EAGLE User Chat (English) Pin Names
  • Subscribers 177 subscribers
  • Views 781 views
Pin Names
The distance between the pin and associated name in the symbol editor
appears to be fixed and equal to 0.1" which is a rather big gap.
I looked in the "Edit" and "Options" menu items but couldn't find a way to
change this. Is it somehow possible to change this gap size?
Second question : vertical pins in a symbol have their name also oriented
vertically. Is there a way to chage this to horizontal? If I have one GND at
the botttom and one Vcc pin at the top of a symbol, I'd prefer to have the
names "GND" and "VCC" horizontally because in that way they don't interfere
with the names of the horizontal pins, unless I make the symbol a lot bigger
than really necessary.
I should add that I'm still using version 4.11 and that these remarks might
be no longer valid on more recent versions.
    It is good practice to only post your question to one group. In general most
    users will check all groups. See eagle.support for answers.
    Sorry, my mistake. I'll keep it in mind.
    "David Moodie" <dgmoodie@onetel.com.cut_this_off> wrote in message
    news:g2o43i$4ug$1@cheetah.cadsoft.de...
    to change this. Is it somehow possible to change this gap size?
    at the botttom and one Vcc pin at the top of a symbol, I'd prefer to have
    the names "GND" and "VCC" horizontally because in that way they don't
    interfere with the names of the horizontal pins, unless I make the symbol
    a lot bigger than really necessary.
    might be no longer valid on more recent versions.
    most users will check all groups. See eagle.support for answers.
    Issue no. 2  Don't top post.  This is a newsgroup, not e-mail.  Of course
    when you start bottom posting you also need to remember to trim posts
    appropriately, but then things are much easier to follow.
    Even with e-mail, top-posting is a pain (and full quotes too).
    Tilmann
    "Tilmann Reh" <tilmannreh@despammed.com> schrieb im Newsbeitrag
    news:g2qq5i$ttm$1@cheetah.cadsoft.de...
    Tilmann
    Coming to think about it - I guess the root problem is in the mail /
    newsreader software. Perhaps the mail client should show the last additions
    at the bottom when opening a mail, and not the oldest stuff on top. Since
    this does not work, and will never be changed, people tend to draw attention
    to their remarks in this "upside down" way. It's just a human workaround.
    T.
