseder" <jrafetseder@hotmail.com> wrote in message
    news:fqurdk$tvc$1@cheetah.cadsoft.de...
    r
    r
    then the data sheet to see if the lib is correct for your type of board
    and how you are going to place the parts.
    Paul R.
    e14 Contributor over 18 years ago
    r
