EAGLE User Chat (English) yellow X's on via's
  • Subscribers 179 subscribers
  • Views 738 views
yellow X's on via's
When I am routing air wires from a via, sometimes I get a yellow 'X'
that doesn't disappear unless I rip up the trace and reroute.  Is there
a way to get rid of these some other way?
cheers,
Jamie
    The "X" is the visual indication for a "vertical" air wire. In earlier
    versions, there was only a dot (line of zero length and width), which
    was very hard to see.
    Tilmann
    Thanks, on a two layer board I don't understand why there would be a
    vertical air wire though image  I think routing vertically is taken
    care of by the via!
    cheers,
    Jamie
    Tilmann
    care of by the via!
    Maybe you just overlooked a detail.
    Does the X disappear when you run RATSNEST? If the nets are correctly
    connected, it should.
    It would also be interesting to know after which operations (exactly!)
    those crosses appear. Here they have always been correct so far...
    Tilmann
    care of by the via!
    No the X's stay after ratsnest, I usually only get a couple every time
    I route a PCB.
    I am pretty sure they mainly occur in the situation where I am routing
    a track starting at a via, and eagle defaults the route layer to the
    wrong one, so I manually switch back to the desired routing layer, and
    eagle places a via on top of the one already there in this case.  Once I
    delete one of the overlapped vias then sometimes there is an X that
    doesn't disappear on the remaining via still image  When routing from a via
    I think eagle should use the currently selected routing layer as well.
    cheers,
    Jamie
    Tilmann
    On Thu, 26 Jun 2008 Jamie Morken wrote saying :
    I
    via
    When I route from a via it always does use the selected layer.
    Furthermore, if I don't want that I can swap layers during routing and
    not get an extra via. Indeed, if I have a track that runs along the
    bottom to a via, then the top to another via, then back to bottom, I can
    "Change layer" on the middle section and both vias completely vanish.
    Perhaps you need to zoom right in and see if there's actually a very
    tiny unwanted track on your via. That could cause the sort of bad
    behaviour you see.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
