EAGLE User Chat (English) CAM issues with power planes
  • Subscribers 180 subscribers
  • Views 424 views
My understanding is that Power plane on an inner layer in Eagle are created
"negatively" - however, when I create gerbers, it looks like my CAm settings
don't create the inverse of the file.
Am I doing something wrong? missed something obvious?
I'm viewing gerbers created using viewmate.
/R
"Do not wave at a performer unless seated. Good studio practice minimizes
all Standing Waves."
Dafydd Roche
  • Richard_H
    Richard_H over 17 years ago
    created "negatively" - however, when I create gerbers, it looks like my
    CAm settings don't create the inverse of the file.
    /R
    Negative printing and displaying is only for "Supply" layers.
    Such layers have the $ character in the beginning of the layer name.
    In case you defined polygons in inner layers (no "supply")
    they are printed the same as Top or Bottom, for example.
    Richard Hammerl
    Richard,
    thanks for your reply. I'm still a little confused (if I'm honest).
    My layer is called $GND. I process it at a Gerber_RS247X file (even on it's
    own) and the file exports as a namefile.gnd.
    That part is fine.
    When I load it into viewmate (I select a layer and hit F4 to load the file)
    and the file loads with the "copper" only where the holes are.
    In other words, it looks exactly the same as the view in Eagle. The View in
    Eagle is inverted as far as I know. The view in viewmate should not be...
    right?
    I'm sure I'm missing something obvious here...
    thanks again
    /Dafydd
    "Richard Hammerl" <ric@cadsoft.de> wrote in message
    news:g0c29i$r6j$2@cheetah.cadsoft.de...
    /R
    Richard Hammerl
    On Fri, 16 May 2008 Dafydd Roche wrote saying :
    View in Eagle is inverted as far as I know. The view in viewmate should
    not be... right?
    I think what you're missing is that if you're using supply layers you
    should tell the board house that they are supply layers and therefore
    the Gerbers are negatives. The board house should then cope with that.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
    Former Member over 17 years ago
    Hello Dafydd,
    In ViewMate, right click on the layer and choose 'negative' from the dialog
    to view correctly.
    Terri Miller
    "Robert Pearce" <news@bdt-home.demon.co.uk> wrote in message
    news:krsXk2OKrFMIFwNL@daniel.huneausware.local...
    in Eagle is inverted as far as I know. The view in viewmate should not
    be... right?
    should tell the board house that they are supply layers and therefore the
    believe a word.      |
